I have a Panasonic TC-P42s30 and while watching tv one day the picture turned to the attached photo. The color boxes move around the screen. Any ideas?
    New Friend:
  • 76 Answers
Screen saver mode?
Posted on Nov 25, 2014
trintek
  • 111 Answers
SOURCE: panasonic tv TC-26LX60 PICTURE PROBLEM
if this is under warranty still, i would take it to a service center or rma it to panasonic.. if it is not under warranty, you can try the following.
1) try a different video source and verify the problem is happening on all video sources and modes.
2.a) if the problem is not happening in all modes, remove and replace the cable that is causing the issue. if this doesn't remedy the problem, the controller for that particular input is going out
2.b) if the problem is happening in all modes, you can open the case and carefully disconnect and clean (de-oxit or rid-ox) the hirose style connectors on the back of the display panel.
3) disconnect and clean all ribbon cables around the display panel
this sounds like either the connectors are not performing adequately or are loose, the top ribbon is acting up for some reason, or the graphic controller is going out.
Posted on Nov 15, 2007
SOURCE: Can I set up tv remote to also control cable box?
Just bought a Vizio 22" 1080 p TV and need to set up a Verizon Fios remote for it. The codes for Vizio for the remote do not work. Can anyone help me with this.
Steve
Posted on Jan 14, 2009
  • 267 Answers
SOURCE: Black screen with colored vertical lines
YPU HAVE A BAD PANEL. THE COST OF REPAIR WILL PROBABLY EXCEED THE VALUE OF THE SET.
Posted on Mar 20, 2009
  • 8457 Answers
SOURCE: No picture just sound.
Ur video ic inverter board is dying about to be dead.U need a new video ic inverter board.
Posted on Aug 25, 2009
SOURCE: P42W46X Zenith Plasma - No Picture - Mostly Yellow on screen
Mine looks like too, but the line running across isn't on my set, picture looks like this, and the sound works fine. I took the tuner board all the way out and turned the set on and it did the same thing, then I unplugged the top wire on the board next to the tuner board and the screen went black. plugged it back in and the screen came back with the scrambled picture. Anyone know why? Bad mainboard maybe? the left of the tuner board?
Posted on Jun 14, 2010
Hello, I had lightning strike very close to my house and now my hdmi ports arent working for my panasonic tc-p42s30. Is there a part i can replace to fix it? Thank you
Try a reset to factory default and then setup from scratch before anything else.
Can I suggest that you obtain a quality surge protector..
If the reset is no good please repost. Also, turn the power off for all devices attached to the tv for a few minutes before attempting the reset.
Jun 13, 2016 | Panasonic Televison & Video
I have a Panasonic Plasma TV that will not turn on. If you try to turn it on the red power button lights up on the TV but there's no picture. When I try to turn the power off the TV does not respond.
You have a burned out main circuit board most likely. The best thing to do is forget the repair and just buy a new one, the cost of flat screens is less than the repair costs in many cases. If you do decide to repair it remember the rest of the parts are getting ready to fail as well.
Jun 07, 2016 | Panasonic Televison & Video
Why does Q441 on SU V sus board run hot? Shuts off after 15 minutes.
Has to chek the voltages on the board if they are exact and what piece around is defect. Or change the board.
Serge.
Mar 01, 2016 | Panasonic TC-P42S30 TC-P42S30 42"" Plasma...
I have a problem with my Panasonic viera TV model TC-P42S30. The TV shows the power light but the screen is not turning on I am not sure what it could be.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window".
Aug 19, 2015 | Panasonic Televison & Video
TC-P42S30
Very Carefully. If you have any screws left over when done...start over.
Sep 05, 2014 | Panasonic TC-P42S30 Plasma TV, 42 Class -...
Panasonic Plasma TV, Model #TC-P42S30 ourchased in May, 2011 stuck in shutdown mode with 14 blinks
My nook won't show the picture I just have the sound what would cause this?
Jan 07, 2014 | Televison & Video
Panasonic TC-P42S30 plasma power light on black screen no sound?
Main digital board should be troubleshooted. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center
Mar 09, 2013 | Panasonic Viera Tc-p42s30 42" Plasma Tv -...
Panasonic TC-P42S30 power light on but black screen
It is likely that there is a power supply problem
Mar 01, 2013 | Panasonic 42 TCP42S30 42 Plasma TV
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
