Question about Timken 2007 HA590092 Chevy Impala Rear Wheel Bearing & Hub Assembly
Are there any special tools needed to replace a hub bearing on the rear passenger side with E brake on a 2007 Impala?
  • 118 Answers
Just a socket set. You remove the wheel, take the drum off (or the brake caliper and rotor if it's disc brake) and remove the 4 bolts on the back side of the hub. They are usually 13mm or 15mm 12 point bolts. You may need to tap it with a hammer to get the bearing assembly off of the axle. That's it!
Posted on Nov 26, 2014
I have a 83 Bronco 351w I am doing the brakes and the passenger side rotor needs to be replaced can someone walk me through this thanks
Personally I would replace both rotors to prevent a future brake imbalance.
* chock rear wheels, raise front of vehicle and place on stands.
* remove wheels, remove brake calliper and bracket assemblies.
* remove bearing hubs from axles, via removal of bearing adjustment nut
*remove hub seals, clean and inspect bearings, repack with HT bearing grease.
* the brake rotor bolts to the rear of the hub, you will have to remove and replace rotor to hubs, make sure all bolts are thread locked with loctite 263 and tensioned to spec.
* pack hub with grease, install seals, fitt hub assembly and adjust wheel bearing preload, install new split pins.
* fitt brake calliper and brackets, fit new brake pads,
* fitt wheels lower vehicle, test brake for function
Hope this helps..
Aug 02, 2016 | Cars & Trucks
Replace front wheel bearing
The front wheel bearing for your Impala is an integrated wheel hub/bearing/ABS.
The whole thing gets replaced. It should look like the one off my Bonneville; Bearing.
Remove wheel/tire. Remove brakes. Remove rotor. Remove axle nut. Press-out axle shaft*. Unplug ABS connector. Remove 3 bearing bolts.
*To press out axle, you may need a special tool from an auto parts store.
Don't forget to put the heat sheild back on during reassembly, and the axle nut need to be very tight.
After Bearing/hub removed:
Apr 21, 2011 | 2004 Chevrolet Impala
Front right bearing on my 99 hyundai elantra needs replaced. how hard is it?
IF IT IS DISK BRAKES, NOT HARD! JACK IT UP. REMOVE TIRE. ON BACK OF DISK BRAKE HOUSING IS TWO BOLTS. REMOVE THOSE, AND REMOVE DISK BRAKE SYSTEM FROM HUB. TAKE DUST CAP OFF HUB. REMOVE LARGE NUT. MAY NEED TO REMOVE COTTER KEY FIRST, THEN NUT COVER. FRONT BEARING, AND WASHER WILL COME OUT WHEN YOU WIGGLE DRUM. TAKE DRUM OFF, AND TURN OVER. REMOVE SEAL, AND REAR BEARING. YOU'LL HAVE TO GET A NEW SEAL FOR THAT PART. GREASE NEW BEARINGS, AND REPLACE THEM! THE NEW SEAL CAN BE TAPPED IN WITH A RUBBER HAMMER, OR HAMMER TILL IT IS LEVEL WITH THE RING IT GOES INTO! THEN PUT HUB BACK ON SPINDLE, AND REVERSE DIRECTIONS TILL IT IS COMPLETE!
Feb 20, 2011 | Hyundai Elantra Cars & Trucks
How to replace rear wheel bearing on 2003 hyandia sonata
Hub & Bearing Removal & Installation To Remove:
  1. Release parking brake.
  2. Remove rear wheel assembly.
  3. Remove rear wheel speed sensor from carrier.
  4. Dismount brake caliper and support with mechanic's wire.
  5. Remove brake disc.
  6. Remove 4 axle hub mounting bolts. Special tool 09432-11000 (Typical) hyundai-08-00-6021.gif
  7. Using tool 09432-11000 (or suitable gear puller), remove tone wheel.
  8. Remove carrier.
  9. Remove stakes and remove flange nut.
  10. Support bearing outer race flange and press rear axle hub out.
  11. Using tool 09432-11000 (or suitable puller), remove inner race from axle hub.
To Install:
  1. Apply thin coat of grease to bearing contact surface and hub.
  2. Using and appropriate tool, press bearing into hub. CAUTION
    Do not press against outer race of wheel bearing.
