Why can I not get the menu setup on my screen for the sunluxy dvr
I have rebooted the dvr but no joy
    New Friend:
  • 88 Answers
Hi you don't say how you have it connected . But if you have it connected by scart take out the scart lead and try a different one it could be the scart lead is faulty or if you have HDMI socket on your DVR try connection that way that's if you have HDMI on the TV let me know how you get on
Posted on Nov 26, 2014
How to reset password for a samsung SDE-3004N DVR home security system. There is no remote for the system and have lost the password.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
Samsung Security DVR Reset Procedure #2
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    Press and hold the following buttons
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
    When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6 Courtesy Sergio Ayala
To factory reset the SDR-B74301
  1. Reboot the DVR
  2. Once the DVR has rebooted, enter the following sequence on the remote:
  3. UP, RIGHT, 5, 3, 3
  4. You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
CCTV Networking Technical Support
Sep 18, 2017 | Samsung Home Security
How to reset my sunluxy sl-7104
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
System reset procedure to many popular brand video recorders are given.
Jun 26, 2014 | Ganz DR4NC-160 DVR DIGITAL VIDEO RECORDER...
How to set sunluxy dvr to factory setting
remove the outer cover of the DVR try to find the on board battery
remove it for about 5 sec or 10 sec (while power off)
Jun 25, 2014 | Lorex SG6153 / Weather Resistant Mini...
How do i login to my sunluxy h264 network dvr
Please watch the above video for setup details or visit the product support team at http://www.sunluxy.com/?p=97
May 14, 2014 | Video Accessory Corporation Home Security
How do i login to my sunluxy h264 netwosk dvr
I'm not familiar with this particular dvr but most of the time the "help" button is still available to click on even though you can't log in. Search "log in" through the help menu and see if they give you default usernames and passwords.
May 14, 2014 | Home Security
When i reboot my Zmodo dvr I Can't get menu to come up or mouse to work HDD light keeps flashing,blinking hdd light,HDD indicator light
I had the same problem. Did their online tech support and Patty told me to hold down the "rewind" button on the DVR for 20 secs. You should now be able to right click your mouse to access the on screen menu. You will now want to go under system, and a/v setup and change the device to VGA instead of Vout. Now you can reboot and not have to go thru holding down the buttons anymore. Worked for me.
Oct 02, 2012 | ECHO1USA Zmodo 4 Ch Complete Dvr Kit -...
MY DVR EYTRON TV8903 IS LOCKED, AND I FORGOT THE PASSWORD. WHAT IS THE SOLUTION?
Follow these instructions to reset the master password on the JPEG2000 and JPEG2000 H.264 Dual Codec series DVRs. Press the menu button on the DVR. When prompt for a password, press the follow buttons on the DVR in this order: STOP --> PLAY --> STOP--> SEARCH --> PTZ --> PIP -->1 --> 2 --> OK (or Enter). You will be logged into the DVR as the administrator. Select Configuration from the System Menu. Then, select password Setup from the confuration menu. The password setup screen will display your current password.
Nov 09, 2010 | GE SDVR-16 Video Recorder
When turned on a purple screen comes on which says the system is rebooting. Afterwards the screen comes on saying it is restarting the system and will take a few minutes. After about five minutes, the...
Unplug your receiver for two minutes. When the first screen pops up I think it says acquiring satellite info do the following.
With the remote press menu then go to settings then setup then reset and press restart everything .
Just remember to reset your times and settings on the dvr.
It may not work right away, just keep trying, including unplugging the infernal machine!
Jan 19, 2010 | Directv HR21-700 DTV Receiver
Sony (KDF42WE655). Always have a video 7 label on the screen
Try these:
  1. Press MENU on the remote control
  2. Select Settings
  3. Highlight Setup
  4. Select Label Video Inputs
  5. Select Video 7
  6. Select None if available or
  7. Leave the label blank
Aug 23, 2009 | Televison & Video
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
