Question about Coleman Quad LED Lantern
How do i change the batteries on a led quad lantern
I received a 21 LED lantern for Christmas and got the 3 "D" batteries and the thing glows at what should be shut off point. They only way to shut it off is to remove the bottom plate. Is this normal
Turn clockwise and counter clockwise the lantern.(The upper side leds)
If not check the pin of switch that makes the contact to the upside.
Jan 01, 2015 | Ovens
How to change the battery for my 4345 coleman lanterne
There are two adapters for that lantern; one for the house and one for 12volt. You simply connect one of the adapters and it will power the lamp and also charge it. Those two adapters came with the lamp; if you don't have them you can contact Coleman to purchase replacements.
Jul 29, 2014 | Coleman 8D Family Size LED Lantern -...
I need to change the battery on a Highgear LED Fuse Micro lantern model #10084HG
It's easy once you figure it out. Unscrew the top and then push down on the exposed screw threads with your thumb. The internal "guts" slide out the bottom.
Feb 12, 2014 | HighGear Fuse Micro Lantern, Red
Hi- I have a Nexxtech LED Lantern that is no longer turning on.
Have you checked that the batteries are seated properly?
Sep 15, 2017 | Camping, Backpacking & Hiking
I purchased a lantern model # jasco 17300 and the light quit working after 6mos use
You may get it repaired but the cost will be the same as buy a new one or much more than get a new lambp. So I suggest you purchase one from online store:
http://www.aurabuy.com/outdoors-76-led-ultra-bright-waterproof-headlamp-with-adjustable-band-black-silver-4-aa.html
Mar 26, 2013 | Camping, Backpacking & Hiking
Rayovac 360 sportsman lantern wont work
Since batteries and bulbs are new/ok, check for a bad connection. In older version using 4 lantern batteries, open the battery compartment by unscrewing the knob on top of lantern. The lantern bottom comes off once unscrewed (of course you did this to change batteries). There is a "C" clip on the lantern center shaft; remove this by prying with screwdriver or with pliers. Carefully raise the battery contact plate and check slip-on wire connections. Clean as needed (Scotch-Brite works well) and reconnect. Squirt some contact cleaner in exposed switches, work switches back and forth. Inspect circuit board for obvious corrosion or damaged parts (this damage may "total" the lantern). Re-install plate aligning grooves with ribs. Install batteries and test.
Nov 01, 2012 | Camping, Backpacking & Hiking
Swissgear rechargable lantern won't light up, even though the green led light indicates it is fully charged
There are several different models of the Swiss Gear rechargeable lantern. On most though, you can remove the top portion of the lantern and check the lighting element inside. In most cases the elements can be removed and replaced. I have a dual filament lantern and from experience I know that every so often you may have to go buy a replacement light piece. If the lantern has been bumped or even just strapped to the outside of the pack while walking, it's possible for those elements to become loose and need repositioning or replacement so do check that. I'm sure that it should be unlikely your charger is malfunctioning unless you left it plugged in for some very extended period of time, in which case I would say the light would be more likely to burn out. But definitely try that and if that doesn't work the battery pack on the lantern itself may have an issue in which case you can always get a replacement.
Aug 29, 2012 | Camping, Backpacking & Hiking
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Oct 24, 2010 | Sport & Outdoor - Others
Rechargeable Camping Lantern
you need to coldsolder the pc board.
Apr 09, 2008 | Dryers
Ac power adapter
Both at Walmart and Radio Shack you can find universal adapters that allow you to change the connector and voltage to fit the device. Try one of these, you can usually pick one up for under $10.
Nov 26, 2007 | Computers & Internet
Coleman Quad LED Lantern Logo
475 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
weirdtop
oldhess
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
