Question about Baby Gear
<!-- from fixya rte -->Tempur-pedic seating TP4000 manual - Baby Gear
3 Suggested Answers
SOURCE: tempur-pedic remote control does not
If the solution posted by Susan R. (below) fails to work, locate the black power down box under the bed. Check the battery compartment and remove all batteries. If batteries are installed they will prevent a full reset of the box. Unplug the power cord, wait 45 seconds and plug the power cord back in to reset the electronic components. Replace batteries. Now that the error has been wiped from the box's memory, you can now synchronize your remote with the power down box using Susan's instructions below. - Mike V., Antioch, CA
"Locate the power down box for the bed and press the "learn button" for 1 second and release (Black box under the bed). On the hand control, simultaneously press and hold the position 1 and off buttons. The transmission indicator light will flash slowly and then flash rapidly. Continue to hold for 5 seconds and then release the buttons. It should now work! Enjoy. Susan R., Paducah, KY"
For further assistance, refer to the user manual that came with your TEMPUR® Advanced Ergo System™ or you can download it here.
http://www.tempurpedic.com/media/Ergo_System_Complete_Ref_Guide_FINAL_022008.pdf
For phone assistance please contact a Leggett and Platt representative at 800-888-3078. Leggett and Platt is the manufacturer of the adjustable bed and remote components for Tempurpedic.
Posted on May 18, 2009
  • 29 Answers
SOURCE: What is the difference between Tempur-pedic mattresses and other brands of memory foam mattresses?
Tempur-pedic is a type of memory foam. They are a brand name distributer of memory foam products. They have reached a level of popularity now, which consumers refer to their product as a brand (similar to Kleenex).
Posted on Jul 25, 2012
How much weight support according to specifications
(You didn't say which chair.) From a warranty sheet that came with a chair: "Warranty is limited to normal usage, not exceeding 40 hours per week and 250 lb. weight."
Tempur-Pedic seating (Raynor Group), model TP4100 chair. $300 (December 2015).
Cheaper chairs can have lower ratings.
Nov 18, 2015 | Furniture
The height-adjustable seat back of my chair tends to fall down, as if it is too loose. Is there an adjustment to tighten this?
The "softness" is similar to shock absorbers in your car. They get tired with time. Most likely you will need to replace those parts. Or a lightly used replacement may be more cost effective.
May 06, 2015 | Tempur-Pedic TP8000 Ergonomic Mesh...
How do I lower the back?
To lower the back, lift it until it stops firmly. Now let it fall all the way down. (It might need a little push to go all the way down.) To raise the back, lift it slowly until it clicks once. Each click is a height setting; it will stay at that height. Repeat until the back is high enough. To go back down, start over.
(This definitely applies to Tempur-Pedic TP4100 Office chair.)
Nov 01, 2014 | Tempur-Pedic TP4000 Ergonomic Fabric...
How do I lower the back of my chair
Sep 09, 2014 | Tempur-Pedic TP4000 Ergonomic Fabric...
How to adjust the back of the chair?
To lower the back, <b>lift</b> it until it stops firmly. Now let it fall all the way down. (It might need a little push to go all the way down.) To raise the back, lift it slowly until it clicks once. Each click is a height setting; it will stay at that height. Repeat until the back is high enough. To go back down, start over.
Jul 01, 2014 | Tempur-Pedic TP4000 Ergonomic Fabric...
The bed is stuck with head up can I manually lower the bed
We have a Tempur-pedic. Each side is controlled by its own remote. It also has battery backup for each side (head and foot) in case the power goes out. We simply push a little button on the battery controlled box on whichever side needs lowered. It works to lower them, but they cannot be raised in a power outage. If you don't have something like that, or a manual crank or something, I suggest you call the company and ask THEM what to do. If it's stuck with the power still on, then even more reason to call the company.
Apr 23, 2014 | Ergomotion Furniture
Seat sloped too far forward
You need to be sitting in the chair and the middle lever is the one which releases and secures the angle. I find the adjustment is easier if you release the backrest lever, the third lever to the rear, lean back in the chair which will raise the front seating cushion while moving the backrest back. Using you feet on the floor push back in the chair until the seat feels better. When it is at an angle you like, push the middle lever down to lock the seat in place. Then adjust the backrest with the third lever.
Apr 08, 2014 | Tempur-Pedic Furniture
Jul 25, 2012 | Furniture
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
