Question about Refrigerators
Need wiring diagram for whirilpool refrigerator
Need to know if unit is continuous run or cumulative compressor run and if version 1 or 2
the dr
  • 447 Answers
SOURCE: low voltage at compressor!
My parts lookup too has no images available for you refrig but i believe it to be a GE Profile with a fresh food fan (and air duct down the center of the fresh food side). All fan motors are 12vdc and run off the Lowvoltage side of motherboard. i assume you are checking voltage to comp from motherboard? How did you check relay?? Have you axcessed motherboard?? On the top of (I say top-- i belive its mounted horiz on yours but all the small wires are on the right) is all the low voltage fan motor, damper, control wiring On the bottom (or the left) side of the motherboard is the larger line voltage wiring. The connector with 3 wires is labeled def -- comp---line it should be blue. Try jumping L1 to comp. ((Just so ya know Def will energize the def heater regardless of compartment temp it does have a bimetal but it only a safety set at 100deg in case relay on board welds shut---it monitor evap compartment, frz, fresh food, (two seperate in FF) in your model))
Posted on Oct 11, 2007
  • 193 Answers
SOURCE: Need wiring diagram or schematic for GE refrigerator
if you look on the back there should be one stuck to the inside of the case near the compressor. if not go here: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=TFX20JRSM
Posted on Aug 14, 2009
  • 47 Answers
SOURCE: I just bought GR R72MD Toshiba refrigerator. When
definitely not normal. could be a problem with the reeds in the compressor, the noise you are talking about the gas circulating sounds very similar to water running through pipes. id say definitely a manufacturers fault. see if u can swap it with another
Posted on Nov 11, 2009
  • 2468 Answers
SOURCE: I bought a defrost timer
use figure #1 as this unit uses a timer instead of adaptive cumulative defrost motherboard so use the white wire configuration #1
Posted on Nov 21, 2010
justinbur167
  • 257 Answers
SOURCE: Do you know where I can get a wiring diagram on a
Hello Thayden,
I understand that the Refrigerator compressor is not working on your unit. There are three possibilities of why the compressor is not working, the compressor is bad, the starter is bad, or the capacitor is bad.
To check the starter you will need to do the following (most common): Refer to picture at the bottom of the post
1. Unplug the unit
2. On the side of your compressor there is a cover this is the starter relay cover.
3. Remove the cover
4. Remove the wires
5. Remove the starter (top piece stuck on two rods)
6. Check if bad (shack it if you hear a noise/knocking it is bad and will not allow compressor to start)
7. Replace it and the bottom one the over load.
8. Reinstall in reverse
The Run Capacitor (uncommon that they go bad but possible)
1. The little black or silver box that two wires run to from the starter
2. Check to see if contacts or unit is burnt.
The Compressor
1. If you replace the above items and the compressor is not running the the problem is the compressor. This will take a licensed HVAC person to replace.
The above parts are inexpensive between $30-$50 at your local appliance parts store. There is a 50/50 chance that this will work and save you the cost of replacing the compressor or the whole refrigerator.
Thank you for choosing FIxYa.com
Justin
pd_0046_106_4387835?$pddetailsth$
Above Starter/overload and cover replacements (starter is in the bottom middle that you shake to see if you hear a noice/clicking)
Starter relay box on the left side of the compressor in this image.
Posted on Apr 05, 2011
Need to identify the prongs on my compressor. embraco egy90hlp wiring diagram
PDF]General Index - Embraco
www.embraco.com/DesktopModules/.../Arquivos/MP01EG.pdf
EmbracoApr 7, 2011 - Figure 6b Series EM - Compressor Model Identification Code . ....Compressor Wiring Diagram T Series (electrical component with terminal ...
Embraco PW 5.5A compressor - pins layout? - Refrigeration Engineers
www.refrigeration-engineer.com > ... > Domestic
Sep 4, 2008 - 4 posts - ‎1 author
My fridge-freezer quit working tonight - it's probably over ten years ... It's an EmbracoPW 5.5A, and the pins form an upside-down triangle, ... So, I want to try hard-wiring it but I'm struggling to identify the compressor terminals.
Identifying Compressor Terminals: Start, Run, and Main ...
fixitnow.com/wp/.../identifying-compressor-terminals-start-run-and-main...
Sep 9, 2010 - Let's say you're gonna do some tests on your refrigerator compressor to see if it's okay. Or, you need to figure out how to wire up a generic ...
Refrigerator compressor electrical question - AllisChalm
Jan 18, 2016 | Refrigerators
How do i get my condenser fan to stop running. it is cooling fine but won't shut off unless i shut it off.
Are you sure its the condenser fan? The fan is attached to the compressor power and wont run unless the compressor is running. On the other hand the fans inside the cooler will run 24/7 and are designed for continuous duty. If someone has worked on the compressor wiring you may have to re establish the wiring following the wiring diagram. I have seen condenser fans wired in hot areas to run continuously to attempt to cool down a hot compressor or compensate for a worn out or damaged condenser that doesn't get rid of the heat from the system. If that is the case a new condensing unit is probably in your future. Hope this helps good luck.
