Question about Thomson GE Cordless Telephone 27995GE1
How do I change the remote access code
Forget access code
Cant change remote code
Don't forget you have to change the codes in BOTH the receiver & transmitter.
Nov 30, 2013 | Hunter Ceiling Fan Light Remote Control
Replaced batterys twice but remote can't access functions
Visit this site to get more details about how to check and repair a remote control. All details are there described. Type in "Electro-help" either in Google or yahoo search box and click search.
Don't forget to type in 'hyphen' in between words of site. The site will appear as this name.
Pull up older posts there. You can repair your remote control by youself.
May 08, 2012 | Tivo C00210 Remote Control
How do I access my messages when I'm not home
1. Dial your phone number using a touch tone phone.
2 After the greeting message enter your 2 digit remote code.
3. Follow the voice instructions.
4. When finished hang up.
The default remote code is 11
The remote code can be entered or changed on your base station.
To change/set the remote code.
1. (Menue) ---> (0)(6)(3)
2. Enter a 2 digit code ---> (Save) ---> (Off)
Jan 19, 2012 | Panasonic KX-TG5243 Cordless Phone...
Retreving calls from another phone uaing my code does not work any longer. I would like to reset the code. Please give instructions. Thank You,
Changing the Remote Access Code The Remote Access Code is preset to 500. You can change the Remote Access Code to any three-digit number from 500-999. DO NOT pick the same number as that assigned to the Priority Calling Code. 1 Press g. The Message Window displays CH. 2 Hold down c for at least two seconds. The system announces "First digit." 3 Press / or ? to change the digit. 4 When the Message Window displays the desired first digit, press c. The system announces "Second digit." 5 Press / or ? to change the digit. 6 When the Message Window displays the desired second digit, press c. The system announces "Third digit." 7 Press / or ? to change the digit. 8 When the Message Window displays the desired third digit, press c. The system announces the new Remote Access Code.
Aug 26, 2011 | AT&T 1725 Answering Machine
Hello I was wondering how to use the VM acess with my phone. I want to be able to call from a different number and listen to my messages how do I go about doing so
I have a similar model. You need to configure a remote access code on the phone. Then, when you call your phone, you enter the pin after your message starts.
(From the manual)
Using a touch-tone phone, you can call your phone number from outside and access the unit to listen to messages or change answering system settings. The unit's voice guidance prompts you to press certain dial keys to perform different operations.
Remote access code:
A 3-digit remote access code must be entered when operating the answering system remotely. This code prevents unauthorized parties from listening to your messages remotely. The default
setting is "111".
Important:
To prevent unauthorized access to this product, we recommend that you regularly change the remote code.
1 {MENU} {#} {3} {0} {6}
2 Enter the desired 3-digit remote
access code.
3 {SAVE} {OFF}
Below is a link to the manual. The remote access instructions are on page 35.
http://static.highspeedbackbone.net/pdf/KXTG4031-MUL.pdf
Mar 05, 2011 | Panasonic KX TG4031 Cordless Phone
I need the tv codes for Sanyo TV
Acording the User manual for One For All URC4220 Remote Control the only Code for Sanyo TV is 0154. You can access the user manual here:
URC 4220 ENG ESP
I found the code on page 40
Don't forget to rate if this was helpfull :-)
Sep 17, 2010 | One For All URC4220 Remote Control
I purchased a used Emerson TV Model 3 CR202EM8 and dont have manual or remote...how do I reset password to access screen to enable me to change to video mode
go here if you cannot access the site: here are the instructions:
Your password will be erased and return to the default
(0000) when a power failure occurs. If you forget the
password, unplug the power cord for 10 seconds to restore
the password to 0000.
Sep 07, 2010 | Emerson CR202EM9 TV
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
I lost my Universal remote manual for INTERTRONIC RC Pro. Can anyone please help me? I have a Roadstar telvision. Thanx please
Can you please give me the make and model no. of your universal remote so that i can let you know if there are any manuals available.
May 16, 2009 | Philips 483521917703 Remote Control
Unlock apex tv model # AT2702
try this manual;
[PDF] AT M C T
On the remote try pressing the ( F ) button and the mute button at the same time on your remote control.
Here's the link for the 2402s manual:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=4db1185db9d3369
Pass Code Menu
This menu allows you to change the access code for the Parental Guide
functions of the TV set. Pressing the “Menu” key when Pass Code
Control is highlighted. This will turn on or off the Pass Code function. With
the Pass Code function ON, you can also change the Pass Code. Use
the down arrow key to highlight “Pass Code,” then enter the new Pass
Code using the numeric keypad. Press the left arrow key when finished.
1. The factory default pass code of 6688 is also the override code, in case
you forget your new pass code.
2. The factory defaults have TV-MA and MPAA-X ratings blocked . Hope this may help you
DON'T FORGET TO RATE:
Apr 17, 2008 | Apex Digital AT2702 27" TV
Thomson GE Cordless Telephone 27995GE1 Logo
120 people viewed this question
Top Thomson Lands Phones Experts
george  peters
george peters
Are you a Thomson Lands Phone Expert? Answer questions, earn points and help others
