My vizio e470vl was working fine til cable got installed. Went blank about an hour afterwards. Took to a shop and they said main board. Bought one, now just the orange light when plugged in and white light when suppose to be on but no picture. Could it be the power supply board?
    Champion:
  • 209 Answers
Rather than you trying to figure it out, the shop you took it to should have diagnosed the problem.
Posted on Nov 24, 2014
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
Posted on May 04, 2009
Raditronic
  • 196 Answers
SOURCE: plugged in orange light turno on vizio light is white no picture
possibly is the main board.
Posted on Apr 30, 2010
ginko
  • 19396 Answers
SOURCE: VIZIO GV42LHDTV Got TV after
Hi.
If the TV does not start with the new audio board, and if it does start with the old one, then the audio board that you recently purchased is defective.
About the board : 0500-0507-0230; that is the power board (PSU). If you could see the Vizio logo, that means that TV started, and that the power board was OK without need for testing. When the power board is defective, either the TV does not give any sign of life, or the TV goes in standby mode from start and does not wake up. In that case the led stays blinking to warn you that there is an incorrect voltage from PSU.
If the TV is freezing with Vizio logo, that means that at most the faulty part is the main board.
Also, you say that there is no backlight. No backlight means that the screen is completely dark. If there is no backlight you won't be able to see the logo or any other picture.If there is no backlight, then the problem is usually the inverter.
Here a brief article summarizing how to test PSU and inverter: How to test an LCD TV.
Here all parts for this model:GV42LHDTV.
Regard.
Ginko.
Posted on Feb 11, 2011
SOURCE: model e470vl cable from power supply to main board
Are you needing a replacement?
Posted on Nov 19, 2012
Vizio E470VLE HDMI inputs not working
its the antanna don't go on your roof you probs bumped it
Aug 31, 2016 | Vizio E470VL 47 in. HD-Ready LCD TV
Vizio Model E470VL, HDMI ports are not functioning properly.
on some TV's the Analog board is where the other cables plug into. I know on a Sanyo I am working it looks like the analog and main digital board are all the same. but they are just hooked together. I bought an analog board for less that $30 from Shop Jimmy.com. The prices might vary according to the make and model of TV. need to be careful and remove the back of the TV . and get the part # directly off the board. BE SURE TO UNPLUG from the wall outlet first. Nearly all the boards carry a charge even when unplugged so be careful.
Nov 18, 2014 | Vizio E470VL 47 in. HD-Ready LCD TV
My Samsung DLP HLR5667W went blank. Just before it went out, I was unable to control volume/mute. I replaced the lamp ($175 a Walt's ripoff shop) and the TV worked for four hours then died again
I would guess that it could be the main board going bad. Check all our connections and wiring. You should call places like Tri-State Module and they can probably send you a part or repair for way less than 500 bucks.
Mar 31, 2013 | Samsung HLR5667W 56" Rear Projection HDTV
Vizio E470VL with no sound after main board replacement
No, your video and audio processing should take place on the same main board.
Feb 12, 2013 | Vizio E470VL 47 in. HD-Ready LCD TV
Fuse locations vizio e470vle
The fuse will be located on the power supply board. The power supply board is the one that the power cord plugs into. The fuse should be close to where the power cord plugs in at.
Dec 06, 2012 | Vizio E470VLE 47 Class Widescreen LCD HDTV
Vizio 47
It sounds that the main board has got faulty. Seek check support.
Jun 07, 2012 | Vizio E470VL 47 in. HD-Ready LCD TV
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