Oct 09, 2014 | True GDM-47 Refrigerator Merchandiser -...
I am attempting to locate the schematic for my refrigerator
You have not mention model so you can go your self to this web page where they have the parts diagrams and for most of apliances the diagrams also and many more so this can solve your questions
Jul 11, 2012 | KitchenAid Refrigerators
Do you know where I can get a wiring diagram on a whirlpool side by side refrigerator model no ED5PHEXMB00? Mainly for the compressor. Freezer is not getting cold. I vacuumed the coils in front and...
Hello Thayden,
1. Unplug the unit
3. Remove the cover
4. Remove the wires
The Compressor
Justin
Apr 05, 2011 | Whirlpool Refrigerators
Unit powers up, fans run, no compressor start
If the fans run we know it aint the defrost timer and you are getting power to the compressor so that means you have a wire done burned off one of the compressor terminals hopefully or ya might need a compressor. Probably just a burnt wire. These are pretty tough units. Diagram and run info
Partslist
Jan 31, 2011 | Delfield 406 / 406-CA Refrigerator
Will not defrost . Is it a continuous run, 8 hour or 10 hour defrost?
Good day,
It's an 8 hour cumulative running time control. It runs when the compressor runs, and as well the defrost thermostat in the freezer compartment is closed. That's for the running mode, in the defrost mode it runs whether the defrost thermostat is open or closed, and as well whether the thermostat is on or off.
If it's a defrosting problem, it could well be the defrost thermostat, and in rare cases the main heater. They are both located behind the rear panel in the freezer compartment.
In order of frequency of failing,
1. Defrost thermostat
2. Timer
3. Main heater
4. Harness wiring plugs in the freezer compartment that connect these items.
Jun 23, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
I have an old Searsd Coldspot upright freezer, Thr
on the side of both defrost controls is a diagram black is normally power white is normally nuetral wire the black wire will go to the center of the switchs defrost heater
will be on one side compressor to the other white to the clock moter green was hooked to the metal case if you have a mutitester the clock moter will have constant continuity even after the timer has been turned till it clicks the heater will go on the contacts that have continuity for the shortest amount of time
on the back of most older units was a wiring diagram constant defrost has power even when t-stat is set to off
cumulative the defrost only has power when compressor is running the diagram on old defrost timer should be simaler to the diagram on the old defrost timer the lighter colered tab is normally white wire
hope you have a tester but if you are inclined hook up black and white only turn control till clicks when you have the black wire in the correct position the moter will run no matter where the control is turned
then find wire that starts compresser it will need to be placed on the switch that maintains contact the longest leaving the
heater wire to hook to the contact that stays closed for 20 to 30 minutes
most defrost controls wire the same be careful wiring is 120 volt
Dec 13, 2009 | Cell Phones
I have 20 yeras old Maytag model GT1928PVCW which we were very happy. Unfortauantly it just stop cooling. Fans steel working but no cooling. Is it possible to repair
Yes it is, for sure. We just need to diagnose the problem. First, if you unit has ice on the back inside wall of the freezer, you have a defrost problem that can mostlilely be solved by replacing the defrost heater. If not, we will move on.
If you can read a wiring diagram, go to www.partselect.com and enter your model number. This will bring up a blown up diagram so you can locate evey part or you unit plus your in luck, it also has wa wiring diagram included. By looking a the wiring diagram, there are only four thing that will prevent your compressor from running.
  1. Temp control
  2. Defrost timer
  3. Run cap.,Over load, PTC Relay
Checking temp control/ Take the two wires from part and connect together. If the unit starts running, you will need to replace control.
Defrost timer/ It has a round piece in the front of it with a slot on each side of the round piece that will let you turn it in only one direction. You can take a flat blade screw driver and turn. This advances the timer. Turn until you hear it click. If unit starts running, replace timer.
Run capacitor, overload and PTC relay/ If you can hear the compressor clicking around every 5 to 10 seconds, you will need to replace the part. The bast thing to do is replace all three pieces with a Supco 3 in 1. You can search Supco 3 in 1 and find one on the web. If you can use a meter, you might want to check your compressor to see if the windings are grounded. Take anyone of the 3 post coming out of the compressor and check continuity between it and ground. If it has continuity, it's bad and will cost a lot to replace. Also check for continuity between each post. If there is continuity, this is great and the Supco 3 in 1 will fix the problem. I have made this as simple as I know how but I also know that it's not simple to peolpe that don't work on these everyday like myself. I hope you the best and good luck. If you have anymore questions, please respond back and I'll do my best.
Oct 25, 2009 | Maytag Refrigerators
Fride not cooling on eather side..
I believe your start relay and capacitor need replaced or the compressor is defective. Don't allow it to continue to try to start until we can find the problem. Let me know, Sea Breeze
Apr 23, 2009 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
