Question about Coffee Makers & Espresso Machines
Grinds and dumps coffee instead of brewing
Complete cleaning including descale. New brew group. Fresh coffee, tried different grinds.
  • 3,506 Answers
Hard to answer without a make/brand etc.
Posted on Nov 26, 2014
SOURCE: I have a cuisinart automatic
On mine the door that holds the ground coffee in place at times doesn't latch properly either and then the it will pop loose. I have to close it fairly hard in order to get it to latch and I test the latch by pushing on the door to see if comes open. When properly latched it will only open via the little button on the side, not by jiggling the door.
Posted on Jul 23, 2008
EsWorld
  • 1618 Answers
SOURCE: Saeco talea touch - grinds & brews coffee into grounds drawer??
Try this, adjust the grind to a coarser setting atleast 2 numbers, then remove brew unit and look behind at white plastic valve, there is a small chamber under valve make sure chamber is clean and that the small discharge from chamber to drain tray is also clear. Then remove shower screen from brew unit and clean if necessary, also check the tube from the shower. Reinsert and test.
Posted on Jul 02, 2009
co7196
  • 3433 Answers
SOURCE: I have a cuisinart with brew and grind coffee
Stuck? how stuck can it be when it is supposed to be removable? Try turn ing it,
Posted on Sep 24, 2009
  • 55 Answers
SOURCE: Lights for descale and grounds drawer flashing red
Have you ventilated the machine . turn to hot water and see if can get water out .
Posted on Dec 18, 2009
  • 1089 Answers
SOURCE: Steady Brew Group Light: Old Saeco Magic deluxe
Open the door on the right. The brew unit is the thing with the handle that has the push on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Posted on Jan 10, 2010
While performing the descaling the brew group gets stuck
Have you check if the knob on the top of the machine to distribute hot water is fully closed. If on the edge, you may not get hot water flowing but the light may be on.
Look on page 12 of the manual. It explain the the meaning of the led flashing or stayed on from the control panel
Good luck
Aug 30, 2014 | Saeco Odea Giro Plus Coffee Maker
Jul 02, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Seaco Easy wont work/Warning light blinking always
Try descaling the machine. If there is no water getting to the brew unit then it might be blocked, if you checked the brew unit then the blockage might be at the boiler or one of the lines.
Jun 03, 2009 | Saeco Easy Espresso Machine
Saeco Royal Digital Not brewing Coffee
If you try to make a cup of coffee, hold the button to see if there will comes some coffee, it can be the memory that have loose the settings. If so you have to program the machine again.
Best regards
/Mirran
Oct 13, 2008 | Saeco Royal Digital Plus Coffee...
Machine grinds but doesn't brew
Hi Donna,
Try to factory reset the machine in the meny.
Apr 13, 2008 | Saeco Royal Exclusive 30153 Espresso...
Saeco Magic De Luxe - hot water / steam but no coffe through the brew group
our taking about the plastic piece with 2 seal on it if it that its very easy to change that thing is screwed in the boiler try to unscrew the piece if you cant you gonna have to remove the boiler i know does machine good let me know thanks for using fixya pierre
Feb 13, 2008 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
