Question about Canon HG10 HD AVCHD HD Camcorder
The lens of the viewfinder Canon HG10 was pushed inside. I removed the small outer lens through the opening. How can I open the viewfinder tube in order to push the lens back in place?
I removed the screw on the bottom of the tube, but it still won't come off. I can not see other screws that can be removed. After removal of the screw I tried to remove the plastic part, but that does not seem possible.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 103 Answers
i am not a user of this cam, but generally you have to open the camera shield to be able to separate the two parts of view finder, because or there are also screws in the inside of the hinge (pivot point) or the hinge itself does maintain the two parts...
cheers
Posted on Nov 25, 2014
SOURCE: Canon MV800i tape would not eject.
Put pedalfoot in camera, shake vigorously.
Posted on May 13, 2008
SOURCE: Canon ZR100 cassette compartment won't open
ok so my tape inside broke and i spent some time tinkering around with it.
step 1: take the extremely small screw out from the top. VERY SMAL!!! hehe
step 2: with some strength behind it, try to slide the cover that the screw held on off the top and thatlets the cassette tray come out...
now when i put a new cassette in, it will close, but will eject it after it thinks if it will accept the tape or not... i think its just being retarded... tried the tapping thing - didnt work... im thinking of dropping it out the second floor and trying afterwards...
Posted on Aug 19, 2008
cpt100
  • 154 Answers
SOURCE: canon xl2 will not take the tape it says remove
Canon XL series will indicate "remove tape" sign when the head does not read the data when inserted. You probably have clogged head and probably needs cleaning. Depending on the condition of the clogged head, you can try by running head cleaning tape for about 10 sec. If that does not resolve, it shoud be cleaned and adjusted by trained technicians. Good Luck. If need a professional help, go to www.camerarepairjapan.com
Posted on Mar 26, 2009
  • 18 Answers
SOURCE: my canon camcorder drive for tapes rejects tapes
I had the same problem. Checked the site and found a solution of dropping the camera onto a carpeted floor from about 1/2m to 1m. Thought that it was bullsh1t but was desperate and so tried it. worked a treat!!!
Hope this helps.
Posted on Aug 13, 2009
SOURCE: Put tape in cassette compartment push it closed -
I am having this same problem and I did a test. There appears to be some type of light sensor that fits in the tape when you try to close it. When there is no tape the loading mechanisim will work. If you put in a tape it covers the sensor and will reject the tape. I used a clear straw and covered the sensor and it closed. I then blocked the ligh from coming in the straw and covered the sensor and it ejected the same as having the tape in. Does anyone know where I get get this part?
Posted on Feb 06, 2010
Lens error, restart camera
It is more than likely dirt on the lens zoom extension tubes, try looking for any dirt or obstruction when the lens is extended ( if it will open) if not try using a vacuum cleaner suction tube NOT FULL STRENGTH YOU MUST LIMIT THE VACUUM. insert a small tube into the large suction end and seal it with your hand then run the small tube end around the lens extension. Remove the battery for 15 minutes then replace, if still not working then you will have to send it back to Canon for repair.
Dec 29, 2010 | Canon PowerShot SX110 IS Digital Camera
My canon lens 28-135 produces focused pictures but looks fuzzy in the viewfinder...is there something that has to be cleaned?
If your camera has a viewfinder diopter adjustment (small wheel a the side of the viewfinder) try moving this up and down to see if that corrects the problem
Sep 03, 2010 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
Blank screen on Canon Powershot S2is camera
hi.if you are telling both viewfinder and lcd are blank or black the problem is in the shutter that you found inside of the lens are not open.sometimes the cuase of the is humidity or moist goin inside of the shutter thats why it will not work properly or stuck up.if you can open your camera and adjust the shuuter from lens unit its better .but if not its better you bring to service center and request for adjustment.
by the way try also to reset your camera to default setting maybe it will help you.
thank you
Jul 08, 2010 | Canon PowerShot S2 IS Digital Camera
07 BMW 750I HOW TO REMOVE OUTER DOOR HANDLE
To remove the outer handle, open the door and while looking at the edge of the door with it open, you should be looking at the side that the door latch lever is on, look near the top area and you should see a small black plastic oval piece. Remove that piece. Take a flash light and look inside the hole. There will be a brass lever inside with a small hole. Use a pick and insert in the brass slide. If you either push or pull the lever to or away, it will release the outer handle assembly. The assembly levers upwards when removing.
