Question about Air Tools & Compressors
Wiring schematic for a 1971 Reuland 3 phase # Hp. electric motor for a grinder pump
I had it sent out to be rewound, now instead of 3 wires color coded I have 9 numbered wires coming out of the motor. I need a wiring schematic
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
Its going to depend on whether you are connecting to 240 volt or 440 volts...
It also depends on whether it is a 'wye' wound motor or a 'delta' wound motor.
A nine wire motor is probably a multi-voltage motor capable of running on either 240 or 440 volts. For operation on low voltage, 240 v, the windings must be connected in parallel whereas hi voltage operation makes it necessary to have the windings wired in series.
I will not give the details on the winding connections because the process to determine whether it is a 'delta' or 'wye' wound motor is too involved to derscribe on a forum. But..... if it is a 'wye' wound motor, there will be three additional wire connections 10, 11, and 12, that are wired together and under the end bell and not accessible.
We don't want to 'smoke' your motor, so let the suggestion be to contact a reputable and qualified electrician who you trust to determine what's required and to connect it without the potential for damage.
Posted on Nov 27, 2014
rayname
  • 70 Answers
SOURCE: wrong direction of rotation
swap any two leads L1 to L3 this will change rotation hope this helps a common color code is brown orange yellow in that order known as BOY at power feed you can change the wires at the disconnect load or motor side
Posted on Jan 24, 2009
  • 6 Answers
SOURCE: converting 3 phase compressor to single phase
Start w/ a single phase motor. Or maybe your question is just confuseing me.
Posted on Sep 12, 2009
  • 5603 Answers
SOURCE: have a 3 phase 7.5 HP IR compressor,want to put a
You will use two of the original three wires. Not knowing if you have a motor starter and how it is wired makes it impossible to give you details.
BE AWARE that a 7.5 HP single phase motor is going to draw a massive starting surge compared to a three phase motor. I assume this is on a 240 volt system as it would NOT be practical to use a motor that size on a 120 volt system.
Expect to require around a 30 to 50 amp single phase feed to the motor.
Posted on Dec 20, 2009
  • 509 Answers
SOURCE: I have a viking 10 hp three phase motor brand new
If your wiring the motor for low voltage you have it correct. If you want high voltage I can post a diagram.
Posted on Mar 13, 2010
seanpwright
  • 2030 Answers
SOURCE: 3 phase air compressor wrong rotation
yes it will you need to make sure you have the proper wires connected to get either clockwise or counter-clockwise rotation.
try changing the hot wires around to correct your problem
Posted on Mar 31, 2010
What would be a good replacement for a FLYGT 3152 3 phase grinder pump that uses guide rails?
you can still buy them
FLYGT 3152 3 phase grinder pump Google Search
Ads
  1. Grinder Pumps - saniflo.ca‎
    Adwww.saniflo.ca/
  • Grinder Pump Solutions, Ideal for Home Installation. Easy Install!
    Install Anywhere · No Maintenance Required
  • What's the Best Grinder Pump? - E/One Pumps Lead the Industry.‎
    Adwww.eone.com/grinder-pumps/sales-contacts
    1. Find Your Local Distributor & Get a Quote on Grinder Pumps for Your Next Project
      Proven & Reliable Pumps · Distributors Across USA · Industry Leader 45+ Years
    Search Results
    Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump 208/230V 3 ...
    https://www.sumppumpsdirect.com > Shop by Brand > Liberty Pumps US$1,363.60 - ‎In stock
    Buy Liberty Pumps LSG203M Direct. Free Shipping. Tax-Free. Check the Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump (208/230V 3-Phase) w/ 25' ...
    Grinder Pumps - Sump, Effluent and Sewage Pumps - Grainger ...
    https://www.grainger.com/category/grinder-pumps/sump...pumps/pumps/.../N-hv1 6 results - When it comes to Grinder Pumps, Grainger's got your back. ... 208/230VAC(3) .... Phase AC, Discharge NPT, Max Head - Pumps, Pump Body Material ...
    [PDF]3 Phase Simplex Control Panel Grinder & Vortex Pumps - Hydromatic
    www.hydromatic.com/resources/images/27454.pdf 3 Phase Simplex. Control Panel. Grinder & Vortex Pumps. Owner and Operational Manual. Your pump has 5 colored wires. White, Black, Red, Blue and Orange.
    Faggiolati 3 Phase Grinder Pump - Water Pumps from Pedrollo
    www.pedrollo.co.uk/pump.../Faggiolati_Three_Phase_Grinder_Pump_G271T6T1-_J... Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0. Online Catalogue ' Grinder Pumps ' Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0 ...
