Question about Pioneer VSX-D1011 7.1 Channels Receiver
When turning the device on, it shuts down after 10 - 20 seconds. Sometimes it is not possible to turn receiver on at all and on very few times, I can turn it on and play a whole cd without problems...
I have tried disconnecting speakers (2.0 setup now), opened up the device and measured the main switch, hoping it was faulty, but it was not.
    New Friend:
    Problem Solver:
  • 18 Answers
Some receivers have a heat sensor circuit. It may be faulty. The transistors take about that long to heat up. It can prevent power intermittently. What brand model?
Posted on Nov 26, 2014
  • 1 more comment
  • Audio Service Clinic Nov 26, 2014
    I hate to comment on someone elses solutions, but as I worked for Pioneer for over 6 years as well as another 34 years in the industry, as their Audio Field Service Engineer, I can say for certain, Thermal sensors are mounted to the Heat Sink(aluminum bars that the output transistors are mounted to( you can see them through the top cover), do not need need any "warm up time". They simply measure the tempurature on that heat sink, and once they reache a certain temperature, that information is passed to either the main microprocessor, or the display microprocessor IC(two computers with your receiver) that cause to unit to shut down to protect the amplifier stage. That is not your issue here. There are may oof these microprocessor IC, due to the complexity of the receiver, as many as 5-7 ICs. There is an issue that I beleive your receiver has. It is know as DC Offset(as in a damaged amplifier) If DC voltage appears on the speaker putput line, it signals the Display microprocessor, which in turn, signals the main microprocesor to sitch off the power, until the problem is correct, to one, protect the speakers for damage, or further damage to the amplifier. This is not a DIY repair, It is very complicated circuitry. and if you are prepared and equiped, you will likely cause more damage by troubleshooting. If you need further understanding, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. Thank you.
    Well, I guess Fix Ya's system doesn't like long answers, and I'm about the only one that will "push the envelope". There maybe a simple fix you should try first before worring about what I previously wrote. There is a procedure, in your owner's manual, known as Factory Reset, or Return to Factory Defaults. It is located in your owner's manual, usually about 2/3 the way through the manual. You may find that performing the precedure, clears your unit from any mispressed buttons(which I doubt) or any trouble faults picked up by any of the microprocessors. Try that first, before you sweat the hard stuff, which is whatr I do for a living! :-)
HLuis
  • 19 Answers
SOURCE: "POWEROFF" display comes up randomly
there may be broken soldering points in the receiver take it to a workshop or open it your self and check it on the power source
Posted on Jul 03, 2007
SOURCE: Receiver: Pioneer Elite 72TXV Verizon
Called Verizon automated help desk. They rebooted DVR remotely and solved the problem.
Posted on Mar 29, 2008
melnavz
  • 1226 Answers
SOURCE: Cracking and poping with Yamaha surround sound system
Try put a ground line from any metal of your stuff to the any metal direct to the ground. these eliminate noise of the speaker.
Posted on Jan 04, 2008
  • 14 Answers
SOURCE: Overload
try turning the unit off in standby mode then hold down the enter button and then the power button for about 10m seconds that should reset the unit depending on how new the unit is it sometimes has a digital saftey setting but i doubt that would cause it to do what you are saying
Posted on Apr 02, 2008
SOURCE: Overload...
Pioneer posted this on it's Canadian Web Site:
Poor wiring connections, bad wires or a bad speaker may cause this. As you increase the volume, you will increase the amount of current you are drawing from the receiver. To troubleshoot this issue, try the following:
  1. Disconnect each speaker wire connection. Inspect for any frayed or damaged wiring and replace it.
  2. Check the impedance of the speakers; make sure they are properly rated for your stereo. In most cases, they need to be 8 ohms. Only a few Pioneer receivers will support lower impedance.
  3. If the problem still continues, try these steps:
    1. Turn the receiver off.
    2. Remove one speaker.
    3. Turn the receiver on.
    4. Increase the volume.
If the receiver overloads, repeat steps 1-4 (selecting a different speaker each time). If you disconnect a certain speaker and the receiver no longer overloads, have this speaker checked at a service center. It could have a bad speaker component, like a tweeter, sub-woofer, or even a bad crossover.
Posted on Mar 10, 2009
I have Sherwood rd-6106 amplifier and when i turn him on it goes back to standby after few seconds. can anyone help?
bad fuse, something is sending it to sand by to keep from ruining the rest of it, have it looked at by a pro technician
Feb 02, 2015 | Sherwood Audio Players & Recorders
Receiver turned off after power on
I can see two possible problems.1: your receiver wants to take too much current and it shuts down the relais to the speakers, or,2: The hold contact of that relais cannot keep it's voltage and shuts off the speakers after a short time.
Check your end transistors for shorts and/or see what the voltage does at this relais. A faulty capacitor perhaps?
Feb 24, 2014 | Pioneer VSX-920-K A/V Receiver
Nuvico nvjv 4000 beeps and shuts off
sometimes these will go into an automatic sleep mode and will restart once you power it down and restart..
Jan 19, 2014 | Nuvico NVJV-4000N Video Recorder
Look at inside at capacitor and fuse but they seem ok. again once i turn it on, it would automatically shuts off after a second.
When a system shuts down after a few seconds it is the self protect circuit shutting down power to the outputs to prevent (further) damage. It may be caused by frayed speaker wires, bad speaker voice coils, or blown output transistors. First, turn off power and remove all speaker wires from the receiver. Turn it back on and see if the problem remains. If it works OK, inspect each speaker wire at both ends for loose strands and correct these. Then, hook up your speakers one at a time until the problem reappears. That speaker or its' wiring is your problem. For safety's sake. turn the receiver off before connecting each speaker. An accidental short of the output terminals can be disastrous (and expensive).
Apr 06, 2010 | Yamaha RX-V661 Receiver
Light engine
hold menu and input or device button at same time for 5sec. Let me know what blinking code you get. 3-2 6-1 etc.
May 25, 2009 | Mitsubishi WD-62531 Projection Television
Laptop keeps shutting down, both fans not working
sounds like you have a bad motherboard, or uP...is this under warranty, by chance?
May 25, 2008 | Dell Latitude C640 Notebook
Pioneer VSX-D1011 7.1 Channels Receiver Logo
113 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
