Question about Carrier Heating & Cooling
Ac model # 42sd6b er-05 code meaning
Ac not working but indicating er-05
    Problem Solver:
  • 22 Answers
Are you trying to run your cooling now? I'm guessing you have a carrier thermostat and that's where this is displaying. It's been awhile since I've came across one but to my vague reculiction that code indicates the outdoor sensor detects low ambient them temperatures which in turn will not allow your air conditioner to run which would make sense this time of year. If you want to run cooling in below 60 degrees temps you must add a "low ambient kit" this shuts the fan down outside to build up higher head pressure without doing this you will just ruin your ac but in your case it won't let you. Google up your Tstats model number and codes if that's not your situation.
Posted on Nov 26, 2014
Air condition errior 05
What is the make and model of your ac unit? Air Conditioning Repair in West Palm Beach Florida wants to make sure we can help.
May 22, 2017 | Carrier Heating & Cooling
Er is on my refrigerator? what does that mean
Does it just show "er" or does it have "er" and two more characters? The "er" means there is some sort of problem, and the other two characters will indicate what kind of problem. If it's just showing "er" alone, I not sure what that means.
May 31, 2014 | LG LFX25960ST Stainless Steel French Door...
What does message Er IF mean?
LG refrigerator "Er IF" error code is the "Icemaker Fan Error" message.T his error code indicates a problem with the fan that controls the unit's ice production. If this problem occurs because of ice buildup, unplugging the unit for 3 to 4 hours and allowing it to thaw may fix the issue. Call customer service if that doesn't work.
Oct 12, 2012 | LG Refrigerators
I am getting a reading on the screen of "er 05" i
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Mar 21, 2011 | Precor 9.31 Treadmill
Our refrigerator constanly has ER FF in the ice & water display area. What does that code mean.
This error code ER FF indicates a problem with the evaporator fan motor but it can also be with the main control board. When the power cord is disconnected for 30 seconds and then reconnected, it resets the board. But resetting the board does not solve the problem always. The Defrost Control Board being defective will also show this error. The best solution would be to look for your complete model number and contact me HERE and I will send you your models Service Manual and parts to look for, I will continue to publish manuals HERE, Thanks, Sea Breeze
Feb 20, 2011 | LG Refrigerators
MODELNO 42SD6B SERIAL NO 3103Y90080 PROBLEM ER13.NOT WORKING SHUTDOW PLEASE INFORM WHAT IS THE PROBLEMS
Carrier make model no is 42SD6B the problwm is when the unit is running it run's for only 4 min then it's shuttdown give the error code 3 after 3 min. it's starting automitcally again it trip after 4min giving the error code 3.
So I just want to know what is this code stand for, what precaution should I take to solve this problem.
Oct 15, 2010 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
186 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
