Question about Avanti Refrigerators
Avanti WC191BG Little Tavern
I have had this cooler for several years with no problems. Recently I noticed ice built up inside the unit in the top back part. I unplugged the unit and placed it outside for a day or so and allowed all the ice to melt away. When I plugged the unit back up, I heard a popping sound and the unit doesn't seem to work now. Any suggestions?
Thanks, Jody
SOURCE: Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Posted on Feb 03, 2008
SOURCE: new Refrigerator not working properly after being tilting while unloading
You can power the refrigerator on after 3-4 hours, as per _any_ manufacturer's instruction manual. But seriously, all you need to do is give it about 3 hours and you will be fine.
Posted on Feb 20, 2009
  • 85 Answers
SOURCE: Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Posted on Mar 02, 2009
  • 93 Answers
SOURCE: Avanti EWC16B (wine cooler) got fried by power surge
A lot of time during storms the control boards in appliances get messed up. Try unplugging it and plugging it back in after about 20 seconds. A lot of times that will reset the controls.....if they did not get fried.
Posted on Sep 12, 2009
Testimonial: "I enjoyed the detailed explanation. The fuse was indeed blown, but the diode probably as well. But can anything else be blown??"
shastalaker7
  • 1515 Answers
SOURCE: Avanti Beverage cooler gets too cold
Hi, sounds to me as though your temperature control is faulty, and the unit is running all the time. This control will have to be replaced. This is something you can do if you take your time and draw a wiring diagram in case you forget. It will have a long coiled up wire with a bulb on the end of it mounted in the evaporator section in the refrigerator section. This all comes out together. This is the only thing that would cause this problem. Get all of the numbers, model, serial, and part numbers when you go to the appliance parts house to get one. You should have no problems in doing this. Please keep me posted as I am sure this unit is worth changing out the stat.
Sincerely,
Shastalaker7
Posted on Feb 02, 2010
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Doesn't defrost... It cools down to the target temperature and then eventually freezes up
Please check your airflow around the back of the unit,
these units cannot be built in any way reguardless of the manual saying they can
the need a good inch of air for the compressor to cooldown.
Nov 05, 2012 | Avanti BCAD680 Beverage Cooler
When the fan runs it sounds like something is
Replace the fan. Probably bearings in fan are failing.
Nov 15, 2017 | Avanti (BCA5105BG) Beverage Cooler
My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Nov 20, 2009 | Avanti WC3201D Wine Cooler
Avanti Beverage Cooler BCA5105SG running very loud.
Inside the cooler is the evaporator fan usually right in the middle behind a cover. As it slows down you have less circulation and ice forms quicker and cooling is diminished. Sounds like it is going out.
Sep 14, 2009 | Avanti (BCA5105SG) Beverage Cooler
My Avanti wine cooler is not cooling any more.
piece of junk, can not be fixed. Join all the other ones who have bought this unit.
Aug 01, 2009 | Avanti WC3201D Wine Cooler
Thermostat for WC400ygb
personaly i would fit a universal one
Mar 13, 2009 | Avanti WC400YGB Wine Cooler
Mar 02, 2009 | Avanti Refrigerators
Ice forming inside of wine cooler
i would check running temp 1st/possible gas fault
Feb 17, 2009 | Avanti WC400YGB Wine Cooler
Left side fan is not working
Sounds like the fans have stoped turning for the cooling system. If you cannot hear the fans turn on when you flip the COOL switch this is your problem. Pick the fans up at a computer parts store like Frys. Any other part failure on this unit other than a loose wire is not worth repairing. A little oil inside teh motor and several revolutions later might get some relief until a new motor is installed.
Jun 13, 2008 | Hamilton Beach Water Cooler with Storage...
Refrigerators Logo
95 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
