Programming/ need a manual for the above transfer switch and the Kohler 12RES-I3C1 generator
SOURCE: Electrical cable size requirement
This is an answer to your question only. The safest thing to do is hire an electrician to do it. There may be factors you don't recgonize that a skilled eye would pick up on.
The proper size wire is #4 copper or #3 Aluminum. THHN is the most common and most versatile type in conduit. a #6 ground wire is ok. Stranded pulls a lot easier than solid and do yourself a favor and buy some wire pulling lubricant just in case.
Make sure to obey all manufacturer's instructions. If you use aluminum make sure to place anti-oxidation compound or Nolox on your lugs in the panel. Please write back with anymore questions.
SOURCE: Kohler 12res AC breaker flipping with no error listed
wat size c/breaker
6600 divide 240 = amp
rule of thumb
SOURCE: Can some one tell me what oil and air filter to
Kohler Model 12RES generator manual calls for use of synthetic oil (Mobil 1 or equivalent) as follows: If temperature is normally above 0 degrees F, use 10W30. If temp. is normally below 32 degrees F, use 5W20 or 5W30. NAPA Auto Parts recommends their #1056 oil filter for the 12RES.
Product manual does not have troubleshoot section.
The operation might be normal, and within expected parameters, or it might have a glitch.
Suggest you contact Kohler Power directly:
http://kohlerpower.com/contactus/contactus.htm?sectionNumber=
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: Kohler 30RZ62 generator Parts
You are going to have to register with Kohler and use this site to get your part:http://www.kohlerpower.com/residential/sectionfront.htm?sectionNumber=13561
