Question about Intel D845HV (735858149143) Motherboard
Keyboard port dead & IDE #1 channel dead
I have to use a USB Keyboard for the system to boot.
I have to have the hard drive and the cd-rom drive on the #2 IDE channel for the bios to see the drives. All this is fine with me and has been working OK for awhile the computer will only boot in safe mode and work normal with both drives connected. If I try and start XP in normal mode it will hang forever at the Windows Splash screen with the moving blue bar and never boot. The Blue bar moves so it is not frozen. If I disconnect the ribbon from the CD-rom drive XP will boot just fine. Have tried new ribbon and drive and same results.
  • 306 Answers
Change the jumper setting on the drives
Posted on Nov 11, 2007
I have a sony vaio pcg-srx51p/a, and i want to format it b'coz of viruses. but it doesn't boot from cd, although i have a IDE to USB cable and a internal cd rom drive. how can i format it by using a...
Hello sir, Hi, unless we find a replacement cd drive for your laptop. I don't see how this goes. you see, the laptop you have does not support boot from USB drives, (see setup on the bios first boot, hopefully theres a usb boot option, if not you may opt for a WINME install.) so its useless to use the internal CD rom drive.
Mar 18, 2011 | Sony VAIO PCG-SRX51P/A PCG-SRX51P/B...
Trying to reinstall windows XP on Dell Dimension 8300....cant' start up using the CD drive...
Inpect the computers preexisting operating systems to ascertain compartibility to windows XP. Only XP computers would recognise XP operatign systems. Attemptign to install windows XP onto alternate system either windows 98, 2000, mellanuim or Vista XP or 7 is least achieveable unless the old system were erased or new empty storage disk drive were acquired and replaced.
Feb 03, 2011 | Compaq Presario 5000 PC Desktop
I have sata dvd writer.when i connect it my computer does not boot.does intel D102ggc2 supports sata dvd writer?
You're Intel motherboard does support up to 4 SATA hard disk drives including SATA CD-ROM / DVD-ROM drive, reader/writers. This MB also includes two serial ATA IDE ports.
The most likely reason you're system is not booting is because all SATA ports are all seen as Master drives. By connecting the SATA DVD-ROM drive the bios auto configured the SATA ports.
You'll need to enter the bios when you're system boots-up. Press the F2 key on you're keyboard right after hearing a single beep. You will than enter the bios main menu. Listed at the main menu are devices connect to the motherboard. (Instruction on how to move around in the bios is listed at the bottom of the screen). Mainly, the hard disk drive or (drives) and the SATA DVD writer. You'll need to open the Boot tab. Look for boot order. You want the boot order set like so;
First boot device: [Floppy disk] drive; if one is connected.
Second Boot device: [Primary Hard Disk] drive.
(The drive with windows installed on it). (This drive may be ATA IDE or SATA; you did not provide that information).
Third Boot device: [DVD-Rom] drive. Save and exit the bios. The system will auto restart.
You're windows operating system should load correctly after the auto re-start.
The SATA data cable and the SATA power cable should be checked for good connection. It only takes a little bump to make either loose.
Here is the link to Intel for you're motherboard;
May 12, 2010 | Intel D102GGC2 Motherboard
I need to format the hard drive using vista
ok follow this steps now. 0. Configure your BIOS and select DVD/CD ROM Drive, SATA or IDE for the first booting of the system. 1. you should have CD/DVD ROM SATA or IDE. Any of it you can use for the operations, and it's should be attach on you system unit. 2. When you are done on step 1. You can now Enter the Vista DVD/CD Disk Installer inside the CD/DVD ROM SATA or IDE. 3 Restart your system unit to proceed to the operation. 4. Automatically the system will launch the Operating System Files and it will Record all your information inside your hard disk.
