Question about Coffee Makers & Espresso Machines
Our Magic comfort has error message :ventilate" but when I press the water button all I get is a hummm.... no water. we tried to get hot water for the first time in years but didn't open the steam wan
Pushing the water button ,over and over
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Dear Ken, my magic comfort plus had similar problem with incorrect read out and not performing, not specifically with the hot water.
Try resetting the machine to full factory settings, and try again. As the water comes out of the steam wand, obviously that cannot be a blockage fault unless you are not getting steam either.
Posted on Nov 26, 2014
  • Ken Sawatsky
    Ken Sawatsky Nov 26, 2014
    thanx but we are not getting water or steam, it just keeps saying ventilate... tried to reset factory settings and to no avail. I think there's a blockage internally.
mirran
  • 515 Answers
SOURCE: ventilate button does not seem to work
If you open the steam knob, can you get out any water?
Posted on Jul 13, 2008
mirran
  • 515 Answers
SOURCE: No steam and ventilate
When you try to get out water, can you get a full cup of water or just a half cup?
How often do you descale your machine?
/Mirran
Posted on Aug 17, 2008
  • 109 Answers
SOURCE: titanium ventilate issues
Remove the milk frother,checked to see if it is blocked.
This can cause the machine not to ventilate correctly.
They tend to block with old hard milk.
Posted on Aug 26, 2008
SOURCE: trying to ventilate and hot water not flushing through on button 26
Before you press water button to vent you need to restore to factory settings.
First press menu (far right button) then toggle to restore factory settings (using far left button), press menu button then far right again until yes comes up, then press menu button. Press esc button (3rd from left), machine should now be back to normal. Then press water button (3rd from right) and turn steam knob to vent until free water is coming through.
This is the only way I could get mine to work!
Posted on Oct 23, 2008
  • 109 Answers
SOURCE: MACHINE GETS HOT ON TOP RIGHT HAND SIDE.TRYING TO LOSE VENTILATE
The top right hand side can get hot if you have the cup warmer switched on.
I am finding that the steam boilers are starting to block up and the steam lines are getting scaled up.
If you have access to compressed air,undo the boiler and lines and blow them out.
I have had coffee jammed in the inlet of the flow meter,blowing through it will be a good test.
Good luck
Posted on Apr 06, 2010
Testimonial: "coffee came throu' as before.....then switched to steam..it normally says ventilate here..steam! Hurray!!!"
Saeco magic comfort display ventilate, what does that indicate
It means that no water is moving through the machine.. To reset, you need to hit the hot water button (that's the button with water drops). Let it run until the message goes away.
If nothing comes out then you need service. We can service this type of machine in New York.
http://www.cerinicoffee.com/espresso-parts/espresso-machine-service-center-new-york.html
Aug 11, 2013 | Coffee Makers & Espresso Machines
How to ventilate Saeco Magic Comfort + coffe maker
Hi
If its a Magic Comfort + there is a water button on the panel (with the drop) that you push for water. You twist the dial for steam only.
If its a Magic Delux you twist the dial for water.
Nov 21, 2010 | Saeco Magic Comfort Plus Espresso Machine
On the screen is the error message - ventilate- wjat do I do?
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
May 15, 2010 | Saeco Magic Comfort Plus Espresso Machine
On the screen is the error message - VENTILATE- wjat do I do?
Press the water button to prime the machine. There is air in the water circuit which must be expelled. And checked water tank is properly seated.
Mar 28, 2010 | Saeco Magic Comfort Plus Espresso Machine
Error message "Ventilate"
Hi
That means the pump needs to be primed by running water through the wand. Push the water button for water(the drop symbol) You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed. Ventilate
Mar 15, 2010 | Saeco Magic Comfort Plus Espresso Machine
What do you do about the ventilate message
Ventilate is the same as priming the machine open the hot water valve to purge the hydrallic system.
Jan 24, 2010 | Saeco Magic Comfort Plus Espresso Machine
New Royal espresso machine
Run hot water cycle to ventilate machine.
Mar 09, 2009 | Saeco Magic Comfort Plus Espresso Machine
Error message on screen VENTILATE
put a cup under the steam pipe.
If you have a new model of Magic Comfort the you have to press the right lower button, if you have a old vrsion then you have to press the button under the meny button.
Make a cup of water.
/Mirran
Aug 31, 2008 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic comfort
turn the hot water / steam knob on to 'ventilate' the pressure from the machine. The ventilate /overtemperature message will disappear when ready (few seconds usually)
Oct 26, 2007 | Saeco Magic De Luxe Espresso Machine
Esppresso machine
This means there is air in the steam/hot water line. Turn on the hot water button and run it through until it stops saying ventilate. If this doesn't work, there could be more serious problems at work (clogged hose? bad flowmeter?).
Mar 19, 2007 | Saeco Magic Comfort 103467 Espresso...
Coffee Makers & Espresso Machines Logo
29 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
