Question about AEG Cooktops
AEG ceramic hob heats up to full power by itself, no manual control.
I have an AEG ceramic hob, the largest ring is running up to full power by itself as soon as the power is switched on. I have tried resetting by switching off at the mains for 5mins and by holding the power button for 10secs, but the problem remains the same. Other rings seems to work fine and child lock will turn off the runaway ring. It's not practical to cook on the other rings with enlarge one up at full power, can anyone advise on a possible reason or (hopefully) fix for this?
2 Suggested Answers
Kgt1962
  • 59 Answers
SOURCE: Neff T1722SO Ceramic Hob - rings don't heat
Check the power supply to make sure it is getting 220V, the lights etc might still work if only getting 120V but burner won't without full power supply.
Posted on Mar 11, 2009
I have an EKI 807.2 Glass hob. I can't turn the heat up on more than one ring without E flashing on all the Rings followed by 6
Are you sure it is properly wired? For 1 phase 230v:
1= power earth
2-3 intersected = N
4-5-6 are L1-L2-L3 that should be conected together to L
Kuppersbusch is not very cooperative about what their error codes indicate, but E6 seems to be a (low) voltage issue, so you might too check the cabling to the outlet, measure the voltage with a multimeter when you successively switch on elements
Dec 22, 2015 | Kuppersbusch Glass ceramic induction hob...
Lamona ceramic hob
Ceramic cooktops need the correct type of pots or they leave marks,check your instruction manual.
Mar 11, 2014 | GE Cooktops
UNLOCK THE LOCK OF CHILDREN IN CERAMIC
Hi and welcome to FixYa,
I can not insert the symbols here to properly answer your question so, I found the manual and you can read the steps on page 9 here:
http://awadnahas.net/pdf/UserManual/bf7e9e9b-cc9e-46fc-94a7-5965a2d61b18.pdf
This is copy and paste from the manual and the symbols will not come out:
Switching off the child safety device
• Start the hob with ( ' ). Do not set the heat settings . Touch for (Up arrow) 4 seconds. The
symbol ( 0 ) comes on.
• Stop the hob with ( I )
The symbols I typed above are not 100% as they appear in the manual.
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | AEG HK955070CB 41 in. Electric Cooktop
Mar 08, 2009 | Neff Cooktops
Cant switch on hob
gud day,the ceramic hob is very sensitive to operate if u not read the manual.after u unlock the switch go to the control of the hob wat area u want to operate by touching the sensor then if u see the zero # touch again the area,positive side to increase the heat 1-9 the standard control heat.some model & brand have a different operational procedure,try to read the manual 1st or check the voltage of the unit coz the ceramic have a 4voltage standard for different country. tnx gerbee
Jan 26, 2009 | Neff 23 in. T1443 Electric Cooktop
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Aeg hob
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
Sep 29, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
Aug 27, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Cooktops Logo
66 people viewed this question
Top AEG Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you an AEG Cooktop Expert? Answer questions, earn points and help others
