Question about Car Audio & Video
Why do my kenwood kvt -514 cuts off after I turn my volume up past 24?
    Problem Solver:
  • 15 Answers
It sounds like you have a bad speaker. If you do have one, it may be really loud, or, it may be making noise. When you figure out which speaker it may be, disconnect it after the power is off, remove the speaker and put an ohmeter across the terminals of the woofer on it. It shouldn't read less than 4 ohms. Sometimes speaker mfgr's make them in 3 ohm and this would affect the output. The output of the stereo could be either shorted to ground somewhere, a mild short may allow the outputs to work but may eventually burn them up. I would test the speaker wires on the back of the radio with an ohmeter to see if they are shorted or see if they read below 4 ohms on each set of speaker wires when the stereo plug is disconnected.
Sometimes the speakers have crossovers in them which would interfere with the readings, but, you could always disconnect the crossover terminal wires temporarily if you could manage not to ruin them. All in all, the stereo sounds like it is going into protection from a bad speaker, or, possibly low voltage from a loose ground, bad ground, or a bad wire connection. test the voltage from the yellow wire to ground on dc volts with a good digital voltmeter to be sure you are running at 12 volts with the car off minimum, or, 13.5 to 14 volts with the car running. The same with the red wire. Test across the yellow and black, then, find a good shiny piece of metal under the dash, and connect one meter probe to this, then connect it to the black ground wire to check resistance. The meter needs to be on ohms and it should read 1 ohm or lower to show it has a good ground. If it is higher, it may be the problem, especially if it is like 15 or 20 ohms or higher.
Let me know if you still need assistance. I repair this all, but i am in Connecticut.
Regards,
Marc Belanger
Advanced Electronic
http://advancedelectronic.net/
Posted on Dec 02, 2014
5 Suggested Answers
SOURCE: I sent a Kenwood KVT-514 to my niece in Europe. I
no you must send her us dvds
Posted on Jun 08, 2009
  • 909 Answers
SOURCE: does anyone knows where to conect the dimmer wire
Connect to the side light live. So when you turn the lights on it dims the display.
Posted on Jun 15, 2009
  • 547 Answers
SOURCE: What mp3 player will work in the usb port on the
You can put a USB thumb drive in this port, and it will play mp3 files from that drive.
You can also buy an iPod interface that will let you plug in an iPod or iPhone to the USB port.
Posted on Jan 27, 2010
SOURCE: how to unlock code for kenwood kvt-514
Did anyone ever figure this out? I need to know also
Posted on Aug 13, 2010
Help me crack the security code on my kenwood KVT-514 DVD car stereo????
Here's a video tank daWG suggested as a solution to your problem from YouTube:
how to unlock code kenwood stereo.3gp
Mar 23, 2013 | Kenwood KVT-514 Car DVD Player
How can I update tha software for keenwood KVT-514
Try this link. http://www.helpowl.com/p/Kenwood/KVT-514/Research/53126?search=Kenwood+Kvt-514+Update&x=79&y=17
Feb 17, 2013 | Car Audio & Video
My Kenwood kvt-514 is not turning on
unplug the battery wait ten seconds plug it back in....
Aug 10, 2012 | Kenwood KVT-514 Car DVD Player
Codigo de seguridad de kenwood kvt-514
buenas,, hace tiempo compre un repro kenwood kvt-514 y al encenderlo me sale en la pantalla CODE SET y no tengo el codigo,, hay manera de desbloquearlo sin el codigo que me solicita...???
Mar 20, 2012 | Kenwood Sirius KDC-MP522 CD Player
How to pair your phone to the bluetooth on th kenwood kvt-514
Go into your Setup menu and scroll down to bluetooth settings.
From here you should see a screen that says "HFP connect device", "A2DP connect device" and "Receiver pin code".
Press the "Set" button to the right side of "A2DP" and it should bring you to another screen that says Pair device.
Go onto your phone settings and make sure you have your bluetooth setting on your phone set to "make discoverable"
Press the search button on the Kenwood unit on the right side and it will start scanning for available devices in the vicinity
Also press the Search button on your phone so it also starts scanning.
Next you should get a message on both your phone that shows the Kvt-514 and also a message on the Kenwood that shows either the model of your phone or your "nickname" (if you named your phone)
Select the Kvt-514 on your phone and it will prompt you for the pin code that was on the first bluetooth setup screen...most likely 1111 (you can also set a different pin code using the "set" button to the right side of the "Receiver Pin Code" on the first bluetooth setup screen)
Enter the Pin code and select "Pair" on your phone.
You should get a confirmation on both the Kvt-514 and your phone that they are connected and you're good to go.
Apr 02, 2011 | Kenwood KVT-514 Car DVD Player
I have a KVT 514 unit that cuts out when the volume goes past 23. Even when I change the audio equalizer to natural and turn off the loud it cuts out. I have a 2003 accord ex v6 coupe, infinity reference n...
to me you need to do the big 3 upgrades .
1 second battery
2 bigger power cable
3 high output alternator
sound like you electrical system can't handle the high volume you want to here you system at.
it starving for power
need to upgrade your alternator to a 150 amp or bigger so your amps and factory accesories can get the voltage to run properly .
then put a second battery in trunk to help your amp
does you head lights flicker or interior lights flick signs of your car audio system killing your alternator
can help you more
caraudioquestion@gmail.com
Oct 14, 2010 | Kenwood KVT-514 Car DVD Player
Kenwood kvt 514 can't turn on the sub
in the main option menu for choosing tuner dvd video etc. scroll down one and youll see "standby" put that on then scroll through the options and turn on the sub
Jun 28, 2010 | Kenwood KVT-514 Car DVD Player
How to unlock code for kenwood kvt-514
May 16, 2010 | Kenwood KVT-514 Car DVD Player
Does anyone knows where to conect the dimmer wire of a kenwood kvt-514 or kvt-512??
Jun 15, 2009 | Kenwood KVT-512 Car DVD Player
Car Audio & Video Logo
51 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
