Question about Garmin nuvi GPS
I have a honda crv and my nuvi keeps lossing signal,if i hold it out the window or use it in my isuzu it works fine,i even tried a different nuvi and it does the same thing,any suggestions
    Sergeant:
  • 320 Answers
It may be due to the coating of the windshield. Most gps units come with or have available external antenna. You may need to obtain an external antenna for use in some vehicles.
http://goo.gl/xJdcSA
Posted on Nov 24, 2014
Why my 2000 honda crv doesnot have heat on the winter time?
check the controls that open the heater lines . vacuum loss or control module is faulty.
Sep 10, 2014 | 2000 Honda CR-V
Car wont go 50 mph
Maybe the exhaust converter is blocked
Aug 26, 2013 | Honda CR-V Cars & Trucks
2001 honda crv keeps blowing tail light fuse. The bulbs check out fine.
Run a scan on it. The sensor is getting a wrong signal.
Apr 13, 2012 | Honda CRV Cars & Trucks
D" blinking is showing on
The PCM senses an abnormality in the powertrain system. Get the code checked, probably a pressure switch though.
The flashing D is a warning signal that there is a transmission problem. Sorry. Below is Honda recommendation for fluid changing.
Also, you coould check this Honda Auto Trans Flush Procedure - Official
Hope helps.
Apr 20, 2011 | Honda CR-V Cars & Trucks
On my 2003 Honda CRV Sport, When I lock me steering I get a grinding noise, does anyone what this is? Cheers Alan
if the noise only occurs at full lock then it is the pump clutch slipping which is normal.sounds awful but okay.
Mar 12, 2010 | 2003 Honda CR-V
Replaced 2003 honda crv battery,how to reprogram radio,and power window 1 touch does not work
for the radio you need to get the code. this is done by first geting the serial number you do this by pressing and holding the 1&6 preset buttons with the raio off and then turning it on. from that number i can get the code or you can call any honda dealer and give it to them. as for the window roll the window all the way down and then back up after it gets all the way up hold keep holding the switch for a few seconds and that should fix it
Jan 05, 2010 | 2003 Honda CR-V
Honda crv window motor not working
You will need to remove the bolts that hold the window guides in place, and carefully lower the window assembly so you can get to the bolts that hold the regulator to the window. When reinstalling, be careful not to over tighten the bolts.
Mar 26, 2009 | 1997 Honda CR-V
Rear window sprayer does not work on honda CRV 2003
On my 2007 CRV, I have to hold it long. Since I hardly use the rear sprayer, there is no liquid in the hose and it does take a little while before I get enough liquid in the hose to get the pressure going.
Dec 10, 2008 | 2007 Honda CR-V
Garmin GPS acquiring satellite Issue
I would return it to Garmin for service.
Mar 23, 2017 | Garmin nuvi 200W GPS Receiver
GPS Logo
49 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
