Question about Dishwashers
Electro lux Dish washer ESF 660. After finishing washing dishes the light is still on.
    Sergeant:
    Champion:
  • 282 Answers
Probably a bad or stuck timer
Posted on Nov 26, 2014
SOURCE: miele dish washer
I had the same problem only I couldn't get it to go at all. The problem was a bad motor/pump assembly (VERY EXPENSIVE). The bottom inside the dishwasher filled with water, so the intake interlock wouldn't allow new water to go in. I think I am going to throw my 4 year old, $1000 dishwasher out and buy a new one at Sears. Can't believe it is so poorly made.
Posted on Apr 30, 2008
  • 14 Answers
SOURCE: jennair dishwasher jdb8910aww
Start by puting timer in heat dry for about 4 seconds and see if element got warm. If so check you rinse aid and make sure it is full. I like the turbo dry made by jet dry. If it is empty, this is your problem. about the smell, you would use a cleaner such as diswasher magic made by GE. If element did not get warm, put unit on heat dry and and test voltage at the element. 120 volts present replace element. if not check voltage at thermal fuse for 120 volts. If no voltage there replace timer.
Posted on Jul 26, 2008
SOURCE: hotpoint dish washer aquarius
I had the same problem with my Hotpoint Aquarius the eco and fast light flashing, it would go through the pre wash cycle and stop.
I cleaned the filters etc; and it still didn’t work.
I turned the machine off and unplugged it at the mains,
I drained all the water, turned the machine on the side and took the bottom off, I removed the drain pump off the bottom (this was held on with a single screw after taking the screw out slightly turn it to one side as its like a bayonet fit on a light bulb also remove the wire connection and a rubber drain pipe)
Once the pump was removed I could clearly see the impellor it was very tight and I couldn’t spin it after a closer examination I could see a foreign object jamming it I removed this with a pair of tweezers, replaced the pump and put it all back together and it now works perfectly.
I hope this can be of some help.
Peter.
Posted on Dec 17, 2008
SOURCE: The wash light Indesit DI 67 dish washer is flashhing ?
Try pressing the start button in for 5 seconds, doing this cancells the old program and starts a new one.
Posted on Mar 11, 2010
SOURCE: GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Posted on Dec 30, 2010
My dish washer has e3 on display and does wash dishes properly
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 10, 2016 | Dishwashers
Why are dishes clean but still seem to be greasy?
hi,you can take off the washers that spin and clean them ( sometimes the holes get blocked on them ) also make sure you have salt in the machine and rinse aid
Apr 24, 2015 | Dishwashers
Dish washer the clean light stays on and the dish washer wont run
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Whirlpool Dishwashers
The cycle has finished and the dry light is on and it keeps beeping. Usually it beeps 8 times then all lights go off and cycle is finished. i ahev just filled it with salt but this has never happened...
ok why whoud you put salt in dish washer you screwed it up from doing that the salt sweld up and cloged the sencer the sencer is your intake and your intake takes water in out clean out with dish soap 1 or twice with mild water mixed with dish soap[
Feb 15, 2011 | Dishwashers
Dec 12, 2009 | Indesit 24 in. DI67 Free-standing...
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Have a trouble: dish-washer will not drain.
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Mar 21, 2007 | Electrolux 24 in. ESI6220X Free-standing...
Dishwashers Logo
63 people viewed this question
Top Dishwashers Experts
