Amber light behind select button (separate from the display light) no longer goes off - how to turn it off?
Tried all menu settings including setting backlight display to off. Tried resetting unit by turning power breaker off and back on.
  • 1,249 Answers
Change the filter, turn the ionizer off.
Posted on Nov 26, 2014
You have to turn up the volume to 38+ in order to hear the TV, when you use to be able to hear it at 10, is there a control board that goes out and what Is the name of it?
Hi Geoff, I hope I can help you with this. If you are using an accessory device (DVD, DVR) check cables to see that they are secure and if device has audio out option that it is set correctly. Also check to see that Video and Audio cables are connected to matching inputs on your set.
If you are using DVI to HDMI you will need to use a separate digital audio cable. DVI cables do not carry audio signal. After attaching the audio cable if you still do not hear sound you may need to set Digital Audio In. To do so:
  1. Press Menu Button on remote.
  2. Press the cursor ring down to highlight SETUP.
  3. Press the cursor ring left to enter SETUP menu.
  4. Press the cursor ring down to highlight SOURCE.
  5. Press the cursor ring left to enter SOURCE menu.
  6. Press the cursor ring down to highlight DIGITAL AUDIO IN.
  7. Press the cursor ring down to select the source you want to associate Digital Audio with. HDMI 1 or HDMI 2 in this case. You might need a software update also.
    The latest software solves the issues below:
    1. TV (Plasma 42" and 50") will not turn ON/shut off itself and Red LED blinks 4- times. Recover if main switch on/off.
    2. 37" LCD full white screen appear when upgrade software.
    3. Some channels not available after turn ON.
    4. Delta volume changes, not remembered.
    5. Preferred channel changes, not remembered.
    6. Green or yellow static (sometime snowy) on HDMI picture.
    7. Picture and sound loss for 5 to 10 sec (green LED is still ON) and back to normal.
    8. Audio loss in all inputs and can be recovered when main switch ON and OFF.
    9. TV set turn ON by itself/ green LED light up and goes off when set is ON.
    10. Intermittent audio loss in NTSC RF channel.
    11. Crack sound with high input signal.
    12. Include the possibility to download the rating table (RRT5 capability) for digital programs.
    13. No video/ no picture with sound.
    14. Intermittent On-Screen Menu pop up by itself and can be removed by pressing the 'MENU' button.
    15. Channel information display too long.
    16. Improvement on scramble channel.
    How to check the current software version on my TV set?
    1. Press 'MENU' button on remote control to display the on-screen menu.
    2. Select TV MENU and press the cursor right.
    3. Select INSTALLATION and press the cursor right.
    4. Select SOFTWARE UPGRADE and press cursor right.
    5. Select CURRENT SOFTWARE INFO to display the current software version on your TV set.
    6. If the TV software version is lower than the version posted on the website means your TV set needs to be upgraded.
    7. Follow the instruction in the user manual or Firmware Upgrade Readme file on how to upgrade your software.
    Where can I find the latest software for my TV set?
    The Firmware Upgrade Software and Readme File documents can be found on the Philips support website. Refer to the SOFTWARE section.
Feb 04, 2016 | Televison & Video
How do you get the back light yo come on?
The DISPLAY LIGHT menu can be set to on, off, or with a two (2) minute time out. Pressing any button will turn display light on (unless the display is set to off). 6.8.1 To change the Display Light Highlight MENU/HELP and press SELECT, highlight DISPLAY LIGHT and press SELECT. Use the UP/DOWN arrow keys to set values and the SELECT button to continue.
Jun 30, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Just got the phone today, it was acting fine until I disconnected the charger. Now the back light goes out after a couple seconds every time I try to use it. The light comes back on when I press the...
Try changing your display time out to something longer. Select menu-> settings-> display -> screen timeout -> pick something longer.
You can also set your brightness to not automatic. Within the same display menu, select brightness and uncheck the automatic brightness box. See if that works.
Lewis
May 15, 2011 | Motorola Mobility CITRUS Smartphone
Tv won't turn on with remote or front panel
Try this :
Follow the steps below for the initial set-up:
1. Select the "MENU" display by pressing the "MENU" button once.
2. Press the number buttons "2", "2", "7", "0" in sequence to select the "OPTION MENU" display.
3. Press the "ADJUST" button to select "INITIAL."
4. Press "ENTER."
Good luck...
Jan 11, 2009 | Mitsubishi WS-55511 55" Rear Projection...
W2606c lcd tv
Nothing appears on my LCD TV display
1 Ensure the LCD TV display is turned on.
2 Verify that all the cables are properly connected to the LCD TV
display, including the power cable.
3 Check to see if there is a blue or amber light on the lower,
right-hand corner of the LCD TV display. A blue light indicates
the LCD TV display is on. An amber light means the LCD TV
display is in power save mode.
4 Ensure the proper source is selected in the Input Select menu.
See "Input Select Menu" on page 24 for more information.
5 Reconnect any devices that are currently connected to the LCD
TV display. If you are using multiple devices, connect and test
one device at a time.
6 Connect another device that you know is working properly.
7 Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset.
Problem Possible Solution No sound
1 Ensure mute is not turned on. Pressing the Mute button on
the remote control turns the mute function on and off.
2 If only certain LCD TV channels do not have sound, then you
need to correct the Input Select menu in the TV Menu (see
"Input Select Menu" on page 24).
3 Verify that the audio cables are firmly connected to both the
audio input connectors on your LCD TV display and audio
output connectors on your devices. Ensure that the cable colors
match the connectors colors.
4 Also, ensure that the audio cables are connected to the same
row as the video cables. See "About Your LCD TV Display" on
page 5 for the location of the connectors.
5 Reconnect the device using the same type of connector. For
example, if you are using the composite connector on the
bottom, try connecting the device to the composite connector
on the side of the LCD TV display. See "About Your LCD TV
Display" on page 5 for the location of the connectors.
After you connect the device, change the input source in the TV
Menu. See "Input Select Menu" on page 24 for more
information.
6 Connect the device using a different connector. For example,
if you are experiencing the problem using a composite
connector, try using the component connector.
NOTE: To connect to a different connector, you need the
appropriate cables for that connector. See your device
documentation for a list of supported connections.
information.
7 Test the device on a different TV.
Jan 05, 2009 | Dell Televison & Video
MY SONY LAPTOP WONT BOOT
The flashing amber light means the screen is in power save mode. Since you are not seeing a "No Video Signal" things are looking up.
You want to use the menu buttons on your screen to navigate through and locate the power save time out settings. Its best to set it for 'never'.
If that makes the change a fix, let me know, I'll guide you through the settings on your desktop display to control the display time out.
Regards,
Worldvet
Jul 24, 2008 | Computers & Internet
30k gb bla
iPod has backlighting, so you can see the display in low light.
You can configure iPod so the backlight turns on for a set amount of time when you press a button or move the scroll wheel.
To access the backlight settings:
  1. Select Settings > Backlight Timer.
  2. Select a setting from the menu. Options include having the backlight timer:
    • Off
    • Turn off after a period of time between 2 and 20 seconds
    • Always on
A backlight on/off switch can be added to the Main menu by selecting:
Settings > Main Menu > Backlight
Jun 02, 2008 | Apple iPod MA446LL/A MP3 Player
Vizio p42 type sp42a nov 2004 hd tv
POWER SUPPLY OR LCD PANEL INVERTER BOARDS . AVAILABLE THROUGH VIZIO , PARTSTORE.COM OR EBAY
May 14, 2008 | Vizio L32 32 in. LCD HDTV
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
