Question about 2006 SORENTO LX Sunroof Motor
How do i replace the fuel level sending unit on a 2006 kia sorento lx
I need to know how the unit comes out of the tank
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 108 Answers
There is either a compression ring or some screws on the fuel pump.
compression ring - use flathead screwdriver and hammer to lightly tap ring to unlock
Posted on Nov 24, 2014
How to replace the fuel pump in kia sorento 2006
It is inside of the fuel tank, you have to remove the tank from the vehicle to access the fuel pump.
Sep 28, 2014 | 2006 Kia Sorento
I have a 2005 kia sorento lx and have been have problems with really poor fuel consumption. I'm losing about 80 miles to the tank. I had just changed the spark plugs and gotten a tune up
the fuel sender unit needs replacing as is reading lower than what is actually in tank from whay you've said so far, if your basing your MPG on the gauge reading it will be way out , best way to check MPG fill tank, drive for say 50 miles,, refill tank and see how much you have replaced, that will be your MPG
May 26, 2014 | 2005 Kia Sorento
How do i replace the fuel level sensor on a 2005 kia sorento
What You'll Need:
  • flat head screwdriver
  • Phillips head screwdriver
  • hammer
  • open end wrenches
  • replacement fuel tank sending unit
    Before you begin, disconnect the negative battery cable to be sure no electrical sparks are possible. You're dealing with gas which is highly flammable!Your fuel tank sending unit is located in the top of the fuel tank, but is accessible under your back seat (or under the carpet in your trunk) on some models. The sending unit will be protected by an access cover, usually held on with a couple of screws. Lift your back seat or trunk carpet and locate the access cover for your fuel tank sending unit. Remove the screws holding the cover in place and remove the access cover to reveal the fuel tank sending unit.
    Safety Note: Gasoline is highly flammable. By removing the fuel tank sending unit, you are opening the gas tank. Be sure there are no sources of spark or flame nearby.
    With the access cover removed, you'll see the fuel tank sending unit right there on top. It will have a wiring harness plugged into the top (this tells your gas gauge how much fuel is in the tank). Unplug the wiring harness and move it safely to the side. If your fuel tank sending unit is screwed or bolted in place, remove the screws or bolts. Some sending units are a "twist-lock" type. They work like the old twist-lock gas caps. You'll see a few notches along the outer ring of the sending unit. Place the tip of a sturdy flat head screwdriver in the notch and gently tap it counter-clockwise. The sending unit will rotate until it's loose. (the picture above shows the fuel tank out of the car to illustrate the fuel tank sending unit's location). Now you can remove the fuel tank sending unit in one piece. Attached to it is a long rod with a float at the end, so you might have to try a couple of different angles to get it out. As usual, installation is the reverse of removal. Don't forget to plug the new sender in or it won't send you anything!
Jun 22, 2012 | 2005 Kia Sorento
Gas light is stuck on and shows empy, even though there is a 1/2 tank of gas.
You need to replace the fuel level sensor that is parted with your fuel pump assembly. Before assuming this, we want to make sure fuel sensor connection is fully connected and seated. You can locate the fuel pump via the rear left passenger seat. You need to pull back the backseat, and there is a sqaure carpet panel, open this... and you will be able to see some wiring that goes into a cap. Check these wiring if there is any dirt, corrosion or maybe loosen. If everything seems fine, then definitly your fuel level sensor needs to be replaced, It either stuck at the half tank indiactor, or damaged. For a 05 sorento, If you decide you want to replace this, I recommend you to change the entire unit, about 250.00+ for a new unit includes the (fuel filter, pump, and level indicator). If you need direction or help installing it, I would be gladly to help.
Jan 25, 2011 | 2005 Kia Sorento
Fuel gauge reads low when the tank is full
Defective fuel sending unit. There is something going on with the sending unit in the tank, sounds like the level sensor arm is stuck in the down position or has come off.
Check it and tell us news.
Jun 03, 2010 | 2004 Kia Sorento
Where is the Fuel Filter in a Kia Sorento 2004 LX
THE FUEL FILTER IS IN THE FUEL TANK, THERE IS An ACCESS PANEL UNDER THE REAR SEAT CUSHION.
Sep 15, 2009 | 2004 Kia Sorento
2003 Sorento EX 2WD Fuel level indicator problem.
the guage on the dash should not be bad it is more than likely the sending unit in the tank you will have to drop the tank and replace the pump. befor tearing anything down make sure the pump is plugged up and that it has a good ground.
Aug 29, 2009 | 2007 Kia Sorento 4x4
2006 SORENTO LX Sunroof Motor Logo
79 people viewed this question
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Randy Ohler
 Mikey
Mikey
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
