Just pressed the button, it used to work?
Hello Colin;
My name is Peter. I am a retired field service appliance technician.
There are many different dryers with different electrical components.
You may have a hot air circulation problem. This is common where lint will block the air flow. You have a hot air distribution manifold, remove the manifold. At the smaller bottom is where the fan wheel discharges, this is where dryers usually plug up. The manifold is located where the hot air fan discharges air. Also, check the fan to make sure it is not plugged up and turns freely.
Needless to say unplug your unit first.
It could be a bad thermostat, and several other things.
If your unit is not plugged up with lint, please post again and provide a model number so I can see what you have
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