    Vertix 3 Phase 400T Grinder Pump - Pedrollo Distribution Ltd
    www.pedrollo.co.uk/pump-shop/.../Vertix_Three_Phase_400TGrinder_Pump.html
    Vertix Three Phase FTR400T Grinder Pump. Online Catalogue ' Grinder Pumps ' Vertix Three Phase FTR400T Grinder Pump ...
    images of other pumps that might suit you.
    Jul 04, 2017 | Grinders
    I just had my electric motor rewound. At first I had 3 wires coming out of it now I have 9 that are number coded. I need to know which wires I need to hook up. The man at the motor shop said don't use
    Apparently you have a three phase dual voltage motor. The wiring should be on the nameplate or in the junction box. You will need to know what voltage you have. There are standard wiring diagrams for three phase motors. If he rewound the motor he should have given you a diagram or there should already be one there. If he doesn't help ask for your money back.
    Nov 24, 2014 | Pool & Spa
    Is the 4A912B Dayton 10" 1 HP bench grinder 3 phase or 1 phase?
    If the plug on the cord has 2 flat prongs and one round one then its 110 VAC single phase. If the motor has 4 wires then I'd suspect 3 phase. The data plate on the motor will tell you for sure.
    Nov 19, 2014 | Bench Grinders
    How do I reverse a three phase electric motor?
    Reversing rotation of 3 phase motors:
    CAUTION: Before attempting any repair of electrical equipment verify the power is disconnected to the device.
    CAUTION: Three phase motors could potentially be controlled by frequency control systems. It is recommended a trained electrician perform repairs to any electrical system. In particular, consult a trained electrician if the system includes a frequency control system.
    Most 3 phase motors can reverse rotation simply by swapping any 2 of the 3 phase wires. A typical 3 phase wiring circuit will include a safety ground wire (usually green) and 3 phase wires, often designated A/B/C, or 1/2/3, or color coded to distinguish each. By swapping the terminal connection of any 2 of the three phase wires, for example, 1 & 2 or 2 & 3 or 1 & 3, but leaving the third phase wire unchanged will reverse the rotation of most motors.
    Jun 12, 2014 | Hayward 1.5hp Pool Pump Motor Motor A O...
    Magnetek m56j wiring schematic
    Wiring diagram will show on label on side of pump.
    High voltage and Low voltage.
    The rating has to be single-phase and not 3-phase, otherwise motor will not rotate as expected.
    Take in-focus photo of label using macro setting on digital camera, and post photo on flickr, and then add a comment with link to that photo.
    Oct 08, 2012 | Pool & Spa
    I have a Baldor 1022W grinder but i'm not sure how it is wired. I've tried looking for wiring schematics but have been unsuccessful. All I need to know is how to tell if the grinder is wired 115V...
    first off what does the plug look like? that would be one clue and also usually under the bottom plate there is a wiring breakdown. Let me know if you need more help
    May 12, 2011 | Baldor 1022w 10" Bench Grinder, 1 Hp,...
    I have a 1/3 hp motor with a capacitor. There are four motor leads coming out of motor, the capacitor is mounted in the wiring box. This motor does not have a centrifugal switch, to isolate the capacitor...
    I am in the process of replacing a capacitor on a Craftsman 6 in 1/3 grinder, 2.8 amp, single phase, 110v. Not sure on the centrifugal switch. model 319.190621, ser B9530. When I took the old one out the black wire from the capacitor went to the cluster of back wires (in my case 3) in the wire nut. The blue wire from the grinder went to red wire from the capacitor in a wire nut. Hope that helps you....
    Maybe you can help me... the specs on the capacitor burned off when it failed. Can you tell me what the capacitor specs are on yours?
    Nov 16, 2010 | Craftsman 6" Bench Grinder with Lamp
    Older sears bench grinder wont run 1/3 hp model 397 19581
    Hi again, OK, Well since I don't have a wiring diagram and the colors don't help. I am also going to assume it is 110VAC. The larger wires are probably the run or primary, it you remember which ones were connected it will help with polarizing. ( getting it to run in the right direction as well as the start and primary working together). You can use the two terminal switch but you should use a three wire cord. Use the switch to break the neutral and ground the case. The connections should be as follows: Connection 1, would have one of the primaries and one of the starts to neutral. Connection 2, the other start to the relay. Connection 3, the coil side of the relay to the remaining primary. ( if the relay has two connections on one end and one on the other it would be the single) Connection 4, the 3rd position on the relay to hot. That is how a split phase is wired. You may find a simple wiring diagram on the net if you type split phase motor wiring diagram. Good Luck to you, this should Fixya!
    Mar 04, 2009 | Grinders
    Air Tools & Compressors Logo
    113 people viewed this question
    Top Air Tools & Compressors Experts
    John Trevino
    Joe Garcia
    Joe Garcia
    Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
