Why outside doorbell not working changed battery still not working
Changed battery.
4 Suggested Answers
SOURCE: The battery unit of my byron sx81r doorbell is
Try following the problem solving from the instructions: http://media.chbyron.eu/file/pdf/SX86_EU-IS_-30-01-09_instructions.pdf
Posted on Nov 20, 2010
  • 10 Answers
SOURCE: how do I change the battery in the wireless doorbell button?
in the wireless doorbell button, you can plug out the old battery, and then plug into the new one, be careful, new one should be the same type as the old one, try it , good luck!
Posted on Feb 23, 2013
SOURCE: Doorbell doesn't work
It seems your doorbell transmitter got wet and corroded the contacts.
These push buttons are not sealed at all and thus will let rain, snow etc. eventually corrode the electronics.
Solution: Find a new push button on eBay.
Cheers
Posted on Mar 05, 2013
Indoor plug in device works fine but doorbell isn't despite changing batteries.
Salutations Helen Wahlen,
If you DO NOT have a RESET procedure in the MANUAL... Remove ALL power from both units... (battery from the base ...if equipped).
Re-Plug the base unit close to where the button is mounted
and restore all batteries & power and start the INSTALL instructions from the beginning.
Failing that.. DISCLOSE what in the world we are discussing (make, model... year, etc) and we can give it more appropriate attention... (resulting in better advice),
Happy hunting!
Mar 19, 2016 | Home Security
My 202 doorbell does not "react" if the button is pushed AFTER my neighbor unlocks his car by using his remote key. Can I change the frequency range of the doorbell?
Just a thought if the bell is wireless your diagnosis may just be coincidental, but look to at swapping out the battery. can you press the bell, say 5 times one after the other ok? Batteries sometimes recharge slightly between presses, maybe just pressing it twice once after each other doesn't work.
Nov 19, 2014 | Cars & Trucks
Cheers
Feb 26, 2013 | Desa International White Wireless Plug In...
We are installing the doorbell and here is how we have it set up: the 18 volts off transformer red wire going to transformer on doorbell, negative wire going to outside button, red wire from button going...
need more info. Doorbells do not need 2 xfrms. The red off 24 volt xfmr foes to door switch and returns on white. If you have 2 door switch one switch to front door label on doorbell and the 2nd goes to back door label. What is the brand and model number/ I'll try and walk you thru it.
Jun 21, 2017 | Heath Zenith Designer Series...
Hello I have now got 2 (two) of these units over the past 8 months and neither work----changed batteries--interchanged push button---changed main unit--nothing works----but when my neigbour across road has...
The doorbell buttons and your receiver must be on the same channel. If you will get out the directions that came with your unit, they will describe the process to go through to reset the specific "codes" for your buttons and receiver.
Jan 04, 2010 | Desa International White Wireless Plug In...
I changed the batteries on my door bell, and it still wont ring
Troubleshooting
Chime does not sound:
• Make sure the doorbell button and the chime codes are the same (See pages
2 and 3).
• Check orientation of doorbell button battery (See page 3).
• Check the doorbell button and chime batteries, replace if necessary.
Batteries seem OK, but the chime does not work when installed:
• Do not mount the chime or doorbell button on metal or near metal studs. This
reduces the transmitter range. Use 1/4" to 1/2" (6 to 13 mm) wood shims to
move the chime or doorbell button off the metal surface.
• Don't mount the chime too close to ground level concrete slabs. This may
also reduce the range. Mount the chime away from the floor.
• Try different locations for the chime closer to the doorbell button. Also try to
orient the chime at a different angle to increase the range.
The range of the doorbell depends on location, temperature and battery
condition.
Regulatory Information
This device complies with Part 15 of the FCC Rules and RSS-210 of Industry
Canada. Operation is subject to the following two conditions: (1) this device may
not cause harmful interference, and (2) this device must accept any interference
received, including interference that may cause undesired operation.
The user is cautioned that changes or modifications not expressly approved by
the party responsible for regulatory compliance could void the user’s authority
to operate the equipment.
Technical Service
Please call 1-800-858-8501 (English speaking only) for assistance
before returning product to store.
If you experience a problem, follow this guide. You may also want to visit our
Web site at: www.hzsupport.com. If the problem persists, call* for assistance
at 1-800-858-8501, 7:30 AM to 4:30 PM CST (M-F). You may also write* to:
HeathCo LLC
P.O. Box 90004, Bowling Green, KY 42102-9004
ATTN: Technical Service
* If contacting Technical Service, please have the following information available:
Model Number, Date of Purchase, and Place of Purchase.
No Service Parts Available for this Product
Jan 02, 2010 | Desa International White Wireless Plug In...
How do I change the battery in the wireless doorbell button?
are you to take it off the wall
if so it should have either two screws or slide off door
Feb 01, 2009 | Desa International White Wireless Plug In...
Doorbell stopped working
Check the contactor in the doorbell. It may have some "yuk" on it preventing it from making contact.
Jan 04, 2009 | Desa International White Wireless Plug In...
493 people viewed this question
jasbo
jasbo
