Question about Onkyo 7.2 Channel Network A/V Receiver - TX-NR737
How do I get the vertical lines out when I switch to bd/dvd.It will also go to a blue screen.
I have tried resetting the system and inputs but I still get vertical lines and then it will go to a blue screen. tx-nr737
    Habit-Forming:
  • 166 Answers
Sounds like a hdmi fault on the dsp board
Posted on Nov 26, 2014
2 Suggested Answers
XSdB
  • 80 Answers
SOURCE: No sound when dvd input is selected on onkio tx-ds696
Make sure your DVD setting is looking at the right audio inputs. Usually there is a menu option or a button to toggle from analog or digital input. Usually when no-sound but video ok, you have the wrong input-type selected. If you are using 2 RCS's (red/white) then you want ANALOG input mode. If you are usung a single RCA (orange) or a fiber optic input for audio, you want DIGITAL input selected. If digital os selected, make sure you plug into the correct digital input to hear. If it does not work at first, mofe the jack/fiber around into the different inputs untill you hear sound, then you will know which port is associated with the DVD setting. Unless it is self evident feom the menu.
Posted on Jun 12, 2009
Can I hook my cable box into my Sharp Blu ray player
Curious why you would want to do this since both cable box and BluRay generate output signals. I doubt a single line pass-through would work since the last device on the link would override the signal with its own content when turned on.
If your TV or media system accepts multiple inputs, I would route each device to a separate input on the TV/MS and switch between them with a remote. I run HDMI lines out from both my cable box and BluRay box directly into the TV as two different lines and it works fine.
Jun 29, 2012 | Panasonic DMP-BD77 Blu-ray Disc Player -...
Vertical Lines on my Mitsubishi WS-65819
This sounds like a bad connection or a bad capacitor in the 220 volt source that supplies the voltage for the CRT boards. You will need to get a schematic and trace out this voltage from the PM board to the CRT driver boards when the set acts up. it could even be a connection on one of the plugs from the PM board to the CRT boards. Sorry but not a real easy repair. Might take some time to trace unless a component is failing. Good Luck
Jun 29, 2007 | Mitsubishi WS-65819 TV
TV has blue vertical lines and no picture
I have a 42" Electrograph plasma and it has a 2" black vertical line on the left side of the screen.
Aug 02, 2010 | Electrograph Systems DTS4230 42 in. Plasma...
Blue vertical and hrizontal lines moving slowly
This is usually caused by a ground differential. on the cable box. Solution is to put an F-type cable box ground eliminator on the incoming coaxial cable line. You can test this theory by unplugging the Coax on the INPUT of your cable box. They are less than $12.00. For more info go to www.cedia.org and put in your zip code to find the closest in home tech to install one for you.
Feb 10, 2010 | Ronin P807 DVD Player
Picture goes off after a while
Call 1-800-Samsung to set up a warranty service call. They will repair it in your home if they send a Samsung Field Engineer. You probably have a bad Main bd.
Jul 01, 2009 | Samsung 32 in. LCD Monitor TV
Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Jun 12, 2009 | Sanyo Televison & Video
Blue horizontal and vertical lines
We have many problems with loose or poorly seated cables and connectors on these units. Pull the back and reseat all the internal cables, especially the LVDS cable to the LCD control bd. If this does not correct the problem the main cause is a bad LCD control bd. or possible a defective main bd.
Jan 12, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Vertical red/green lines
This set has a bad digital board.and or signal board
The company is in California and is a china inport.
Digital and signal board could cost $130+
Nov 03, 2007 | Soyo Dymond DYLT032A Television
Mitsubishi WD62530 62 in. HDTV LCD displaying blue vertical lines
i just got the same tv today and the same thing happend to me but it happend with the satellite input and i did not have the blue vertical lines i just had a black screen and sound. i unplugged the hdmi cable that carried the signal to the tv and plugged it back in and i had a picture. hope this helps
Dec 17, 2006 | Mitsubishi WD62527 62 in. LCD HDTV
Onkyo 7.2 Channel Network A/V Receiver - TX-NR737 Logo
78 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