Apr 10, 2010 | Compaq Presario CQ60-220US PC Laptop
Hard Drive Upgrade to Dell Dimension 3000
Try this Boot to the BIOS
press ALT+E (single Beep)
ALT+F another beep
ALT+B system will reboot and re-detect drives
once done, you should be able to install XP on HDD
Dec 30, 2009 | Dell Dimension 3000® Pentium® 4...
Trying to install Windows XP SP1 onto HD with this Motherboard. System will not boot from HD to start install.
Make sure your IDE hard disk drive is connected to IDE1 port and that the data cable is fully connected. Also check the jumper on the IDE drive. If you are using only one IDE hard disk drive set the jumper on the drive as a Master without a slave. If you are running two IDE hard disk drives set the primary drive's jumper as a Master with a slave. Set your second IDE disk drive's jumper as a slave. The master drive should be connected at the end of the data cable and the slave drive should be connected to the next data connector. Than check your bios settings. Power on the system and press the Delete key every 2 seconds until the bios menu loads. See page 3-1 in your manual. If you need the manual for the NF8-V MB click on the link provided below and download it;
You'll also need the program Adobe reader to view the manual. Adobe reader is a free download;
Once you’re in the bios go to page 3-4, Standard CMOS Features.
Follow the instruction listed for IDE HDD Auto-Detection. Your HDD should be listed here. Than see page 3-7 in the manual. Open Advanced BIOS Features. A normal boot menu for the Abit would read;
First boot device Floppy disk drive (If one is connected). 2nd boot device should be (CD-ROM/DVD-ROM). Third boot device should list your primary hard disk drive's (Model number). Load your windows CD into your CD-ROM drive.
Once the settings above are set, press the F10 key to save your changes and exit the bios. Your system will auto restart. Windows should begin to load.
Nov 18, 2009 | Abit NF8-V Motherboard
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
My PC refuses to boot up
If you have IDE rather than SATA drives -
You should have your hard drive as master and 1 CD drive as slave on one IDE channel, with the other 2 CD drives on the other IDE channel, one set to master and one set to slave.
So, pull the CD drives out and check the master/slave jumpers on the back of them.
Apr 10, 2009 | Teac CD-Rewritable W28E CD-RW Burner
Audio drivers needed for my pc. plz help.
Sound card driver for
Realtek AC97 Audio CODECs Driver v4.06 Windows 98SE/ME/2000/XP/2003(x32/x64)
Mar 23, 2009 | Computers & Internet
Drive is not accessible. I/O Device Error
Method 1: Change the transfer mode for your CD drive in IDE Channel Properties
1. Click Start, right-click My Computer, and then click Manage.
2. Under Computer Management (Local), click Device Manager.
3. On the right side, expand IDE ATA/ATAPI controllers.
4. Right-click the channel where your CD drive is connected, and then click Properties. Typically, this channel is Secondary IDE Channel.
5. On the Advanced Settings tab, in the Transfer Mode box for the device that represents your CD drive, click PIO Only. Typically, this device is Device 0. Then, click OK.
If the issue is not resolved after you change the transfer mode for the secondary IDE channel device 0, your CD drive may not be located there. Use the same procedure to change the transfer mode back to DMA if available. Then, repeat these steps to change the transfer mode for IDE devices in the following order until the issue is resolved:
• Primary IDE channel, device 1
• Secondary IDE channel, device 1
Note Primary IDE channel, device 0 is connected to your boot disk. This is the hard disk that typically contains your operating system.
Make sure that all cables are connected correctly
If you have another cable, try to use it. For USB devices, try to use another USB port. If it is internal dirve is there then Reseat it that means remove it and reinstal that
Then Set the BIOS as Default for that restart the system and before windows screen it gives the instructions how to boot in setup once you are in setup, on the bottom it says press F9 or F10 to set as default; different BIOS have different options so do the as the on screen instructons says.
Try to access the media or device on another computer; try it on your friend or family computer
if it is not working contact your H/W Vendor
Aug 14, 2008 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Intel D845HV (735858149143) Motherboard Logo
60 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
