Question about Hotpoint Washing Machines
How do I stop my Hotpoint washing machine WMF740 which has been going for 7hours and is stuck on 1 minute
I switched it off at the power supply for 30 minutes switched it back on and 1 hour later its still going
    New Friend:
  • 76 Answers
Is there a way to manually advance the cycle or is it all digital control panel? Do you see a reset button anywhere? Check the link I'm sending you on the manual.
Hotpoint Washing Machine Instructions For Use ManualsOnline com
Posted on Nov 25, 2014
  • 662 Answers
SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your pump/filter is plugged. (E4) There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. Use a plastic bag to catch this or a small pan.(later models have a drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. Remove it, clean out, screw the black connector back in. You can check with rinse, if you want to make sure there are no leaks. Put the door back on and rotate. I will try to come back to you re. the wash, wash.
Pl rate me 'very helpful' for the free help, thanks!
Posted on Jun 17, 2010
SOURCE: Hotpoint WF865 Drum getting stuck?
I THINK IT MUST BE A LOOSE COIN,STUCK IN MOTOR
Posted on Feb 08, 2007
SOURCE: Hoover 1300 washing machine
any reason why my hoover 1300 washing machine is so noisy when doing the final spin?
Posted on Jan 03, 2008
  • 10 Answers
SOURCE: Machine keeps tripping the fuse at the fuse box - WD61 Aquarius Hotpoint
it might be too small of a fuse for your machine
Posted on Feb 12, 2008
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
Posted on Sep 13, 2009
Washing machine not selecting cycles. It is stuck on fast wash, dial moves but wont click and select any other cycle.
Hi
the problem is the shaft on the control knob
is cracked so the knob turns but won't grip
the shaft on the control panel
requires an new knob
Jun 06, 2016 | Hotpoint Washing Machines
Washing machine Hotpoint Aquarius WMF740
Its normal for the door not to open with water in the machine this is a safety feature the door will not open immediately after the wash cycle completes their is a delay before it can be opened.
May 04, 2015 | Washing Machines
HI! I HAVE A MESSAGE ON MY HOTPOINT WMF760P WASHING MACHINE OF ' DOOR ' COMING UP & IT'S STOPPING SHORT OF THE WASH CYCLE & THEN YOU CAN HEAR THE LOCK MECHANISM
http://www.ebay.co.uk/itm/HOTPOINT-WMD9692-WMF520-WMF540-WMF560-WMF720-WMF740-DOOR-INTERLOCK-SWITCH-/390558604486?pt=UK_Irons_Presses&hash=item5aef1b5cc6
you need one of these
take the lid off and open the door
isolate the mains supply and water supply
remove the two screws that secure the interlock
this is what the doors catch sits in
reach down and tilt slide it out
remove the plug
plug in the new one
and remount
screw back in the two screws hand tight avoid stripping the plastic
and return the lid in position
now reconnect the water and mains and test
the door closes and the machine should now work aok
did one the other day
Dec 08, 2014 | Hotpoint Washing Machines
I have just bought a hotpoint aqaurius washing machine model no. WMF740. THe power to it is o.k. but when I press the power button the machine does not light up. Can you help
MOST WASHING MACHINES HAVE A SWITCH ON THE DOOR , WHEN THE DOOR IS CLOSED THE SWITCH ACTIVATES OR TURNS ON THE WASHER. THIS IS A SAFETY TYPE SWITCH TO PREVENT IT FROM RUNNING WITH THE DOOR OPEN. CHECK THIS SWITCH TO SEE IF IT IS LOSE OR NEEDS ADJUSTING. IF THIS DOES NOT FIX THE PROBLEM, THERE THEN MAY BE A SENSOR OR OTHER SWITCH THAT NEEDS REPLACING. THIS WILL REQUIRE AN APPLIANCE REPAIR MAN TO REPLACE THE SWITCH OR SENSOR. - - SORRY
Feb 20, 2011 | Hotpoint Washing Machines
My Hotpoint WMF740 washing machine is displaying a 'door' error message. The machine started to make a funny noise and then stopped approx. 15 minutes from the end of a 1 hour cycle. The door opens alright...
it very well is the door switch might be stuck. The way to unstick it is to slam the door. Very often it'll jar the switch loose if that doesn't work you'll need to order one. Easy to install there are youtube videos on it. If you need the part...try here...repairclinic.com or appliancepartspro.com.
Hope this info helps a little.
Jan 04, 2018 | Hotpoint RGB745 Gas Kitchen Range
My aquarius wmf740 has a blockage cannot undo the white water release valve on front bottom right hand side of washer to solve problem. Any help grateful.
tip machine right back and unscrew valve. It is probably caught on something. Hope this helps ( I had a kirby stuck in mine)
Audrey
May 21, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
The machine won't start as saying door isn't
1.the door may be worn at the point it presses the switch at 2.the door switch may be wired incorrectly 3.the door switch may be worn out and needs to be replaced
Mar 06, 2010 | Washing Machines
Washing Machines Logo
288 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
