Question about Samsung Microwave Ovens
SMH9207ST Samsung microwave. Hit the start button,relays click, light turns on but won't heat and plate won't turn no cooling fan either.
Resetting would help at first but now it never works.
    Top Expert:
  • Samsung Master
  • 25,695 Answers
Internal fuse blown due to faulty door switches.
Posted on Nov 24, 2014
  • Brett Dean
    Brett Dean Nov 24, 2014
    Ohm'd both 250V 20A fuses. Both OK.
heatman101
  • 43501 Answers
SOURCE: My microwave intermittently (1) hums but
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ][
Posted on Aug 13, 2011
caroldon
  • 17130 Answers
SOURCE: My microwave won't heat anything
Since the light and fan work the main board or the processor is working .Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
As there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Thank You for using FIXYA.
Posted on Sep 17, 2011
walesarumi
  • 6993 Answers
SOURCE: My microwave oven isn't heating my food.
Investigate these three areas if your microwave won't heat
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
Testing a diode
NOTE: Before you test your diode, make sure your microwave is unplugged, and that you discharge the microwave's capacitor.
Whether it is shorted or open, a defective diode will most likely show some sign of defect. Defective diodes will usually emit an electrical burning smell, signifying its defectiveness. Also, it may have split in two, or it may exhibit a burned crack, or possibly even a blistered spot.
A shorted diode is indicated by a loud humming noise from the high voltage transformer, and no heat produced when a cook cycle is initiated. Whereas little or no heat produced in your microwave, with an absence of a humming noise is indicative of an open diode. In either case, the diode has to be replaced.
With your microwave unplugged, and your capacitor discharged, use extreme caution to remove the lead that leads to the capacitor. You can leave the ground connection attached. The side of the diode that goes to the ground is usually marked with a dot, stripe, or arrow. Set your ohmmeter to R x 10,000 or higher. Touch the positive meter probe to the anode and the negative meter probe to the cathode to measure the resistance across the diode terminals. Remember that the cathode is on the side that goes to the ground, which is often marked by a dot, stripe, or an arrow.
A normal diode, that is a non-defective diode, will read anywhere from 50,000 to 200,000 ohms. Differences in microwave make and model account for this large range in resistance readings.
Reverse the meter probes and measure resistance while touching the positive probe to the cathode and the negative probe to the anode. Reversing the probes like this should result in a reading of infinity. Unless a bleeder resistor is present. The presence of a bleeder resistor would produce a reading of the value of the resistor.
High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating. Test your microwave's magnetron. Replace it if it is defective.
Testing a magnetron
NOTE: Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitor.
There are two tests to conduct in order to determine whether or not a magnetron has become defective. If you receive results other than what are detailed below, you will have to replace your microwave's magnetron. Each test is described for you here:
TEST 1: Locate your magnetron and label each of the wires attached to it so that you know which wires are to be replaced where. Set your ohmmeter to the lowest resistance scale. Take a resistance measurement between each of the magnetron's terminals by touching each probe to one terminal each. Reverse the probes and take a second resistance measurement. Each measurement should read less than one ohm.
TEST 2: Set your ohmmeter to its highest resistance scale. Touch one of the meter's probes to a magnetron terminal. Touch the other probe to the metal magnetron housing. Take special caution to not touch the two probes together. This could result in an inaccurate reading. This test should produce a reading of infinity - indicating an open circuit.
Read the tips on the below links on how to replace your microwave oven's diode and how to discharge the capacitor.
http://www.fixya.com/support/r7088355-replace_microwave_ovens_diode
http://www.fixya.com/support/r7088317-discharge_microwave_ovens_capacitor
I hope the above is helpful.
Regards.
Posted on Nov 11, 2011
ercupa190
  • 12223 Answers
SOURCE: Goldstar Over the Range Microwave won't heat any food. Fan & everything works.
see this cuases and fix it. God bless you
Microwave Runs, but no Heat OK, get ready, this micrwave oven repair can take some time. This is where you must be able to read a wiring diagram and do some "live" checks on parts. First easy check is to make sure power is coming off your control board at the MW relay. Make sure of the wires and test here, if you have 120 volts at this point, you have ruled out a lot of parts that could be the problem. You have now ruled out any switch problems, control board problems, or a thermostat or 2.
