Question about Checkpoint Check Point 2200 Appliance with 5 Security Blades - FW VPN Advanced Networking & Clustering IA & Mobile Access for HA CPAP-SG2205-HA
How to get serial number of checkpoint 2200 from ssh (command line)
Why 94 ranger 4.0 rpms 2200 take breather off rev up 2 times drops to 1700 1800 at 55 60 for a while then goes back to 2200 no engine light ?
The idle air control motor may be defective/sticky. The computer gives it a command but doesn't realize the motor is not following the command and therefore no check engine light. You can remove the IAC and try to clean it with carb spray
Apr 06, 2015 | 1994 Ford Ranger Supercab
Tip
Vmware enable SSH
If you want to do advanced features in VMware ESXi you will need to go into the core of ESXi to do this you can use Secure Shell or SSH. SSH is simplar to telnet but the data is encypted.
To enable SSH on VMware ESXi you need to enter an the ‘unsupported’ mode.
Step 1. At the physical console of the ESXi server press the Alt+F1 key combination.
Step 2. Type ‘unsupported’ and then press <Enter>. Note that nothing will appear on the screen whilst you type.
Step 3. When prompted enter in the ‘Root’ password and press <Enter>.
Step 4. You will now be presented with a prompt on the console. From this prompt type the following command
vi /etc/inetd.conf
Step 5. vi (the file editor) has now opened the inetd.conf file. Using the direction arrows scroll through the lines until you reach the line that has ‘#ssh’ and remove the hash (ie: #). This is effectively un-commenting this line so that the ssh service can be started.
Step 6. Now that you have made this minor file you want to save this change and exit out of the editor (vi). To do this press the ESC key (to put vi back into Command Mode) and then type ‘:wq’ *Note: If you want to exit without saving any changes to the file then just press the ESC key (Command Mode) and then type ‘:q!’.
Step 7. With the SSH service now un-commented from this file we need to restart out ESXi box to do this type in Reboot.
on Mar 31, 2010 | Computers & Internet
What is lg 800g serial number
electronic serial number video
Dec 18, 2014 | LG Cell Phones
I need to access my NetgearN150 from a command prompt as the GUI is not working can someone tell me if there are telnet or ssh commands available for this unit? The following lists the systems I am...
I think if you're using stock firmware you might be out of luck using ssh.
Still try telnet. (telnet IP address) if it was enabled before on the router (disabled by default.) If you have Win 7 you have to enable telnet in "Programs and Features/Turn Windows features on or off".
Find more info here.
Anyways - I would first try a 30-30-30 reset.
  1. Hold reset button for 30 sec.
  2. pull power whilst holding the reset button for another 30 sec.
  3. plug in power and keep the reset button holding for an additional 30 sec.
Let me know how that goes.
Aug 13, 2013 | NetGear Computers & Internet
I made a change in the firewall and now have locked myself out. is there a way to access the sg565 straight from the unit to a pc without using the url
yes that device uses a protocol called SSH which is a command line based interface.
from a windows machine I would recommend using "Putty" as an SSH program to work with(make sure to select SSH as the default is telnet under the host name which will be its IP in this case).
once you connect to the device and sign in you can type"enableweb"
and it will reset all ithe interfaces to allow webaccess again.
other than that a hard reset would work as well.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Aug 24, 2011 | Cyberguard SG565 (SG0186US) Firewall
Need serial number
If running Windows you can find you serial number via the Windows Command Line Interface (CLI)
HowTo:
Start --> Run --> CMD --> OK
at the ">" prompt type: WMIC BIOS get serialnumber
Notes and Tips:
Help! I don't see the Run Command at the Base Right of my Start Menu
Select the Windows Key 5efscqsiutc36pracwwi8vi8xg8fotfo1h4qiww+19xaygba7ieowaaaabjru5erkjggg== plus R together on the Keyboard
This will launch the "run" box , type in CMD {short for "command"} and click OK
now at the ">" prompt type: WMIC BIOS get serialnumber
and the return result is your machine serial number.
May 07, 2011 | Computers & Internet
My icons arent showing up after i ssh
Assuming that you are using the term "SSH" correctly:
SSH is a protocol used to remotely access the command line for a remote machine, usually linux.
SSH provides no direct way to share a desktop or any other graphical interface.
However, with a lot of configuration, it may be possible to use it to form a secure link by which you can open a VNC connection, which does share the graphical environment.
Mar 14, 2011 | Computers & Internet
Forgot password of Adtran NetVanta 1224R Switch
  1. Recovering passwords requires direct physical access to a unit. This procedure cannot be performed remotely over Telnet, SSH, or the Web GUI.
  2. Connect a straight through serial cable to the console port of the unit.
  3. Configure a VT100 session (i.e. HyperTerminal or ProComm) using the following settings: 9600 bps, 8 bits, no parity, 1 stop bit and no flow control.
  4. Reboot the unit by removing the power.
  5. As the unit boots, you will be given the opportunity to break into bootstrap mode by pressing the ESC key within 5 seconds.
  6. While in the monitor mode issue the following commands:
Bootstrap# bypass passwords
Bootstrap# boot
Notice that you are issuing the boot command not the reload command following the bypass passwords command. Once the unit has finished booting up, you can issue the enable command and you will not be required to enter the privileged (i.e. enable) password. Once you are in privileged mode, you can view the configured passwords by using the show run command. A new password can also be entered by going into global configuration mode by using config terminal command and issuing the enable password <word> command where <word> is the new password. Also remember to change any Telnet, SSH or Web GUI passwords if necessary.
Below is a sample output of these steps:
Router (1200990L1)
Executing bootstrap...
ram: 268435456 bytes of RAM detected.
Serial Number: LBADTNXXXXXXXXX
Bootstrap version: 11.03.00, checksum: 0F3C, Thu Feb 09 17:40:34 2006
vfs: NONVOL: 120 tracks, 128 sectors/track, 1024 bytes/sector.
eth0/1: initializing...
eth0/1: MAC address is 00:A0:C8:XX:XX:XX
bootstrap: Checking boot configuration...
bootstrap: Primary image is 'NONVOL:/NV5305A-12-01-07b-E.biz'.
bootstrap: User escaped to command line interface.
cli: starting command line interface...
cli: starting user interface
Press '?' for help.
bootstrap#bypass passwords
bootstrap#boot
Mar 20, 2009 | Adtran NetVanta 1224R 24-Port Ethernet...
Dell Optilex GX300 checkpoint [Vmgr]
Items in blue which are underlined are clickable to give more information about the process
Start the System Restore Utility at a command prompt
1. Restart your computer, and keep tapping F8 during the initial start-up until you get options, select Safe Mode with a Command Prompt then press enter.
2. Log on to your computer with an administrator account or with an account that has administrator credentials.
3. Type the following command at a command prompt, and then press ENTER:
%systemroot%\system32\restore\rstrui.exe
4. Follow the instructions that appear on the screen to restore your computer to an earlier state.
Look for the most recent system checkpoint created before the errors to restore from
For additional information about the Safe mode with a command prompt, click the following article number to see a description of the Safe Mode Boot Options in Windows XPthe article in the Microsoft Knowledge Base: 315222
Mar 06, 2008 | Dell Optilex GX300 (188TD) Motherboard
Checkpoint Check Point 2200 Appliance with 5 Security Blades - FW VPN Advanced Networking & Clustering IA & Mobile Access for HA CPAP-SG2205-HA Logo
187 people viewed this question
Top Checkpoint Computers & Internet Experts
David Payne
David Payne
Are you a Checkpoint Computer and Internet Expert? Answer questions, earn points and help others
