Question about Kenmore Vacuums
Kenmore progressive vacuum model 116.25512500 won't power up
Won't power up, reseated and check wand connection to canister, power at wall, power cord
  • 3,506 Answers
Check the reset breaker on the machine
Posted on Nov 26, 2014
Nickstar19
  • 417 Answers
SOURCE: kenmore vacum wand power cord
http://www.vacsew.com/vacuum-cleaners/kenmore-vacuum-parts.html/
Try here
Posted on Jul 17, 2008
SOURCE: Kenmore vacuum manuals
I tried what reddevil6 suggested and was not able to get Sears to produce a manual. I would prefer an online manual but at this point I'm desperate enough to try anything.
Posted on Oct 05, 2008
  • 3 Answers
SOURCE: Need to know if a replacement part can be purchased and where
IT CAN BE FIXED BUT YOU NEED TO KNOW THE ROPES
I HAVE THE KNOWHOW AND THE PARTS
PRICE IS 40$ + YOU PAY ONE WAY SHIPPING
RETURN IN 1 WEEK
EMAIL LESGUEST@VERIZON.NET
Posted on Mar 05, 2009
  • 231 Answers
SOURCE: I have a Kenmore canister vacuum cleaner. The
check the reset button or the wire that goes into the powermate sometimes it frays and breaks
Posted on Jan 04, 2010
SOURCE: my kenmore progressive canister vacuum won't
wire broken in several place along suction tubing. Replaced tubing and works fine
Posted on Jan 27, 2010
How do I disassemble a Canister Vac Model 116.21714. extension wand ?
Sadly, there does not seem to be much help available for this. Sears wants $100++ another $30-40 shipping to have UPS take it and may be fix it. If you do not want to pay the fees, you will still have to pay $50 to get it back. Sears service shops will not fix vacuums. What the heck?!
Apr 24, 2014 | Kenmore 23913 Progressive PowerMate Bagged...
My kenmore progressive canister vacuum turns on only if the hose is attached to the floorwand. It seems that the canister motor is not working because I can't hear anything coming from the caniste
If the floor wand is powered, there may be an electrical connection that is broken when the wand is disconnected. This is part of the design, not necessarily a fault
Jan 05, 2013 | Vacuums
My power mate keeps losing power. As I am vacuuming, it surges off and on. The rest of the vacuum works perfectly fine. help!
Remove the wand from the telescoping pole, and look at the two holes in the wand where the electrical connection is made between the wand and the pole. You may see corrosion, which will cause the connection to be flaky and the power assist to surge on and off.
In any case, a good bet is that the wire harness in the wand needs replacing. It's about $15. (P/N KC37GBZTZV06) You'll have to take the wand apart - 3 screws and some judicious prying - to replace it.
Dec 28, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
The powerhead on our kenmore progressive canister vac (model 116.25615506) turns on and off as the yolk handle is raised and lowered. what is the most likely cause and is it repairable? thanks,
Wires (pins) are burned in the handle connection, usually the top section by the switch, unhook from the metal wand and inspect the connection, look for black sooty looking pin holes or pins, check both sides. This means the pins have burned slightly and now have a loose connection with little or no continuity. Very common, you will need to repair with a wire Kit or have a professional do it. Horrible design flaw been going on for years with these types of vacuums.....ACE
Dec 15, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
Kenmore 25614/25615 Progressive bagged canister vac won't start
sounds like there was a loose connection or loose wire that came in contact with another wire. check your cord for small burn holes, also could have shorted out in the hose or the wand. If you are comfortable to disassemble the vacuum i can walk you through the troubleshooting process so we can find out what actually went bad. id start with the cord though. let me know if you have any questions or need more assistance
Jan 04, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
Dec 29, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Kenmore canister vac 25614
Have you checked and made sure that the hose is COMPLETELY clear and the bag is not full?
Feb 13, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Can you tell me if Powermate Power Brush attachments are all the same for all the Sears Powermate Cannister vacuums.  That is, would one power brush attachment on a Model 116.56512690 fit one that is Model...
i think your confusing model #s ,as the 116. 22512202 is the canister model number and the model number of the powerbrush attch would be 116.52512202,but to answer your ? no it depends on which wand your useing that determans which one you can use
there 3 types of wands 1 telescoping which comes only on progressive models 2 a 2 piece with wire connected and a 2 piece
wire not connected,hope this helps,les
Jan 03, 2009 | Kenmore 22812 Bagged Canister Vacuum
Losing power to stick/floor vacuum
if you have an extension wand, the replacement will cost about $100.00. there is a way to repair both the pwr-cord on the brush assemble and the wand, but it depends on how much damage there is. also you need to check the contacts where the wand connects with the handle,and the prongs on the handle.
let me know if you still need help
Jan 11, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Vacuums Logo
64 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