If you do not have power from that MW relay on the control board, you must trace the wiring back to see if the proper voltage is going through your switches, any thermostats, and arriving at your control board. Your wiring diagram on your sheet will show you where and what to test. Below is a general switch test troubleshooting guide.
mwswitchtest.jpg mwswitchtest2.jpg If the proper voltage is coming into your control board and you are not getting voltage at the MW relay, then you need to replace the control board. If voltage is interupted by a thermostat or switch from your testing to the control board, then replace that part.Now, testing from the MW relay on to your transformer, high voltage capacitor, magnetron, and diode. Do not do any voltage reading from the secondary side of the transformer on, this can be a deadly microwave oven repair if you do not follow directions. This can result in electrocution and the "blowing-up" of your voltmeter, only do OHM testing with the power off and the capacitor discharged. Someplace in this circuit, usually before the transformer, you will have another thermostat to test. It is usually mounted on the magnetron. Do a quick OHM test to see if it is open or closed.
Now to test either the transformer, high voltage capicitor, magnetron, and diode, you must test each part separately. A good rule of thumb, if your capacitor is bad, change the diode also. Another note, if you are working on an OTR model and you have determined to be one of these "heating" circuit parts, you can not test these parts until you take the unit down. If you don't have the parts with you and you have to order them, order the magnetron, capacitor and diode and you will have a 90% chance of solving the problem. If it is an older microwave, order the thermostat also, most times you can return un-used, un-opened parts. Check with your parts supplier. This way you only have to take the unit down once.
To test these parts, scroll down this page and you will see a chart with component tests. Follow the instructions to find which part(s) are defective in your microwave oven repair.
Posted on Oct 11, 2012
  • 10 Answers
SOURCE: My Russell Hobbs RHM2020 microwave lights up plate turns ect but the food won't heat up
replace or rewind the transformer.
Posted on Nov 02, 2012
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
My fan for the stove reduces power once the microwave is turned on
you must understand that any manufacturer has the proper design engineering from to save electricity, etc. And they using the new concept of reingeenering.
If the microwaves do not HEAT and working, do not worry.
Mar 06, 2013 | Microwave Ovens
My samsung SMH1611B Microwave Oven does not heat
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
These answers will help me judge whether it's in the high voltage section (magnetron, transformer, or diode) or the control section (door switch or control board relay or connection).
Please reply back with your brand and full model number from the tag so we can help you properly.
Mar 02, 2013 | Samsung SMH1611W Microwave Oven
How do I stop the vent fan on my Amana OTR microwave (AMV1162AAW)
see the block diagram, unppluged the machine, and disconnect only 1 wires or 2 wires and wrapping with electric tape individual.
However I will NOT recommend to do this, because the fan cool the magnetron, that emite radiation for heating the foods.
God bless you
Aug 01, 2012 | Amana AMV5164 Microwave Oven
Microwave lights, clock, and everything works except when you press start, it just counts down like its cooking, but the microwave is actually not on. No hum as usual or plate rotating. It just counts...
Hi, one of the most common reasons why the turntable won't rotate is that the microwave isn't clean. The turntable guide and carousel can get sticky, preventing the turntable from properly moving. If you have built-on food particles or liquids, fill a bowl with 2 or 3 cups of water and 1 tsp. of liquid detergent and lemon. Run the microwave for about 3 minutes. Clean the microwave with a cloth, including the base of the turntable, guide, carousel grooves and microwave base. Your microwave turntable won't rotate if the grooves on the base of the turntable do not sit right on the carousel. Also, check the position of the turntable guide. Place the guide directly under the turntable. Remove the turntable, and then reposition it into the carousel grooves.
Motor The carousel motor is located beneath the base plate of the microwave. If the carousel isn't turning at all, check the motor. Disconnect the microwave from the power source, and remove the turntable, guide and base plate. Try turning the motor to see if it's just stuck. If it doesn't turn freely after a few seconds, examine the motor to see if it's burned out or corroded. Use an ohmmeter to see if the motor has continuity. If not, you must replace the motor.
Bushings The drive bushings are plastic components that sit underneath the cooking plate. Remove the plate, and examine the bushings. Use a magnifying glass if necessary to see if any debris is caught in the plastic. Clean the bushings, and reinsert the plate. Turn the microwave on to see if it rotates. If the bushings are extremely worn or if some of the plastic is broken off, you need to replace it, which is a complicated repair for consumers. Contact a service technician for assistance.
May 07, 2011 | Amana Radarange Microwave Oven
My samsung microwave oven is not heating up food. It works normally, lights on, food turning on plate, but not heating the food.
if your microwave does everything you have described , and you can hear the cooling fan running as well after you press the start button , you probably have a faulty wave guide. The wave guide is also called a Magnetron Tube. It is the main part of the microwave which produces the microwave energy . If this part is not functioning it is best to replace the entire unit, rather than have it repaired .
Oct 03, 2010 | Samsung Microwave Ovens
Microwave Ovens Logo
206 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
