Question about Canon ImageRunner 2525 Copier Canon
Error load paper and beep when i print
When i print from computer the error is beep and load paper
    New Friend:
  • 34 Answers
More info would be helpful. Like exactly what is the control panel message. However, from your description it sounds like the machine is looking for a paper size or type not loaded or wants paper loaded in the manual feed tray. Check your driver and see which paper tray is selected and what type paper as well as checking the printer to see if the tray is set to plain paper or some other type.
Posted on Nov 24, 2014
My Star TSP600 Thermal Printer is displaying a flashing Error light. Power light on, new roll of paper loaded correctly, self-test was ineffective - nothing printed. What's my next step?
i know you stated you put the paper in correctlyin the printer but if the thermal reactive side of the paper is not facing the print head the thermal paper won't print on the wrong side of the paper. it will load into the printer and seem ok but the heat on the wrong side of the paper will not react and show any writing. Can you try turning the paper over in the printer feed holder so the other side of the paper faces the print head and give it another test .
Jun 21, 2016 | Star Micronics TSP600 Thermal Printer
Hull, my canon IR 2520 cant print when i send the job it only beeps with a red light, can some one help me...
press the status monitor on touch screen. it will show that load paper LTR. that was an error.
go to additional function-> printer settings-> paper size over ride-> make it ON.
Sep 22, 2015 | Canon Office Equipment & Supplies
Cp305d paper size error
It may be a sensor problem When you reseat the tray it may not be actuating the paper size switches correctly. Check the paper tray and make sure that there aren't any missing or broken/bent tabs on it.
Mar 17, 2014 | Office Equipment & Supplies
Canon ipf605 paper error
Here is what I've found out by trial and error.
Paper Roll Won't Load:
    -Usually occurs when the roll is less than 50% full
    -Printer will give the error "paper loaded askew"
    To Correct This:
      - Press and hold Stop until Job Cancel comes up on the
      screen
      - Press Menu
      o Scroll Down until Adjust Printer menu comes up
      o Press right side arrow next to OK button
      o Scroll down to Manual Band Adjust and press right side
      arrow again (or select one of the other adjustments)
      - Select Yes and press OK
      - Load paper roll - make sure paper is straight
      - When asked (printer will beep) select Plain Paper and
      press OK
      - Let paper load
      - When printer starts to print press and hold Stop to cancel
      job
      - Paper should now be loaded
      When all else fails load a new roll.
      This would be a temporary solution until the sensor is fixed.
Mar 12, 2012 | Canon imagePROGRAF IPF605 InkJet Plotter...
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    My Canon s4500 not working, with 6 beeps error
    This is because the BJ Cartridge is not installed. Please refer to your manual page 214.
    Two beeps: Out of paper, or paper feed error
    Three beeps: Paper jam
    Four beeps: BJ Cartridge out of ink
    Five beeps: Cartridge not installed correctly
    Six beeps: BJ Cartridge not installed
    Seven beeps: BJ Cartridge defective
    Eight beeps: Waste ink tank almost full
    Nine beeps: Automatic print head alignment failed
    The POWER lamp flashes orange and green alternately with beeps: Service error
    YBC (/\)
    Oct 08, 2009 | Canon Office Equipment & Supplies
    Printer keeps printing garbage
    i believe that if you update the firmware for the copier, you shoud see that the garbage printing should go away.
    Mar 31, 2009 | Minolta DiALTA Di183 Copier
    Sending error
    I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
    Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
    Epson Photo RX600 error messages
    Hi.
    Check for a paper jam inside the paper feeder... There's something blocking the path that is why the 3-beep is activated. Also put lubricant to the head's round-bar, gears and levers.
    Goodluck... Fixya me...
    Feb 10, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
    Error light & 7 beeps
    geez, going back in time,but it is a print position fault, head is not traveling correctly , make sure rail is lubed and carriage can move back and forth without obstruction,
    Oct 26, 2007 | Canon BJC 80 InkJet Printer
    Canon ImageRunner 2525 Copier Canon Logo
    140 people viewed this question
    old marine
    old marine
