Question about PLANET Audio P9740 7 Touch Screen Dvd Cd Mp3 Usb Sd Aux Car Video
No power to touch screen on planet audio p9740
How can i get rid of the blue screen that says cant play while driving on my planet audio p9740 monitor DVD
Connect the Parking brake wire to a ground source; either permanent chassis or with a toggle switch.
Mar 04, 2013 | Car Audio & Video
How to display clock on a planet audio p9745b
bummer - cant find any manuals online about this receiver. Maybe hold down the volume down and see if the option becomes available?
Jan 03, 2013 | Planet Audio P9745B / P9740 Car Video...
Planet audio p9740 user's manual
how do I transfer my pic off my digital camera sd card into my p9740 I put the card inside it read it but I can't program the pic to choose one as my screen saver...do u have a solution?
Mar 13, 2012 | Planet Audio P9745B / P9740 Car Video...
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
I was hooking my Planet Audio P9745B up in my 2000 Honda Accord and it said Warning Video something so it wouldn't show but you could hear the movie and then it showed up on the screen. So i put everything...
Sounds like there could be a shorted wire possibly power but what sounds like happened is the unit grounded out and blew the cigarette lighter fuse. Check fuse box for blown fuse, if this is the case I would suggest pulling radio out and having the wire harness for the radio professionally connected and inspect all connections
Aug 23, 2017 | Planet Audio P9745B / P9740 Car Video...
Red protection light
make sure amp is not grounded out or shorted out like if u miss and touch ground to power or the other way around protect light usaully comes on be resets once u turn the amp power off then back on . if that don't fix it maybe ur amp needs some repairs inside.
Jun 06, 2010 | Planet Audio VX4002 Car Audio Amplifier
Planet audio vx3002
Sorry wayne2953 but this amplifier isn't stable @ 1ohm loads. This amplifier would be better suited running a pair of 12's, 4 12" subs could run if configured correctly but the subs would be underpowered and probably not sound very good.
Features of Planet Audio VX3002:
  • Max Power (2 Ohms) : 300W x 2
  • RMS Power (4 Ohms) : 150W x 2
  • Bridged Power (4 Ohms) : 600W x 1
  • Signal-to-Noise Ratio : 102dB
  • Frequency Response : 20Hz-20kHz
  • Dimensions : 10-5/8"W x 2-7/16"H x 16"L
Mar 31, 2008 | Planet Audio VX3002 Car Audio Amplifier
PLANET Audio P9740 7 Touch Screen Dvd Cd Mp3 Usb Sd Aux Car Video Logo
Top PLANET Toys Experts
Andrew Taylor
Andrew Taylor
Are you a PLANET Toy Expert? Answer questions, earn points and help others
