Kenwood washing machine kmw 5072faf error e05
    Problem Solver:
  • 11 Answers
Have you checked the machine's manual.. It should tell you what the code means in which case you will know where to look.. If no manual, download one through Google or direct from Kenwood (manufacturer).
Posted on Nov 27, 2014
2 Suggested Answers
sodeep
  • 3267 Answers
SOURCE: Hi i have candy go washing machine it shows error
E05 indicates that the pressure switch is stuck on full, this may be that your pump is jammed or blocked. Remove the filter and clean it out, also try to fish around in the tube that leads up to the drum. If this doe snot remedy the fault have it repaired by an engineer or someone whom has a rudimentary understanding of the mechanics of a washing machine.
Posted on Jan 08, 2011
I have a hoover vhd 9163zd with error code E05,what component does it refer to being at fault,where is the component located
Error Code 05 is a NTC fault, either open circuit or shorted.
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "E05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component. It could be the sensor or the temperature control module (NTC module).
Good luck.
Apr 20, 2015 | Hoover Washing Machines
I have kenwood Washing machine kmw5072 faf it's showing error E05.
This error means the pressure switch is stuck.
Most likely the pump is jammed.
Clean out the filter and tube under the drum.
Nov 27, 2014 | Washing Machines
Candy error code e05
The error code E05 means the temperature sensor has gone bad.
Aug 24, 2014 | Candy Washing Machines
E05 error kenwood kdc-w7027
Sounds like your laser is dirty or faulty. Try a cleaning CD.
Dec 10, 2013 | Computers & Internet
Maytag Maxima E05 & F06 error codes on washer
My F06 E05 error returns within a moment of clearing all errors. My Maxima has no tach line from the M to the MCU. MCU commo fault is a different error. So does anyone except Maytag really know what this error is? And Maytag only wants to send a service guy to bleed some money from you.
Oct 21, 2013 | Maytag Washing Machines
I have a Hoover H160i that is coming up with E05 error. Any ideas?
Thank you. I ran a 2 and 3 wash (60 and 40 degree wash). It allowed me to put it onto a rinse/spin/cycle but it didn't allow the wash.
Nov 28, 2012 | Hoover H160I Front Load Washer
Hi i have candy go washing machine it shows error cond e05 What to do?
Jan 08, 2011 | Candy GOY105 Front Load Washer
Hoover oph 714d optima 7kg washing machine fault code e05
Hi
Error code e005 means the temperature sensor has gone bad. To fix this error you'll need to replace the temperature sensor. It might have happened that the temperature sensor wires have been disconnected from the main board. To replace the temperature sensor you'll need to disassemble the washer and inspect the drum's bottom for the temperature sensor. Also check the wires coming to the sensor fro any cut.
Please post back for any further assistance.
Daniel
Aug 01, 2010 | Washing Machines
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
