What would make the fan on a furnace turn off and immediately back on while running?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
It depends on the furnace. Older ones had 'temperature initiated' and 'temperature terminated' cycling controls for the blower motor in the heat mode. Newer ones energize the blower through a tiny black or white relay soldered into a circuit board. Those types are "time initiated" and "time terminated" and it could be that the board is going a bit wonky cycling the fan relay.
As described, it just about cannot be the motor cycling on its internal winding thermostat because it has to cool down several minutes or longer before the internal overload resets. And they never fail in a way to cause the motor to do what you are saying.
Flip the thermostat's fan switch from 'auto' to the 'on' position and see if it still does it like you described above. If it does not, the relay board is most probably the culprit. The 'on' position USUALLY uses a different relay on the circuit board and USUALLY runs the blower on a higher speed. There are exceptions though.
A 'far out' possibility is a faulty wiring connection that makes and breaks the circuit due to the vibration....but that's a slim chance. After a few times, the ends of the stranded wires begin to 'arc' and melt then they rapidly become too short to come into contact.
Posted on Nov 24, 2014
  • 148 Answers
Need more info about your unit
We have a Coleman Electric Furnace Serial # AOL6042086, Model # AHP36C3XH21A and the fan runs constantly, will not shut off. We have replaced the thermostat and just replaced the control board. We h
I wish I was a furnace expert but I will give a push in the right direction. When a gas/electric fan runs it has two speeds. When you turn on the FAN ON switch it should run at the slower speed. If it doesn't turn on or turn off again when you turn it back you have a wiring problem or a thermostat problem. Make sure the thermostat is compatible with your unit and wired properly (on both ends). The other time the fan runs is "in session" when heat or cooling is applied to the system. It should run until the system finishes the cycle then a bit more (30 seconds or 1 minute) to blow the treated air completely through the ducts. If it doesn't stop then you may have a bad fan time delay or relay. Check parts for your model and various appliance repair site online.
Nov 25, 2014 | Coleman Mobile Modular Home Electric...
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
Furnace will not run when hooked up to electricity
Go to your thermostat and access the fan mode. Change the fan mode to Automatic, AU. This will stop the AC fan from blowing when the furnace is turned on. If the fan mode is on Hi or Lo and the furnace is turned on it will turn on the AC blower. Bad design...
Mar 02, 2014 | RVs
Goodman furnace GMT115-5B Turn fan to on on
Bypass the tstat first but that's where I'd be leaning.
Aug 14, 2017 | Goodman GMS90703BXA Heater
Coleman furnace -- fan runs, ingniter won't light,
The chances are that the furnace was running when the power went out. This will cause the high limit switch to cutout and needs to be manually reset.
You will find that switch in the blower compartment near the blower. Usually somewher near the highest point of the cabinet.
Push the little red button firmly till it clicks.
When the power goes out while the furnace is running the heat builds up because the blower shuts down immediately and causes this limit switch to cut out.
If you have a electric tester you can also follow the low voltage circuit till you find the open switch. Ther is usually a wiring schematic on the door cover of most furnaces.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 09, 2009 | Coleman Propane Forced Air Heater...
I have a Ruud 90 Plus Model UGRA furnace and blower starts immedi
NO BECAUSE THE BOARD IS TELLING THE FANS TO STARTARE THE CONTACTS FUSED TOGETHER OR STUCK IN THE CLOSED POSISTION CHECK THIS FIRST
Aug 10, 2009 | Heating & Cooling
Furnace blower not working how it should
first off buy yourself a honeywell stat, in my personal opinion lux stats are garbage, I have run into so many that are bad stats !!! but as far as your fan not shuting down, sounds to me like your fan center on your circuit board is bad and will not shut down the fan when needed, you will have to replace the circuit board, as the fan center is a part of the whole of the circuit board, hope that helps
Jan 19, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
