Question about Samsung Cell Phones
HOW DI I CONNECT MY HANDSET HF-1000 TO A SAMSUNG PHONE
  • 30 Answers
To pair the headset in manually pairing mode:
1. With the headset off, press the center POWER button for 7 seconds until you see the headset blue light turn solid blue (no loneger flashing).
2. The indicator light will turn solid blue, which indicates that the headset is in "Pairing mode".
3. In the phone, you now have to add the headset to the phone's list of Bluetooth devices.
4. You have to enter a Bluetooth passkey in the phone. The default passkey is 0000.
These directions apply to a lot of different bluetooth headsets. If "0000" (four zeros) does not work, try "0001" (three zeros and a one) or "1234".
Hope this helps!
Posted on Nov 24, 2014
  • KARL JOHN
    KARL JOHN Nov 24, 2014
    Thanks for the assistance, the directions has worked.
Why has the phone reversed, dial tone works only when phone is hung up why?
If I understand you correctly, when you leave the handset in the cradle and press a line, you can hear the dial tone. But, if you lift the handset and then select a line you don't hear anything through the headset. If this is correct, I suspect the handset is damaged, the cord is damaged, or if you're lucky, the clips may not be plugged all the way in on both sides. If you have another phone that is the same, you can switch handsets to test this theory.
Oct 19, 2014 | NEC 22b Hf Aspirephone-bk Stock No....
I have a samsung hf 1000 which speaks to me in chinese but i need it in english, any ideas please?
I did this to my HF1000 Handsfree device this evening as I had mine in chinese language as well today.
Power up the unit the vioce will say power on, wait for silence then push and hold the Call button, the unit will speak the pairing instructions including the pair code of 0000. regardless of the language the voice will repeat the number four times, so even thought you might not understand it, you will hear the number repeat....
After a brief silence period, press and hold the call button again, the next announcement is the language selection menu. After the announcement press the Volume + (plus) button to change the langauge, this announcement is quite long. Wait for each announcement (they are maybe two full sentences long).
Press the plus (+) Volume button to again to change to the next language, wait the appropriate length of time and press the plus Volume key again, for the next language....
Chinese language is directly after English, and so you need to go throught the key press sequence about I think five times. English, then Chinese, Italian, Spanish then German, is the sequence I believe.
Hope this helps!
Oct 08, 2011 | Samsung HF1000 Bluetooth Headset
Need instruction manuel for Samsung HF 1000
Just turn on, the speaker will say " power on" then go to your phone, go to setting on phone till you reach blue tooth settings, turn it on, it will now discover available Bluetooth , now go back to HF 1000 bring them closer, now press and hold the call button on Samsung HF 1000 till you hear speaker say paring, now look at your phone, you will see HF100, click and you are all set !
Sep 18, 2011 | Samsung HF1000 Bluetooth Headset
I get Warning! use rechargeable batteries only. But they r rechareable, and changing them doesn't help
Reboot the base :
-Make sure the handset is HF and not on the base.
-Disconnect the base from the power supply and remove the batteries (only the base's, don't remove the handset:s batteries), soon, after a few seconds at most, the handset not finding the base when scanning for it, should go off by itself.
-Wait a moment (60 sec should be plenty) then reverse the last step (batteries+power-supply).
When reboot is completed (watch for the normal screen on the LED display) just put the handset back on the base again, 'voila' !
Sep 04, 2011 | AT&T E5965C Cordless Phone
I cant connect my samsung S5233 to my laptop
Hi
Please let me know how are you trying to connect your phone through the cable provided with the phone or through bluetooth?
If you want to connect your Phone with Laptop via Bluetooth, you need to have a Laptop equipped with bluetooth facility built-in, through which you can pair your handset with the handset bluetooth and transfer files.
Else if you are trying to connect it via the cable provided with the phone, you can set your handset connectivity to USB mode and check if your laptop recognizes your phone as a USB device or not, in case it doesn't then you need to install the Samsung PC Studio software which came with the phone and then you would be able to connect your phone to your laptop
Dec 02, 2009 | Samsung Star GT-S5233 Cell Phone
Error 734 ..ppp protocol terminated in .Aircel pocket internet
dear Sir,
I have the mobile handset samsung GM S 3310. I am usuing Aircel Pocket internet in this phone. Surfing net is not a problem from the handset , but unable to connect it to my laptop.
Before dial up, it gives :error 734 ..ppp links protocol terminated. Therefore I Can not connect pc to handset as the dial up connection is not established.
Oct 28, 2009 | HTC S710 Smartphone
A cannot connect my samsung sell phone M330 with PC. I already installed Samsung PC studio 3 and usb driver, but PC studio is not connecting with phone.
According to Samsung, neither the m330 nor any CDMA phone works with PC Studio:
"Samsung does not offer a Data Kit software package for the purpose of transferring data between the handset and a personal computer or for using a Sprint handset as a modem for a personal computer." Unfortunately, PC Studio is not compatible with any CDMA handset." So we're out of luck, unless someone has a hack. Anyone?
Oct 26, 2009 | Samsung Gravity SGH-T459 Cell Phone
I want to unlock my phone
*I recommend backing up your phone's data before doing this"
EEPROM reset code: *2767*3855#
Without sim, power on the phone and where it says "insert sim" enter the code above.
Please beware that doing this reset will erase ALL your data.
Works on D500 and U900 so it should work with your handset.
This code as well as clearing the data off a handset can also remove the sim restriction off some Samsung phones.
Hope this helps
Regards
Ronnie
Feb 14, 2009 | Samsung SGH-D600 Cellular Phone
Main handset won't work; additional handsets do.
Check that you have the larger power adaptor connected to the base unit.
May 16, 2007 | Doro 530 Twin Cordless Phone
Cell Phones Logo
48 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
