Question about Saws
I need an online manual for Pro-Tech Compound Miter Saw, Model 7203. I removed the blade guard and now I can't get it back on properly. Can you help?
When I removed the guard in order to change the saw blade, I was careful to put the screws/bolts in the right order for replacing them, but now the guard is in the way of the blade and the blade won't descend enough to cut the wood. I have to cut the wood without the guard now and that is dangerous. Can I get an online manual for this product?
jyackle5
  • 8197 Answers
SOURCE: Makita 10" Compound Miter Saw LS1040 manual?
Here you go.
This is the ls1040
http://www.makita.com/en-us/Assets/images/Products/LS1040/owners_manuals/LS1040.pdf
This is the ls1040f
http://www.makita.com/en-us/Assets/images/Products/LS1040F/owners_manuals/LS1040.pdf
Posted on Mar 12, 2009
Editor925
  • 285 Answers
SOURCE: changing the blade to our compound miter saw when hex slot is rou
ok a couple things to try...
Firstly to hold the blade arbor still if it doesnt have an arbor/spindle lock button, try wedging a piece of wood between the blade and the saw table (might have to lower the cutting head and hold it down. Next try again with the hex key... Make sure it is the right size one, i.e. the one that came with the saw. If the hole is really rounded out, you are in a bit of a bind, however, the next option is to get a grinder and try and slice a groove across the nut so you can fit a large screwdriver or a flat piece of steel in th slot in the nut you just made for leverage and try and work the nut off that way. Either way, be sure to get a new blade nut if and when you get it off to make sure the problem doesn't occur again. See how you go.
Posted on Jun 20, 2009
  • 7 Answers
SOURCE: change blade miter saw
Un-plug the saw. Remove the screws holding the side saw guard in place. Look at the center of the saw blade for the nut holding it in place. Take a socket wrench that fits the nut and loosen it. You'll need to take a scrap piece of wood 2x4, and jamb the teeth of the blade into it while loosening the nut. The nut will come off first and then a washer/spacer.
Reverse the order for installing the new blade. Make sure you use the proper size diameter blade (10 inch) and mounting hole in the replacement blade. Also, use the provided washer/spacers that were on the original blade and secure the nut. Spin by hand to see if everything clears. Mount the protective guard back on. Plug in the saw and test cut .
Good luck. If you are still unsure - ask a handy neighbor to help. It takes about 5 minutes to complete this task.
Posted on Oct 05, 2009
Dolfoff
  • 148 Answers
SOURCE: I am looking for a repair manual for my 10" ryobi
Takes a bit of navigating to reach it, but I'll try to help you get there.
Start at this page HERE.
Click "Repair Parts Catalogue"
Click "I HAVE READ THIS PAGE & AGREE TO THE TERMS PROVIDED".
Click the "Model" tab located at top left of page.
In the box labeled "Model Name/Number" type in the following without the brackets [TS1342] and click the "Search" button to the right.
One (1) Result should be found. To the right is a list of two available drawings.
The one you seek is "General Assembly"
Hope this helps,
Dolf-
Posted on Oct 15, 2009
  • 323 Answers
SOURCE: Changing the blade
there is a nut holding the blade in the center , it is left handle thread , there should be a locking mechanism to hold the blade while you unscrew the nut
Posted on Oct 31, 2009
Northern Tool 10" compound miter saw. How do I change the blade?
remove the power cord from the socket in the wall first
if there is a small hole in the blade , place a phillips screw driver in that hole and turn until the driver is locked against the depth guard
use the correct size spanner /socket and undo the spindle nut holding the blade on
if there is no hole ,then place the screw driver in the teeth of the blade to lock it
the motor will spin so that the teeth cut against the direction of cut ( up into the guard or up through the depth guard ( blades normally have a arrow for rotation direction)
tighten the spindle nut and if no hole in the blade use a hammer and hit the spanner with a hard rap
Sep 30, 2015 | Saws
I HAVE A DW716 MITER SAW AND NEED TO CHANGE THE BLADE, BUT I'M NOT SURE EXACTLY HOW TO REMOVE THE BLADE GUARD. I KNOW THAT I NEED TO PURCHASE THE CORRECT BLADE WRENCH TO DO THE JOB. CAN YOU TELL ME THE...
Hi there
You do not need to remove the blade gaurd to change the blade. You only need to raise it enough to acces the blade screw. Unplug the saw. Raise the blade arm. Raise the guard to it's upper position. On the left side of the blade, just forward and up slightly from the blade screw is a screw for the guard bracket. Loosen, but do not remove this screw. Once it's loosened the guard can be raised farther exposing the blade screw.
pg 6 of the manual illustrates this process, here's a link so you can see the parts I am discribing,
http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=DW716&selectedType=12803#
click the pdf icon next to instruction manual, then open the file.
As for the blade wrench, this should have come with the saw, there is a slot in the base for storing the wrench, on the back left side, it slides in and out for safe keeping. If you have misplaced the wrench the DEWALT part number 608563-1
Dec 31, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
Need a new lower guard assembly part, for an 81/4" compound Protech miter saw.model #7203
Sorry the only place you can get parts for the saw is sears parts direct
Dec 03, 2010 | Garden
How do I remove 12" blade from from dw705 miter
loosen the guard screw, UNPLUG tool first, move the guard out of the way, there is a spindle lockon the backside of the gearcase push it and slowly turn the blade until it engages and then remove the bolt, it is a left hand thread. DO NOT disassemble the guard, just loosen bolt and move out away from blade also you need to have the head in the raised position.
Oct 28, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
Concept MS100 mitre saw blade guard dillema.
I have changed the blade a few times, There is no need to remove the spring, etc. All you do is remove the bolt holding the guard and rotate it counter clockwise and it exposes the blade.
I am looking for parts for this saw. Anyone know where to get them?
Jul 06, 2010 | Makita 10" Dual Bevel Sliding Compound...
How do i get guard out of way to replace blade..DW718
Make sure the saw is unplugged, manually move the blade guard up to it's fullest extension, push the arbor lock to make sure the arbor and blade do not spin (on front of saw motor housing), then wrench the nut holding the blade to remove. Remove the old blade, install new one and reassemble in reverse order. You can take the guard off completely if you choose, but it is not necessary. I hope this helps and good luck!
PLEASE REMEMBER TO VOTE AND LEAVE A TESTIMONIAL. THANK YOU
Mar 30, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
Change blade miter saw
Oct 05, 2009 | Delta Cycle Rothko Rolling Bicycle Stand
How do i change the blade on a bosch 3912 chop saw
Push the saw down and manually hold the guard while it is the retracted position and let up on saw while holding guard,you should
be able to put in wrench and loosen bolt.
Apr 09, 2009 | Bosch 3912 12 Inch Compound Miter Saw,...
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Jan 24, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Saws Logo
113 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
