Question about Whirlpool Washing Machines
Wanting to know how many kilo's the heavy duty super capacity whirlpool washing machine can handle. serial no. 3xla87w72b
Tried google, gumtree, and olx looked on the back of the washing machine.
  • 29 Answers
4.6
Posted on Nov 24, 2014
SOURCE: washing machine leaks
Go to fixitnow.com to find out how to remove cabinet. If it's a big leak it's most likely a hose; if a little leak, more likely the pump. Both easy to replace once you have cabinet off.
Posted on May 14, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Posted on Jul 23, 2009
  • 401 Answers
SOURCE: my Whirlpool washer is not washing or spinning
This sounds like the motor coupler has broken.
Posted on Jan 03, 2010
  • 10865 Answers
SOURCE: Find serial and model number
Hello. for a top loader look here
  • Under the lid
  • On the back of the control panel
  • On the lower-front or side of the main cabinet body
  • Posted on Apr 30, 2010
    jsrock516
    • 5911 Answers
    SOURCE: water leaking during rinse cycle
    If your TOP LOADING Whirlpool washer is leaking, the following link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak:
    http://www.fixya.com/support/r3576648-washer_leak__top_loader
    If the leak is more like a constant drip, a common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damaged, must be replaced. The following link explains how:
    http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
    Don't forget to check all drain hose connections under the washer and the center tub seal.
    Replacement parts (if required) can be purchased at any of the following websites:
    searspartrsdirect.com
    pcappliancerepair.com
    repairclinic.com
    Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
    If you have any questions, please post back and let me know. I hope this helps you.
    Posted on Jul 05, 2010
    Whirlpool heavy duty super capacity plus LSR 7233 EZO
    Most likely, the legs on the machine aren't level, causing it to move during operation.
    Jun 12, 2012 | Frigidaire Washing Machines
    Just trying to find out drum capacity of my maytag heavy duty super capacity 7 cycle washer. Please help
    Check the tag where you find the model and serial number, they often list it there. Your owners manual should tell you as well. You might have to call whirlpool (maytag), I cannot find the capacity listed on the tech info. Good luck.
    Sep 23, 2010 | Maytag LAT2600A Top Load Washer
    I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
    My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
    Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
    Normally on top load machines open the lid and look toward the back hinge area inside the lid. It is usually on the back there. It may also be posted on a white sticker on the back of the machine.
    Apr 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
    Lid switch
    You will have to remove the back at least on the dryer , should be able to see up in there the switch and the 2 wires connected to it, yes just twist them together when you find them
    Aug 22, 2009 | Washing Machines
    Whirlpool heavy duty super capacity washing machine...The water works and then all of the sudden its like a water hammer and the water shuts off, then you have to fiddle with it to make the water flow...
    on some of these models if you only want cold fill,it will also bring in hot water as well,if the cold water is below a certain temp.turn off the hot tap when you want to wash in cold only and see if this helps.its hard to know without being there.
    Mar 13, 2008 | Washing Machines
    Washing Machines Logo
    53 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
