Question about Thomson GE Cordless Telephone 27995GE1
Have a 27995ge1-a answering machine. I forgot remote access code, is there a way to change it
Uniden DECT6.0 Model D1680 Problem: Need to change recorded message ,cant get past Security Code_ a 2 digit pin .Forgot what is was..
The only time the Security Code is used is to effect
Remote Access, ie, "call home and manage your
answering machine messages remotely" by pressing
the code numbers while the Greeting is being said....
The Security Code is set on the D1680 from the handset
by this procedure:
press [menu]
scroll to "Ans. Setup"
press [select]
scroll to "Security Code"
press [select]
the code will be displayed, first digit blinking
(enter a new digit if you want to change it )
the code will be displayed, second digit blinking
press [select] (chirp) press [END}
All of the Answering Machine System functions can
be managed remotely, and voice menus are provided
to guide you in these operations.
Entering the model number found on a small sticker under
the battery in the handset at www.manualslib.com will
fetch a free copy of the User's Manual in case the original
has been misplaced.
Apr 01, 2016 | Uniden D1680 Cordless Phone
Retreving calls from another phone uaing my code does not work any longer. I would like to reset the code. Please give instructions. Thank You,
Changing the Remote Access Code The Remote Access Code is preset to 500. You can change the Remote Access Code to any three-digit number from 500-999. DO NOT pick the same number as that assigned to the Priority Calling Code. 1 Press g. The Message Window displays CH. 2 Hold down c for at least two seconds. The system announces "First digit." 3 Press / or ? to change the digit. 4 When the Message Window displays the desired first digit, press c. The system announces "Second digit." 5 Press / or ? to change the digit. 6 When the Message Window displays the desired second digit, press c. The system announces "Third digit." 7 Press / or ? to change the digit. 8 When the Message Window displays the desired third digit, press c. The system announces the new Remote Access Code.
Aug 26, 2011 | AT&T 1725 Answering Machine
It says to enter my remote access code to check my answering machine remotely............I do not know my remote access code, or how to set it?????
If you haven't changed it, it's 50.
To change it, press and release the MENU button on the base unit until the system announces "Set Security Code." Choose a two-digit number from 40 to 99.
You can download a copy of the manual at
http://vt.vtp-media.com/ecp/documents/product_Product/937/UserManual/2677/ip5850_manual.pdf
May 09, 2011 | Vtech IP5850 Answering Machine
I have a Vtech Model ia5824. i forgot my remote access code. how can I change the access code?
The IA5824 isn't an answering machine. Please refer to the documentation for whatever answering machine or voicemail system you have on your phone line.
If you require further assistance, add a comment to this question and identify the answering machine or voicemail system.
Sep 13, 2010 | Vtech IP5850 Answering Machine
I have at&t digital answering machine 1717 and lost manual
The code it usually set up by you on the device, if you run through the set up procedure (Time Date, message) on your machine one of the steps is the remote access code, which the machine should read off to you at this point, you should change this to a code you can easily remember and not leave it at the factory defaut as this would leave your messages openly accessable to other parties.
Hope this is of some help.
Ed
May 19, 2009 | AT&T 1717 Digital Answering Machine
Instruction manuel for ge cordless phone 27995ge1-a
Our base phone is hung up on searching. It has not dial tone. It just says "searching..." How do we fix it?
Jan 30, 2008 | Uniden Cordless Phone
ANSWERING MACHINE
http://www.home-electronics.net/ge/pc/IB/27851GE1_IB.pdf
that is the manual. just hold the skip button down and that will change the lanuage!!!!
Oct 29, 2007 | Thomson GE Cordless Telephone 27995GE1
At&t 1739 answering machine
Get remote access code from the machine get it by pressing set up button on answering machine. Go to another phone when machine picks up enter access code then enter *7 record new message press 5 when done then to end call enter *9
Sep 18, 2007 | Lands Phones
Thomson GE Cordless Telephone 27995GE1 Logo
125 people viewed this question
Top Thomson Lands Phones Experts
David Burbee
David Burbee
Are you a Thomson Lands Phone Expert? Answer questions, earn points and help others
