Question about Toys
Why does the trans pressure system light keep coming on.
  • 4,339 Answers
I have no idea what toy would give that message. A vehicle giving that message, however, would be not good at all. A transmission requires pressure to full engage clutch packs. IF you do not have correct pressure, you will destroy the clutches. Stop operating the unit until you resolve this issue.
Posted on Nov 24, 2014
I have a 2001 Saab 95 3.0L transmission warning light comes on while driving. There is no acceleration when I press the gas, but the rpms increase. Trans fluid is good, not sure what's going on.
You don't say the mileage but even though the oil level is good the trans needs pressure from the internal pump to operate the clutches etc. there are usually pressure tap points on the casing. A trans shop would be able to check.
Feb 17, 2016 | Saab Cars & Trucks
Check trans keeps coming on and trans over heating fan consantly runs
The lights come on because a trouble code has set in the transmission control. If you want to know why the light is on, you have to get the codes read. I would contact the trans shop that performed the service and advise them regarding the issue. There may be a correlation between their recent service and the current problem, and the suspicion of this is completely legitimate.
Jan 19, 2014 | 2003 Lincoln LS
I have a 2004 ford explorer and the o/d light keeps coming on. I took it to advanced auto and put it on the machine and code p1744 came up what in detail does that mean
This has to do with the Torque converter. It can be a bad connection, a bad electric solenoid inside the trans, or a bad torque converter. Sometimes a pressure check is necessary to determine the exact problem.
There are a few solenoids which can be changed during a trans fluid and filter change. Sometimes it is just a bad external wiring connector.
A little money spent for pressure testing may save an unnecessary trans replacement.
Aug 21, 2013 | Ford Cars & Trucks
Will make dodge trans temp light o d off
Run fault codes and look for a servo/sensor fault in the od section of the box. If the od band/clutch is slipping it will cause the oil to over heat. Have a pressure test done on the box to ensure proper operating pressure. Check for correct oil level in the gear box.
Aug 17, 2013 | Cars & Trucks
Service engine light keeps coming on. Shows pressure sensor is bad ?
You have to have, all vehicle problems involving any
OBD2 light on the dash,checked out in a couple of
days. Don't keep driving it,you have a possible
system malfunction
Need the code to give you ideas
Just get it checked out
If it is a transmission problem, I wouldn't even drive it.
I have owned a trans repair business and I own a 2004
LS V8.
Feb 21, 2011 | 2005 Lincoln LS
Transaxle light keep coming on
is the light that comes on a flashing yellow gear shaped symbol?
If so this happened to me about 10 mins after starting and driving my car. It didn't seem to affect how the car ran or changed gears. You could stop shut the car off and start it right back up and it would take about the same amount of time for the light to come back on. I bout a transmition code reader and it came up trans pressure control soleniod. Depending on the type of trans your car has they only ranged between 25 to 95 $ for the part.
The best thing to do is go to a trans shop and have them run the diagnostic codes. Hope this helps a little
Apr 03, 2010 | 2001 Ford Taurus
1994 Lincoln Contiental DCL warning light keeps coming on.
uve entered the computer universe-my condolences--today everyting is connected in almost an imposible logic-u have an OBD 1 system-before 96-go hav car scanned to obtain a data stream to translate the codes that may appear-repair manuals explain these
Sep 08, 2009 | 1990 Lincoln Continental
I have a 2002 Maxima 6 Speed Manual Trans. Under Heavy Acceleration the check engine light blinks several times and then goes off and stays off during normal driving. The light seems to come on as I hit...
U have an ignition related problem, have the system tested for the trouble code that is stored in memory any time the check engine light comes on to determine what is causing this issue. check engine lights have nothing to do with oil level or pressure, they indicate electronic control problems with the engine, trans or emission system.
Jul 07, 2009 | 2002 Nissan Maxima
Brake light, abs light will not turn off have had checked
the ! light is for the tpms system or tire pressure monitor system, check your tire pressures, all should be @ 35 psi- if this doesnt corect it then there is probably a bad tpms sensor
May 11, 2009 | 2003 Ford Windstar
Trans light comes on and then it won't shift into low
Sounds like either the range sensor is not properly adjusted or the kick down cable is not adjusted right.If the cable is not adjusted right early failure of the trans will happen.So if you can have them scan the van and see if the range selector which tells what gear its in is right and make sure the drown shift cable is adjusted right because thats what controls your shift pattern and controls and pressure to the trans.I hope that this helps you.Have a great day..
Mar 31, 2009 | 2000 Dodge Durango
Toys Logo
41 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
