Question about Samsung CLP-315W Laser Color Printer
I have a CLP 315 that when I print it leaves gray lines from left to right on the paper. Any ideas?
Replaced the black cartridge.
  • 186 Answers
Sounds like an imaging unit problem. You need to replace your drum unit.
Mike Computer Shop
Posted on Nov 24, 2014
  • 11 Answers
SOURCE: Samsung CLP-315 eats toner. Cartridges last almost
ean_inkrefills on ebay. Search on the terms "samsung clp 315 toner refill solution". Chip installs on the printer motherboard--installation is not overly difficult, but still not for the faint-hearted. I expect it voids the printer warranty. Ean gives good email support.
Posted on Aug 17, 2009
Lin0
  • 6 Answers
SOURCE: how to refill toner cartridge for Samsung CLP-315
Yeah actually theres "something" about this particular toner cartridges...check this out: http://sites.google.com/site/refillinstruction/Home/clp-310-refill
Posted on Dec 19, 2009
  • 7 Answers
SOURCE: My CLP-350 Samsung printer only prints black ink
Here is my solution, hope it will solve your problem.
From your post, I believe your CLP-350N printer has enough black toner. The black cartridge is on the far right side of the printer, so the black toner is harder to go to left side of the roller than right side. Everytime we start the printer, it will move some toner of each color to the roller before it shows ready to print.
Because we always use B&W printing when we start the printer, but less Color printing. The result is there are always enough toner on the 3 color rollers, but the black toner is lean on the black roller. When this gets worse, the left side of the black roller may hardly get any toner at all -- so it only print black on the right side fo paper.
Step by step solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.(Hold the printer button for 3-5 seconds, it will print the test page.)
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Posted on Feb 10, 2010
  • 670 Answers
SOURCE: Hi. My Samsung CLP 300 Laser is playing up. It
The problem you are experiencing is a common problem with this printer. What happens is over time as the printer is used, toner or developer builds up a film on the developer blades. The developer blades meter the amount of toner that the printer puts on the paper to make the image. As the film builds up, less and less toner makes it to the page causing the image to become faint. The black developer blade probally is clogged.
This can be fixed two ways. The easiest and most expensive is to buy a new imaging unit for about $100+. The second is to disassemble your imaging unit and clean the developer blade(s). This can be done in about 30 minutes. I have posted instructions in my Tips section.
Posted on Feb 20, 2010
  • 11 Answers
SOURCE: my samsung clp-315w prints smudgy black lines
Cleaning my unit resulted in the solution of this problem. I removed the toner cartridges, the imaging unit, and the waste bin, opened the back door as well, and blew it out with "canned air". This will not solve all problems, but it is the right place to start. be careful to keep the imaging unit out of bright light when you you have it out of the printer.
Posted on Mar 21, 2010
I have a Samsung CLP 315 color printer that when I print it leaves a gray shadow line from left to right
if it is only one color that cartridge is probly bad. if it were all the colors then it would be somethinfg else. i would try a new black cartridge
Nov 24, 2014 | Samsung CLP-315W Laser Color Printer
Changing printer mode from color to black
Dear You can print only gray scale. Go to printer and fax setting-right click on printer icon-go to-printing preference-click on graphic- in color mode choose gray scale- then click on apply.
Thanks.
Oct 29, 2014 | Samsung CLP 315 Laser Printer
My CLP 315: starts printing, but paper jams every time. It's prints fine on the top half of the page, then gets blurry and will not exit printer. I have to turn off/on to get the page out. I...
at the fuser unit. thes is the part were the printer get very hot with a red and gray roller.
look in th sid of it you will find a sensor . you need to replace it
Jul 24, 2011 | Samsung CLP 315 Laser Printer
Why is red light on samsung clp- 315 and it is not printing
Does one of these situations apply to you?
The Status LED light is Red and the Toner lights are OFF (Check Smart Panel for message)
  • A Paper Jam has occurred.
  • The Front, Top, or Back Cover is open.
  • There is no paper in the Paper Tray.
  • There is a problem with the Waste Toner container.
  • A major error has occured.
The Status LED light is Blinking/Flashing Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Can still be used to print, but quality is unreliable)
The Status LED light is Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Printing is not available)
  • The Toner cartridge(s) are not installed properly.
Source: samsung troubleshooting guide for CLP-315
Sep 25, 2010 | Samsung CLP 315 Laser Printer
Samsung CLP-315 colour laser printer - is it true that you cannot print only with the black toner cartridge, if one or more of the colour cartridges is empty? I only need to print black!
Yes, it is true that most of Color printers will not allow you to print document if one or more of the recommended Cartridge of the printer is empty or removed from the printer. for printing only black, the better option will be to change your printer settings while printing a document. ex: when on a document ,and your press Ctrl+P for document printing, there is a option where you can select print color as black and the printer will print your document in Black only.
Feb 05, 2010 | Samsung CLP 315 Laser Printer
My samsung 315 clp has status LED red light on.
It is a color laser printer.it has 4 toner cartridge(1)black(2)magenta(3)cyan(4)yellow all cartridge is missing or toner finished.Please purchase full set toner.All toner cartridge has a image sensor.When toner is run out then it is out of work.
Dec 14, 2009 | Samsung CLP 315 Laser Printer
My samsung clp-315w prints smudgy black lines
Dec 06, 2009 | Samsung CLP 315 Laser Printer
Refill clp-315
No need to drill holes. If you turn the cartridge with the drum facing away from you, on the left hand side, you should see a small block elliptical cover with a couple of divider on it. That is the cover for filling the cartridge. The problem is there is no available reset chip yet for clp-315.
Feb 21, 2009 | Samsung CLP 315 Laser Printer
Samsung CLP-315W Laser Color Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