  3. Install flange nut and stake nut until it meets concave portion of spindle.
  4. Install carrier.
  5. Use an appropriate tool to press tone wheel.
  6. Install hub/bearing assembly with rounded portion of outer race facing up.
  7. Install 4 hub/bearing assembly bolts and rotate hub to seat bearing.
  8. Measure wheel bearing starting torque with a spring balance or equivalent device.
    • Starting torque should measure 15.9 in lb (1.8 Nm) or less
  9. Install brake disc.
  10. Mount brake caliper.
  11. Install rear wheel speed sensor to carrier.
  12. Install rear wheel assembly.
Oct 28, 2010 | 2001 Hyundai Sonata
Can you tell me if it takes special tools to remove the rear brake hub and brake line
No, there are no special tools required beyond everyday hand tools.
Raise the vehicle.
Remove the rear wheel and tire assembly from the vehicle If the vehicle is equipped with rear drum brakes, remove any retainer clips from the wheel mounting studs, then pull the brake drum off the hub and bearing.
If the vehicle is equipped with rear disc brakes perform the following:
Remove the two guide pin bolts securing the front disc brake caliper to the steering knuckle.
Remove the disc brake caliper from the knuckle and brake rotor.
Hang the caliper out of the way using a wire hanger or cord. Do not support the caliper by letting it hang by the hydraulic hose.
Remove any retainer clips from the wheel mounting studs, then pull the brake rotor off the hub and bearing.
Remove the dust cap from the hub and bearing assembly
Remove the retaining nut, then the hub and bearing from the knuckle's spindle
Oct 10, 2010 | 2004 Dodge Neon
Replace front hub assembly.
Replacing the front wheel bearing/hubs can be a big job for the inexperianced. Briefly...
Remove tire/wheel
Remove brake caliper assembly, do not remove brake line.
Remove caliper bracket.
Remove brake rotor.
Unplug ABS sensor.
Remove the large axle nut.
Press axle out of bearing (may need special tool)
Remove the 3 bearing bolts and remove bearing.
May 19, 2010 | 2003 Chevrolet Impala
Passenger rear wheel bearng needs to be replaced.does this require special tools? I've just had a complete brake job ,new pads new rotors new drums and I have a recurring grinding noise coming from the...
You can do this job your self with common tools. Auto zone carries the wheel bearing you need and can give you the step by step instructions to replacing the bearing. Here is a tip, to try to break the old wheel bearing from the axle. Just loosen the 4 bolts 3 mm that hold the bearing to the axle and put the wheel back on and drive the car back and forth a few times, hard on the brakes to break it free from the axle. Once the bearing breaks free from the axle, it should take you under 45 min to get the job done. Good luck and be safe.
Nov 17, 2009 | 2001 Toyota Corolla
Replace rear wheel bearing 2002 ford explorer 4x4
you must remove brakes, then remove axle nut, then remove upper control arm and finally tie rod stabilizer, remove axle from car then bearing can be accessed. this is a difficult job that requires special tools so be careful
Aug 15, 2009 | 2002 Ford Explorer
2005 impala
All the hubs on the car have the abs sensor built into the hub. The abs system has to be re set to read the sensor . The rear hub bearing if noisy should be replaced. There are wiring harnesses that connect to the abs sensor. The harnesses to each of the abs sensor should be replaced.
Mar 18, 2009 | 2005 Chevrolet Impala
Timken 2007 HA590092 Chevy Impala Rear Wheel Bearing & Hub Assembly Logo
335 people viewed this question
Top Timken Cycling Experts
John Egan
John Egan
Are you a Timken Cycling Expert? Answer questions, earn points and help others
