What is the code for remote control. I have to change to numeric. 24" TVGPX modelTD2420AB
To go to numeric. I don't know what to do
    Champion:
  • 209 Answers
Unless you have the original instructions, you may have to call the manufacturer to obtain it; or google it.
Posted on Nov 24, 2014
2 Suggested Answers
SOURCE: I can't find my tv
los c?digos en los controles universales son distintos para cada control .- o sea cada control trae sus propios c?digos no son los mismos o sea no es la tv la que trae el c?digo es el control remoto universal.-para el caso de ese TV RCA si es del a?o 2007 en adelante pruebe con el sistema CODE SEARCH O SEA BUSCANDO EL C?DIGO DE LA MANERA SCANER.Para el caso del control universal  RCA oprima el bot?n code search y su?ltelo hasta que la luz roja encienda luego oprima la tecla TV y su?ltela luego presione y suelte la tecla power varias veces hasta que la TV se apague .- una vez se apague oprima la tecla enter y la luz roja se va a apagar . listo su control esta pagado.-    suerte y cualquier duda comun?quese con migo a  :   roro8228@hotmail.com
Posted on Mar 29, 2011
Agk 10133
Some times the remote you have no set-up codes to none of these devices. http://electrohelponline.blogspot.com/. Check this link, and try some other codes to your devices. Wish you sucess.
Jun 10, 2013 | Universal Remote Control Televison & Video
The number 2 remote control do not work the remote
ramoshummer,
I would need more information to provide you a specific resolution, but below I have included basic steps to programming your remote to both your TV and your DISH Network receiver.
Link for codes if needed: http://www.dishnetwork.com/SupportSection/remote-setup
Addressing Remote to TV:
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if working.
5.) If no function, repeat steps 1-4 with another code.
Addressing Remote to Receiver:
1.) Go to System Info screen.
2.) Hold down the SAT button until all mode lights light up.
3.) Enter a number between 1 and 15 using the numeric keypad on the remote.
4.) Press the pound (#) button.
5.) Once the SAT button blinks three times, press record.
6.) Test remote and see if works.
If those don't solve your problem or you're experiencing a different issue let me know here or at thomas.faust@dishnetwork.com and I will check it out!
Tommy Faust
DISH Network
Sep 08, 2011 | DISH Network IR Remote Control
I accidentally changed the command code from dvd3 to dvd1 and now my remote doesn't work, and I don't know how to access the systems menu to change it back.
Since unit has been set on DVD1 remote mode so you need to set remote control itself on dvd1 mode to communicate with unit.
Press and hold Enter and 1 numeric key on remote control for 5 seconds, this will change remote control to dvd1 mode, now unit will accept remote control signal and you can operate it normally.
Thanks.
Jan 02, 2011 | Sony RDR-VX535 Player
I have a classic IRC81587 universal remote control and i dont know how to tune it in to tv it is a baird flatscreen can you help please kind regards irene mcdonald
1. Hold down the TV/Tuner Button.
2. Whilst holding down the TV/Tuner Button, enter the four character numeric device code.
3. Press any other button on the remote.
NB: If the remote was sold to you under the guise of being " the correct remote control for that model," then simply remove the battery cover and you will see that the correct code for your device has been helpfully printed there. If you do not know the code for your particular device, these can be found on numerous websites, or in your TV manual.
Aug 21, 2010 | Televison & Video
I have a tv remote control Classic irc 81469 and i have lost the instructions manual. Can somebody help me in order to sintonize it with my tv
NB: If the remote was sold to you under the guise of being " the correct remote control for that model," then simply remove the battery cover and you will see that the correct code for your device has been helpfully printed there. If you do not know the code for your particular device, these can be found on numerous websites.
Jun 30, 2010 | Televison & Video
BOUGHT A REMOTE THAT I DONT NO HOW 2 USE
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating as thats how we get paid.
Apr 29, 2009 | Jensen JR500 Remote Control
Sky + Remote wont change volume or mute after buying a new tv.
I have since found the code. 206 worked straight away which I hear is good as some people have to try numerous codes before it works. You press tv, press select and red button simultaneously for a couple of secs until the red remote light blinks, then press 206 and finally, select to save. This worked for me so hope it helps anyone else.
Jan 24, 2009 | Microsoft Windows XP Media Center Edition...
Parental control
According to the user manual you should be able to clear the code by unplugging the TV and wait about 30 minutes.
The manual is available here.
http://www.usersmanualguide.com/funai/television/dwt2405
Aug 31, 2008 | Durabrand DWT2405 24" TV
Code Problem with a kenwood kdc-mp232 car audio
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Dec 03, 2007 | Kenwood KDC-MP232 CD Player
Kenwood MP4029 4 code reset
Type 1
Type 2
Type 3
Oct 13, 2007 | Kenwood KDC-MP228 CD Player
Televison & Video Logo
Top Televison & Video Experts
