Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
When switching on the screen has horizontal lines and doubles and stretches on left of screen goes to normal after 20 mins
  • Jim Dunn
    Jim Dunn Nov 25, 2014
    Faulty capacitor is not getting power surge for initial start
    Top Expert:
  • Sony Master
  • 74,383 Answers
Fault with the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Nov 25, 2014
  • 668 Answers
SOURCE: line thru screen
The LCD Panel must be replaced to fix both problems. The cost in doing this would exceed the value of the set. I recommend not putting the money into it.
Skyassoc
Posted on Nov 25, 2009
  • 4 Answers
SOURCE: When we turn on our tv in the morning the left
Call Sony my friend. I have the same exact issue with the same model. They already have a recall for the 46"XBR4. Let Sony know that us 52" owners are having the same issue. I'm essentially calling them everyday until they fix it.
Posted on Mar 31, 2010
eagle338
  • 4889 Answers
SOURCE: Have Sony model TV KDL46S4100
The picture becoming normal after a while indicates that its a capacitor related issue. Apparently they are taking too long for the charge/discharge cycle to become normal(due to loss of electrolyte). The source of the problem is most likely to be the LCD control board or the mainboard. You should look for capacitors that are bulged at the top, cracked or have tiny holes at the top. If you want to do it yourself then have a look and let me know.
Posted on Oct 25, 2010
  • 8457 Answers
SOURCE: #1 tv has black
The tv board that called a T-CON board it is dying to causes these problems.All the tv pictures dots pixel codes go through this board before it show up onto the tv LCD sreen panel.This tv T-CON decodering board sit in the midle at the bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.
Posted on Sep 04, 2011
  • 46 Answers
SOURCE: lines in right side of screen
You have a board connected on the side and another on top.. the board controls your horisontal lines and your side board controls your vertical.. Afte using the television for some time the board gets very hot and the solder gets damaged. You get what is called cold solder preventing the electrical current to pass. You need to retouch with solder but do it carefully. its best if you know some one with soldering experience. That will solve your problem. you can get more details at www.bestdirectorysolutions.com
Posted on Mar 01, 2012
After 10 to 20 mins left half of screen goes to white vert lines
Sounds like power supply regulator board fault. Check all the electrolytic capacitors for any leaked or bulged one. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Jul 01, 2014 | Samsung LN32D450G1D 32 LCD TV
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Desktop icons stretched horizontally
Sounds like you need to set the screen resolution for the monitor. The computer should recognize each screen individually in the desktop options dialog. If it doesn't recognize the two different screens, you may want to change the resolution when you plug in the monitor.
May 14, 2017 | Computers & Internet
Acer AL2216WBD LCD Monitor Problem
If your computer does not have a video card that supports the correct resolutions for the widescreen monitors, then your picture may get stretched. Much like watching normal tv programs on a an hd set. It will eitther strech or cut off the picture.
Try different settings in you computer display settings.
Fran
Sep 09, 2008 | Acer AL2216WBD LCD Monitor
Picture on 42HDX82 vertically stretchs after about 10 mins
Sounds like a bad cap, spray some freeze around till you can duplicate the problem.
Oct 22, 2007 | Toshiba 42HDX82 42" Rear Projection...
Picture goes to one thin horizontal line in middle of screen
There is a bad solder connection in the vertical sweep circuit. if you know how toi solder, go and find the vertical output IC and resolder that first.. but if you have no solid state electronic repair experience, please find a trained tech to assist you in this repair, as if you wait it may end up costing you double of what it would now, so haveit done ASAP. Good Luck Please do not forget to rate this one.
Oct 16, 2006 | Sanyo DS24205 24" TV
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
67 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
