Question about Kitchen Ranges
<!-- from fixya rte -->Find out where the battery is situated - Kitchen Ranges
  • 3,506 Answers
Kitchen ranges normally do not have batteries so find out what make and model you have and go from there
Posted on Nov 26, 2014
LG laptop battery
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery. For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter. In most situations it's a bad battery.
hope this helps
Sep 06, 2012 | LG LB32111B, LB52113B, LB52113D,...
Computer will not start up
Third-party utility
hope this helps
Aug 30, 2012 | Dell Inspiron 1501 Laptop
No battery is detected
Third-party utility
hope this helps
Aug 24, 2012 | Computers & Internet
What is the solution the battery is fine
Third-party utility
hope this helps
Aug 05, 2012 | Dell Latitude D510 Notebook
Blackberry will not charge
Hi :
There could be many diagnosis .
1: The battery life could be ended [ battery is dead ] . A dead battery can't be recharged anymore . in this situation you need to replace the battery with new one .
2 : There could be a problem with the charger . In this situation also you need to replace it .
3: Check the cord between the charger and the blackberry .!
4 : There could be a problem with the charging jack . In this situation you need to take your blackberry to repair shop for repairing .
I hope that will help you .
PLEASE DON'T FORGET TO RATE !
Jun 03, 2010 | RIM BlackBerry Curve 8310 Smartphone
1999 Chev 2500 want start. Replaced wires,plugs, fuel filter+started, 2-3 wks later same situation, ran battery down, put in new battery=started. 2-3 wks later same situation, put on new switch box=started...
check fuel pump pressure....GM is known to have faulty ones that work after started and will run but wont send enough on cold srarts...Good luck...Lee
Nov 13, 2009 | 1999 Chevrolet C/K 2500
Where is battery fuse link
Under hood box: Fuse 20 (120A)
Hope this helps.
Nov 12, 2009 | 1999 Honda Odyssey
Not coming on with new batteries (have tried several new batteries)
this problem seems to be caused by a faulty battery protection switch fault, which is situated in the battery compartment.
May 28, 2009 | Olympus FE-110 Digital Camera
My fuji finepixs 5200 wont let me take photos and when i try it says "FOCUS ERROR"
Karen,
First let's see if the camera will reset. Remove the battery or batteries and leave them out for 5-10 minutes. Then, reinsert batteries. Try taking pictures in various lighting situations. Also, try taking pictures at various focal lengths (distance from subject to camera). Follow-up and let me know how the photos turn out -- and in which situations you receive the FOCUS ERROR. I'll gladly help you further at that time.
Nov 17, 2008 | Fuji Cameras
Hi:its annonimus person, Iam having trouble with my palm tx it turns on and off all the time and i have to keep charging the battery practicly every twenty minnutes and also i have problem lyning the palm ...
If you need to keep charging the battery so often I would suspect the battery is faulty and needs replacing. Whether you replace it with the genuine article or a different replacement I cant advise you on. If after replacing the battery and this situation does not improve after two weeks then I would suspect you have a leaking capacitor somewhere on the power supply. Unfortunately you also might have to buy another battery again as there is a chance that waiting to see if the situation improves might also do irrepairable damage to your new battery. Hope this helps.
Sep 29, 2008 | Computers & Internet
Kitchen Ranges Logo
57 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
