After just turning on my isyphony tv. It starts to dim slowly than powers off. Why is that?
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Check its main power supply regulator section too. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit; if any. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Nov 25, 2014
Proscan 37lb30qd
This could be one of two things. The backlight is dimming. There are tube lights in the unit and they slowly burn out. The way to tell is if the picture turns a shade of orange slowly comes on to full brightness. It could also be the inverter. The inverter is the board that powers those lights.
Jul 14, 2013 | Televison & Video
Lighting ran in on my lg47lg50 tv now the red power light is on but the tv wont come on
The power board is cooked. consider another tv.. Consider using surge protection in future.
Apr 01, 2013 | Televison & Video
2007 Dodge Caravan won't start.Batt. is good, all lights work, Turn key, solenoid clicks and stops, all gauge needles slowly move to max., and return to min. No codes displayed.
When you try to start it do the lights dim way low, have you been able to start it with a jump from another vehicle, unfortunately, chances are the starter needs to be replaced. How many miles does it have?
Feb 09, 2013 | 2007 Dodge Grand Caravan SXT Minivan
Panasonic TV slow to turn on, works fine after it turns on.
If you have to try to turn it on several times it is power supply related.
If dirty inside on fans etc it would cause set to shut down(the set monitors the fans for speed)>
I would suggest (take it outside) using a air compressor and cleaning the entire set out.
Lamps do fail---average life is 2000 hours for a original lamp and much less for a generic one.
If picture comes up try to watch the light from the lamp---if dim at first and then slowly comes up---it could be the lamp or the ballast the set uses to power the lamp.
Jun 10, 2012 | Panasonic Televison & Video
Toshiba 62HM84 Starting Problem
you need a balist.
olso in the cust menu is a quick start mode . turn it off
Nov 18, 2009 | Toshiba TheaterWide 62HM84 62" Rear...
How to clean Mitsubishi TV WD-52327 fliter
Remove the 2 screws in the access panel on the left rear side of the tv. You will see the filter behind it. Rinse the filter in warm water until clean. Lay it flat on a paper towel and fold the other half of the paper towel over it. Press gently on the towel to soak up most of the water, and install it in the tv.
Oct 10, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Thin diagonal lines on screen. How to adjust whit balance ,screen end focus?
Is that diagonal thin line about 10 to 20 degree slant? And then you have a very bright raster?
Then you set the flyback(for tube tv), I think its "screen" voltage is set too high adjust it slowly to lessen the brightness. It is commonly a small pot on the side of the flyback together with the focus pot.
If you have raster turn the tv on, use insulated screw diver, then slowly turn the knob to the direction(CC or CCW) where your raster go dim.
Be careful your dealing with live and high voltage. If your not inclined on electronics better not to.
Oh BTW, set your settings to normal.
Sep 30, 2009 | Televison & Video
Power issues
It sounds like you are drawing to many amps and you need to go to a higher capacity altinator and a second battery would be a good idea as well. Start your car (do it at night makes it easier to tell) turn on your headlights without your stereo on look at head lights and see how bright they are then slowly turn stereo on and up if headlights dim you are drawing to many amps and need a higher capacity alt to charge and stop you from blowing them, and second battery with and isolator so you don't draw amps from the battery that starts your car.
Jul 23, 2008 | Rockford Fosgate 800.2 Car Audio Amplifier
Picture faded to black, came back, faded again and had stayed black.
It seems your set has a loose conection in the high voltage circuits,in fact by now it should have many loose conections in different areas like the power supply and the horizontal deflection circuits,if you are familiar with tv service you can use the information as the first step to take,some of the loose conections are hard to see even for the trained technician but the one giving you this problem should not be hard to see,if you are not too familiar with tv service be safe and call for assistance from a servicer a least for an estimate.
Oct 11, 2006 | Mitsubishi CS-40507 40" TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