May 18, 2010 | 2007 BMW 750Li Sedan
My Canon HG10 HD AVCHD 40GB is acting up! The Lens door won't shut and it keeps clicking inside the Camera... Why? How can I remedy this problem?
hey did you ever solve this problem? I'm having the same problem and it's driving me crazy. It happened out of no where. Help would be much appreciated.
Apr 16, 2010 | Canon HG10 HD AVCHD HD Camcorder
Cleaned inside of viewfinder, now AF focus lights gone
Then you learn, when everything works fine, dont mess with it! Have a look at the gold pins that rely the body to the lens. Also check that your lens manual switch focus is engaged... Try a friend lens to see if its your cam or the lens...
Jul 29, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Diopter adjustment and viewfinder problem
Hi
I would not attempt to open the camera for any sort of fix. It has weather seals in place and would recommend sending it in to Canon. If you have any warranties left it would void these. Lastly this is a high proformance bit of kit and you want to get is seen to by an Authourised Canon Dealer.
As for the diopter adustment. To be able to see through the view finder and see your subject clearly, take of the lens cap aim the camera and turn the little dial until the screen inside the viewfinder is clear it should not be fuzzy. You are only looking at the screen/gring and not the image beyond. This does not affect your image but does effect how clearly you see your subject through the viewfinder.
Hope this helps
Regards
Jun 03, 2008 | Canon EOS-1Ds Mark II Digital Camera
Viewfinder screen and viewfinder are black and lens is off
Make sure the selector switch is turned to record (the center position) and camcorder is turned on. Make sure the viewfinder is pulled out fully when you look in it. If that doesn't work try resetting the camcorder. Open the LCD and there is a small hole near the play button, gently push a paper clip in the hole all the way and press the power on button.
Mar 24, 2008 | Sony Handycam DCR-DVD101 DVD Camcorder
Lens canon 28-135 IS
Need to open Lens?
1. Front Lens Cap- press the two side taps in and pull out.
Rear Lens Cap- twist and pull out.
2. Remove and Repair: Small Phillip Screwdrivers, gloves and mask.
From the rear, the electrical contacts- remove all those
screws. Some screws are locked with clue. Pinch black
plastic ring that is part of those contacts and gently remove out.
Don't brake the electrical contact ribbon cable.
Good lock.
atdlee@netzero.com
at
Dec 23, 2007 | Canon Zoom Wide Angle-Telephoto EF...
550 Problem: Dust collecting inside Viewfinder
I had hoped that a few people would check their cameras and posted replies before I contacted Pentax about my dust problem, but nobody has so far. But it's interesting that someone else posted a message this morning that he has some dust inside the lens of his 550. Anyway, this morning Pentax Canada told me that there should definitely be NO dust inside the viewfinder or the rest of the camera for that matter. Although the Viewfinder is "almost sealed" from the rest of the camera, it is not a total seal - which means to me that if dust can get into the viewfinder, it can get into the rest of the camera's interior - including the lens and imaging chip. They have asked me to bring my camera in so they can remove any dust particles that are inside. Basically, they told me that the only place I should see any dust is inside the lens cover, which is meant only as a protective covering rather than a seal from dust. Even then, they claim that any dust on the outer lens would only enter while the camera is being used. That one I don't buy, as the lens cover is very flimsy and can easily be accidentally spread open while the camera is turned off.
Sep 08, 2005 | Pentax Optio 550 Digital Camera
Open Questions:
See all Canon HG10 HD AVCHD HD Camcorder Questions
Canon HG10 HD AVCHD HD Camcorder Logo
37 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
