Question about Weed Eater FB25 25cc 2 Stroke Gas Powered 170 MPH Blower
Won't start no ignition weed eater gas blower 25cc FB25
Change gas oil mixture ??
    Sergeant:
  • 458 Answers
If the fuel is older than 2 months dump it out and put in fresh fuel mix. To see if it has spark attach a jumper wire to the chassis of the saw< cooling fin is good> and the other end to the threads of the plug. Pull the starter cord and watch for spark to jump across. Do this in dim light. It should be bright blue.
Posted on Mar 13, 2015
  • 29 Answers
If it has a spark plug try a new one.
Posted on Nov 26, 2014
Gas to oil mixture for 1 gallon of gas
most of my 2 cycle machines are 50-1 which amounts to 3 ounces of oil per gallon of gas. If 32-1 than it would be 4 ounces of oil per gallon of gas. Hope this helps.
Nov 26, 2015 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
My hand held blower wont spark plug and carb.replaced still wont start
If the plug is wet with fuel and it is firing then pull the muffler and for a struck ring. Struck and bad score cylinders will cause one not to start as you need at least 100 psi of compression to ignite the fuel mix.
These are okay then check the ignition of the flywheel to coil relationship as it could be a sheared flywheel key. Note most 2 cycles are now using cast in key as part of the flywheel itself.
Mar 14, 2015 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
Can a gas powered blower be repaired if it was drooped in pool.
it's hard to get it running again...probably it's not worth a try...
- you should open the carburetor, dry and clean it.
then the spark plug has to be removed and dried with a blow torch, also inside the cylinder opening.
then you better buy a can of starter spray to ease a start procedure.
Weed Eater FB25 Handheld Blower Parts 25311960-50ikml0pgld1svv5r0lj5py2-4-0.jpg 25311960-50ikml0pgld1svv5r0lj5py2-4-2.jpg
Dec 07, 2014 | Weedeater 25cc 2-Cycle Gas Blower - FB25
What fuel do I put in the weed eater gas blower fb25?
Regular unleaded with whatever oil mix the fuel cap has on it.
Try to avoid gasoline with high ethanol content. You can look online and find alcohol-free gas in your area. You wont regret it!
Oct 05, 2014 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
Weed eater fb25 25cc gas blower wont start
change the spark plug--put fresh fuel in gas tank 89 octane mix
Sep 04, 2014 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
I have the featherlite weed wacker the prime button won't come up when i push it down' won't start
For the bulb to come back up it needs to easily pull fuel from the carb, if the filter in the tank is blocked, or there is dirt in the carb the bulb will not come back up, replace the filter in the tank, if no better you need to clean the internall filter in the carb.
Aug 10, 2013 | Poulan Fb25 Weed Eater 25cc 2-cycle...
Ran well the 1st yr. Added Stabil - would not start this yr. Have put fresh gas in but will not start.
you added stabil but did you run the gas out of the carb? Take the carb apart and klean all with carb cleaner, spray in all holes. Check the plug gap of the new plug while your into the unit anyway the gap should only be 1mm.
Dennis
Nov 06, 2012 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
Weed eater fb25 won't start
This blower is fuel sensitive! Gas and oil mixture has to be correct. Too much oil will cause carbon buildup in the cylinder. In my case my blower would not start after several uses this season. I checked EVERYTHING....spark, fuel delivery, air filter.....then checked the flywheel which has no separate key....the key is cast into the flywheel. Read somewhere about the carbon buildup so took the cylinder off and viola! The piston ring was firmly stuck in the piston groove plus the cylinder was carbon scored. I tried to gently pry the piston ring free but it was so firmly stuck, it broke. Not worth fixing. Take the muffler off and you will be able to see the piston ring....use a small pick or something to see if the ring is free. If not, proceed to tear down or throw out. I was able to see scoring on the piston and determine my ring was stuck this way. Remember the elements needed for successful ignition...fuel/air...spark....compression. Stuck ring = low compression. The last time you ran the blower the ring became stuck...the engine continued to run because of the engine rpm's but when you try to start at low RPM's, no luck.
Jan 18, 2012 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poula pro bvm200vs/ 25cc won't start
i have a polan bvm200vs. that wont starits got the main 3 gas spark and compresion i even change the gas in it and still noyhing
Oct 29, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Weed Eater FB25 25cc 2 Stroke Gas Powered 170 MPH Blower Logo
202 people viewed this question
Top Weed Eater Garden Experts
David Payne
David Payne
Bonard Allen
Lawrence Oravetz
Are you a Weed Eater Garden Expert? Answer questions, earn points and help others
