Question about LG Refrigerators
My electricity was disrupted due to an auto accident knocking out a power pole. When it came back on line a few hours later, the refrigerator cooling or freezing does not work. All panel lights, fan
Model number LMX25981ST. Rest on main board does not fix problem.
  • LG Master
  • 744 Answers
Hello Charles;
My name is Peter. I am a retired field service refrigeration technician.
In your owners manual, it is recommended that you have a surge protector on your unit. In fact, any appliance including your television, home computer requires a surge protector.
At your local Home Depot, Ect. you can purchase individual wall socket surge protectors for about $20.00. They are a well worth investment.
Your board reset button is not going to work. The power shut down and restarting surge blew out both your control board and control board capacitor.
As a field service refrigeration technician, I carried no less than 3 LG control boards in my truck. 65% of my service calls were LG & Samsung. The fewest service calls I had were Amanda & Kitchen Aid, follower by GE and Kenmore.
Anyway, You need to replace both the control board (Part Number LMX25981ST - $122.00) and your control board capacitor (Part Number OCZJB20146 - $27.00).
You can get a lower price searching on the internet.
You have already accessed your control board.
My electricity was disrupted due to an auto accide - 25295852-woc4ugcs3z1jzdp4nx0pn5hc-5-0.jpg
So, lets replace the control board and capacitor.
1.) Un plug your unit.
2.) First ground yourself, static electricity will nock out your board. Rub your hands across something that is steel. Do not wear wool clothing.
3.) Your new control board will come in a anti-static silver bag.
4.) The control board is held in by several white pins. On the two sides of these pins are clips you must squeeze in to pull the board out.
5.) Systematically, remove one connector from the old board to the new board. The connectors have a locking tab at the top, squeeze the tab to remove. When inserting on the new board make sure these clips are locked in.
6.) replace the capacitor next to the board.
7.) Reattach the control board cover plate. Plug your unit back in. Allow 24 hours or less for the unit to balance the high pressure (160 PSI) liquid and the low side (65 PSI) vapor side.
Posted on Nov 25, 2014
Testimonial: "Peter, thank you for your response and I will be following your instructions. You sent me the Model number rather than the part number for the board. Do you have the part number for the control board?"
  • Peter Goodwin
    Peter Goodwin Nov 27, 2014
    Sorry, the control board part number is EBR41956401
  • 183 Answers
SOURCE: samsung rs2578sh
Yes, you have a faulty defrost heater or thermal fuse, the fault will re-occure within a few weeks. Regards Advisor
Posted on Aug 23, 2007
the dr
  • 447 Answers
SOURCE: Side by side stopped working but clicling noises every second two.
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Posted on Dec 02, 2007
hotuna
  • 288 Answers
SOURCE: Kenmore Elite refrigerator stops cooling - Relay keeps cycling
The compressor is locked up. Basically it is stuck. You can pick up at the local appliance parts store a hard start relay, Home Depot ,Lowes, or or those guys wont have it. Its not too expensive and is worth trying because your only other option is you need to replace the compressor. The part is called a kick start or hard start, the guy at the parts store will know what you are talking about. It is simple to connect and has the wiring directions on it. Sometimes this is all it takes. I have been able to get a stuck compressor to go by placing a short 2x4 on it and whack it with a hammer a few times. This is only a temporary fix though, as it will eventually lock up again, but emergency situation this saved the food. If the fridge has a fan back there make sure it works too, it may have been the original cause. Good luck.
Posted on Dec 26, 2007
PABLOCSA
  • 1124 Answers
SOURCE: Ice and water dispensing problem; compressor shuts off when paddle pressed but dispensing is sporadic
The ice remains stuck between the dispenser and the top of feeding ice. This respond to a broke rubber on the last section where the ice must be delivered. Replace the rubber will fixed the problem. It is a common problem on this kind of devices. To remove the ice simply move the stuck ice from the bottom oro yu can try putting some warm water from the top. Before to do nothing, unplugg your refrigerator first.
Posted on Oct 11, 2008
Sea Breeze
  • 4654 Answers
SOURCE: evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Posted on Aug 05, 2009
Hi! My LG Refrigerator gr-L247 after a power shortcut of around 3 hours it is not working.
I have read stories of some tv's doing the same thing after the power is cut off and you have to wait for a few hours for unit to "reset" itself. Contact LG for their feedback on this. Could be an issue with the electronics of unit.
Aug 22, 2016 | LG Refrigerators
Whirlpool WRF560SEYB Refrigerator did not turn back on after power outage, display said "cooling off"
Sounds like you had a power outage?-- did the lights go dim for a few minutes, before the power actually went out?-- Sometimes, low voltage will cause the compressor motor to over heat-- so it might have to 'cool down'-- What happened next?-- Did you try it again an hour or so later/-- Tell us more-- Mack B
Nov 03, 2013 | Whirlpool WRF560SEYB 30" french door...
E had a power outage due to a storm blowing trees down on power lines. When the power returned, about 4 hour later, the refrigerator/freezer (side by side) was making a loud buzzing noise. The ice maker is...
This sounds to me like a busted compressor, nothing more you can do to it. You must call a repairman to test it and replace it, a very delicate procedure that requires specialized equipment.
Jun 21, 2010 | Frigidaire FRS3R5EMB Side by Side...
Back of freezer is frozen but everything in the freezer is thawing out.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 20, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Fridge working but not cooling.
The white component you see , is the problem . That is the overload/relay . These short due to power surges , dirty coils in the front bottom of refrig , or just by age . They short , to save the compressor , when one of these happens . The part number you need is # 8201786 . This part just prys off (maybe one wire clip ) , easily replaceable with instructions included with the part .
Sep 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Dometic rm3862 refig. not cooling .
It sounds like the interior fan has stopped. It should be located behind freezer back panel. Pull out the screws and have a look. Hope this helps. Good luck.
Jul 07, 2009 | Dometic RM2652 Refrigerator
Accidently started clean, food inside,hit cancel,can't open
you would have to disassemble the cook top in order to get the the locking mechanism to manualy unlockit
May 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Auot defrost problem?
cleaning the condensor is nothing to do with evaporator freezing up. keep an eye on it - you may have a problem with the defrost cycle. problem can also happen if freezer door has been left open
Jul 21, 2008 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
186 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
