Question about Panasonic SC-HT720 System
How do I unlock the panasonic 5 disc player. drawer will not open
I push all buttons to open the drawer. I push all buttons for disc # 1,2,3,4,5. Will not open. It says reading disc but no disc in there.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Panasonic Master
  • 924 Answers
In the first decade of CDs, there used to be transport screws on the bottom cover to keep the mechanism from banging around during transporting. They used to be painted in RED to make them stand out to the customer. Someone mentioned on another question, that there was a hole in the bottom, that had to be to pushed in to release the mechanism. That may be a more precise answer than mine, in these current days. When I worked for the manufactures, a project engineer told my that the difference between profitable or non profitable on a product may just be the difference in pennies(the cost of those RED screws)! If you need more assistance, please visit my website at audioserviceclinic.com.In addition to that, the information you seek, is probably in your owner's manual.
Posted on Nov 25, 2014
2 Suggested Answers
Toufic Malek
  • 9 Answers
SOURCE: disk drawer is locked
You have to reset the unit: While stopped, press and hold [ ] on the unit and [S10/ENTER] on the remote control for about 3 seconds until ?Initialized? disappears from the television. Turn the unit off and on again. All settings will return to the default values.
Posted on Sep 25, 2007
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Unlock Toshiba DVD player SDP93S bought in America to play Australian DVD's
Thanks for understanding. Please let me know if you require any clarifications.
Jul 09, 2011 | Toshiba SDP93S Portable DVD Player
DVD drawer does not open when you push button to open DVD drawer
The most likely cause is damage, which should be seen with the eye. It could be a belt, broken cogs/teeth in the sledge mechansim, or a micro leaf switch bent out of place.
Apr 05, 2010 | HP dc4000
DISC DRAWER WILL NOT OPEN
First, start with power cycling the player. Turn off the player and disconnect the power cord from the wall socket. Leave it unplug for about 5 minutes. Turn the player back on and try to open the drawer.
If same problem occur, then follow the steps below:
1. Turn off your DVD player. You do not want to risk electrical shock while working with it.
2. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
3. Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
4. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
5. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs.
Mar 21, 2010 | Panasonic DMR-ES10 DVD Recorder
How to lock and unlock the the drawer for the Panasonic Blu-ray player DMP-BD60.
A disc must be in the player. Hold the play and eject button at teh same time for 5 seconds and the msg on the display will change from lock to unlock.
Jan 18, 2010 | Panasonic DMP-BD60K Blu-ray/DVD Player
Panasonic dmres30v unable to open dvd drawer led displaying u99 and cant remove
Press the power button on the main unit to switch the unit to standby. When the unit is in standby , press the power button again on the main unit to turn it on. If the unit doesn’t switch to standby, press and hold the power button on the main unit for about 10 seconds to forcibly switch it to standby.
To open the drawer, press and hold STOP and CH UP buttons on the main unit at the same time for about 5 seconds.
Nov 27, 2009 | Panasonic DVD-S35 DVD Player
How to unlock region code for Yamaha-DVD-S1800-DVD-Players
This worked last time I tried it. As with all region hacks you must first ensure that the remote has fresh batteries inside.
1. Switch the DVD S1800 on using either the remote or the front panel button.
2. Open the disc loading drawer and leave it open
3. Using the remote control press the "Clear" button.
4. Use the remote keypad to type in "2580".
5. Now press "Subtitle" on the remote.
6. Close the disc loading drawer.
7. Wait until the player has finished the loading cycle
8. Switch the device off using either the remote or the front panel switch.
When you turn the player back on it should be a region 0 (i.e. multi-region) player.
I hope that this has provided the answer you require, if so all I ask in return is that you remember to rate my answer.
Oct 21, 2009 | Yamaha DVD-S1800 DVD Player
Five discs keep spinning; will not stop. Cannot open drawer
they button maybe stuck or the switch that open the cd player sticking try to push button to open then pull on drawer not to hard u brack then see if u can clean swith
Mar 22, 2009 | Sony CDP-C445 5-Disc CD Changer
Need the code to unlock regions on LG V9120W
1)turn on power
2)draw tray open
3)push 0 button 3 times
4)press 0 (region code)
5)press pause
OR
1. Turn Player on with no disc inside
2. Set the Unit to DVD mode (Not VHS)
3. Turn Player OFF
4. Turn Player on with no disc inside
5. Press pause on the remote control
6. Then key in 3 1 4 1 5 9
[CODE -- will then be displayed on the player display]
7. Key in desired Region number
[0 for Auto Multi Region, or manually select 1 to 6]
8. Then Press Pause again
9. Turn off player and wait 5 seconds, then back on again.
Sep 13, 2008 | Televison & Video
DMR-E50 won't eject disc.
Nope sorry no quicky fix here
Sep 19, 2006 | Panasonic DMR-E50 DVD Recorder
Panasonic SC-HT720 System Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
