FLATRON W1941S GETTING GREEN contrast (full screen) to my win7 desktop and working fine with other laptops.....
ADJUSTED CONTRAST AND OTHER ALL THINGS.......BUT DIDN'T GET IT RIGHT PLS HELP ME GET THROUGH .......URGENT PLS BRO.....
  • 380 Answers
If the screen works fine on ALL other computers, then it is NOT the screen, But, it could indicate a bad output port on the desktop pc. Or it might just be a bad VGA cable or bad port hook up on the screen or PC. Before you panic, try another port on the PC (if you have one) and try another cable (if you have one).
Posted on Nov 24, 2014
  • 86 Answers
SOURCE: check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Posted on Mar 31, 2007
SOURCE: The Contrast screen pops on all the time
It looks like your UP button contact is demaged.
SOLUTION is to insert a piece from your business card mostly above the button to adjust it down or up. It works fine.
Posted on Feb 02, 2008
SOURCE: Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Posted on May 14, 2008
SOURCE: Dell 15 inch monitor, brightness/contrast window
Press and hold the + button, You will get a message that the monitor is going into auto adjust. After that problem solved.
Posted on Jan 19, 2009
  • 10406 Answers
SOURCE: My LG 700E crt monitor
It's time to RESPONSIBLY RECYCLE any 17-inch CRT monitor, and buy a LCD monitor;
used LCD monitors can be purchased for under $50.
It would cost you over $50 to take the CRT to a TV/Video repair shop, for trouble-shooting and repair.
Posted on May 11, 2011
How to adjust contrast on dell 610
You can only adjust brightness. There is no contrast control.
Jan 17, 2014 | Dell Latitude D610 Laptop Computer -...
Mc3090 CONTRAST ADJUSTMENT
Brightness can be adjusted by the hotkeys or within windows (system settings - backlight).
contrast can be adjusted with a potentiometer at the mainboard.
normally contrast does not change over the lifetime (my oldest 3090 is used 8h/day for 7 years)
some of the old 3090 have a CCFL backlight which dramatically losing brightness when getting old. you have to replace the tube or display unit.
Jul 09, 2012 | Symbol Motorola MC3090 Handheld Computer
How do I adjust the color contrast on a 1998 GE 19GT320?
one of three things here--if was normal before moved you may have a bad solder connection on the circuit board at the end of the picture tube--happens with age as connections can come loose.
The set MAY have adjustable controls on that board for drives and screens(red, green, and blue) that can be adjusted.
The set may only also have those in a hidden menu.
Considering age of set and cost for a replacement it might be better to replace it if none of above options are something you can try.
Jun 15, 2012 | Televison & Video
How to adjust Contrast for ASUS A52J Laptop.
Sounds like either your inverter might be failing or your graphics card. If the screen goes really dark, but you can make out images in a bright light, it's the inverter. Fairly easy to change if you look on the internet you should find full instructions for your make and model, often in you tube. Good luck.
May 26, 2012 | ASUS Computers & Internet
My monitor stays white it wont show any display
black-icon.gif This icon indicates the BRIGHTNESS control, more properly called BLACK LEVEL. It adds or subtracts an offset, or bias, into the red, green, and blue signals. This control should be adjusted so that black picture content displays as true black on your monitor. Misadjustment of this control is the most common problem of poor quality picture reproduction on computer monitors, video monitors, and television sets. Later in this document, I will explain how to set this control properly. The setting is somewhat dependent upon ambient light. Modern display equipment is sufficiently stable that frequent adjustment is unnecessary.
picture-icon.gif This icon indicates the CONTRAST control, preferably called PICTURE. It applies a scale factor (gain) to the red, green, and blue signals. It affects the luminance (proportional to intensity) that is reproduced for a full white input signal. Once BRIGHTNESS is set correctly, CONTRAST should be set for comfortable viewing brightness.
The gamma can be controlled through Video Card utility which can usually be accessed by going to display properties.
Depending on your video card software you may be able to right click your desktop, select properties, select settings tab and then choose advanced, towards the bottom. In there you may find a tab called Monitor and under that tab you may or may not (depending on your video card software) be able to adjust your color correction settings(gamma & brightness & contrast).
. Right click on the desktop and then select Properties
2. Click on the Settings tab and then click on the Advanced button.
3. Click on the Color Correction tab and you will see settings for Brightness, Contrast, and Gamma
Jan 29, 2010 | Computers & Internet
While using my gps 12, the screen suddenly went dark with just a narrow border of lit screen. batteries good. I can faintly see the pages behind the dark screen.
it turns out I inadvertently adjusted the screen contrast. This is adjusted by holding the left arrow key down after powering up, until the contrast is corrected. If the screen was completely white, holding the right arrow key down after powering up would bring contrast back into balance.
Nov 28, 2009 | Garmin GPS 12 GPS Receiver
Contrast 10My problem is that the contrast is appearing in the screen of my flat screen and automatic decrees the contrast and it?s blocking the center part of the screen window keeps appearing on scr
There is no feasible way to fix this. The problem is a short in the circuitry of your flat screen. If the monitor is off warranty, it's cheaper to replace the monitor than to have it repaired.
Jun 02, 2009 | Dell Dimension 2400 PC Desktop
Convergence Problem and Contrast Adjustment
Have you checked all of the resistors inthe convergence circuit as well? If not, check them for the correct impedance.. Remember, you have to pull one side of the resistor out of circuit to measure it correctly.
If all of the resistors are good, then you have to do a coarse convergence adjustment on the set through the service menu.. if you need the service manual for the convergence directions, I have one uploaded in the technicians corner of techlore.com
Dec 25, 2008 | Televison & Video
Contrast
The supplied software should allow you to set brightness and contrast if there are no front panel buttons to set it.
Check for LG or Flatron programs under the Programs listing available from the Start panel.
Jun 19, 2008 | LG Flatron L1710S 17" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
