Question about Electrical Supplies
Change my generator start module from autostart powerlink plc-702-hc toa manual start dse 702 ms-hc module i.e which pins go to which numbered outputs on a genelite 20kva generator?
2 Suggested Answers
  • 250 Answers
SOURCE: Coleman generator #PM0497000.02 generator starts well
You have to get a cord that has a plug on on it. On the other end of the cord strip the insulation off the ends of the wire about an inch. It would be easier if you put small clamps on the stripped ends of the wire. Connect the black wire to plus on a car battery and white to negative. Start the generator and plug the cord in to a outlet on the generator just for a second and take the plug out. The generator should now be producing electrical current. If not there is something burned out internally.
Posted on Mar 11, 2011
Our 2007 Ford Freestyle 3.0V6 shows B1318 code, also scanner shows low battery voltage module. Car shuts off.Please help what to do to fix?
Which module ?
B1318 Battery Voltage Low Audio Control Module REFER to Section 414-00 . B1318 Battery Voltage Low DSM REFER to Section 414-00 . B1318 Battery Voltage Low DVD Player REFER to Section 414-00 . B1318 Battery Voltage Low Instrument Cluster REFER to Section 414-00 . B1318 Battery Voltage Low RCM REFER to Section 414-00 . B1318 Battery Voltage Low Satellite Radio Receiver REFER to Section 414-00 . B1318 Battery Voltage Low SJB REFER to Section 414-00 .
According to this charging system isn't working correctly ! This is a computer controlled charging system .
Principles of Operation
The powertrain control module (PCM) controlled charging system determines the optimal voltage setpoint for the charging system and communicates this information to the voltage regulator. This system is unique in that it has 2 unidirectional communication lines between the PCM and the generator/regulator. Both of these communication lines are pulse-width modulated (PWM). The generator communication (GEN COM) line communicates the desired setpoint from the PCM to the voltage regulator. The generator monitor (GEN MON) line communicates the generator load and error conditions to the PCM. The third pin on the voltage regulator, the A circuit pin, is a dedicated battery voltage sense line.
The charging system voltage is controlled by the PCM. The generator charges the battery and at the same time supplies power for all of the electrical loads that are required. The battery is more effectively charged with a higher voltage when the battery is cold and a lower voltage when the battery is warm. The PCM is able to adjust the charging voltage according to the battery temperature by using a signal from the intake air temperature (IAT) sensor. This means the voltage setpoint is calculated by the PCM and communicated to the regulator by a communication link.
The PCM simultaneously controls and monitors the output of the generator. When the current consumption is high or the battery is discharged (the PCM recognizes this and increases the output of the generator to accommodate), the system is also able to increase the idle speed to increase the charge.
To minimize the engine drag when starting the engine, the PCM does not allow the generator to produce any output until the engine has started. The PCM then progressively increases the output of the generator.
The PCM turns the charging system warning indicator off after the engine is started and illuminates it under fault conditions (when the generator is not generating the correct amount of current with the engine running). The charging system warning indicator is also illuminated by the PCM whenever the key is ON with the engine OFF.
This is a System 4 charging system, which uses the GEN MON and GEN COM lines to control and monitor the charging system through the PCM. System 4 charging systems are virtually identical in design and therefore, share the same diagnostics. The circuit numbers and colors may be different, but the functions are the same.
Jun 30, 2017 | Ford Cars & Trucks
I have a TOA 301 15W amp and a Bose 151 environmental speaker(40w 4 ohms). I do not have a manual for the amp and wish to connect the speaker as a small PA . My concern is that the output I think I should...
Don't worry about the 7.7 volts. Just connect between COM and 4 ohms and you'll be fine. I didn't find a 301 part number related to a 15w amplifier, but I did find a BG series (115 130) of 15 watt amps manual http://www.toa-products.com/international/download/manual/bg115_mt1e.pdf
Carl
May 08, 2011 | TOA Electronics Audio Players & Recorders
I start work in a plastics factory as an electrician. I need to know the type of work I might expect to have to do. Maybe some diagrams of motors and generators may help.
You can start here with this video, what is a PLC. To get a better sense of What is a PLC, see http://plc-training.org To get a better sense of what all is involved on the industrial electrical side, see http://bin95.com/Industrial-Training-Videos/industrial_electrical_training.htm
Oct 17, 2009 | Electrical Supplies
How do you wire from the mixing board to an old school L-41 module that has 3 screws, for my toa 912mk2 amp?
The L-41...3 screws?...Is that a LOW-Z input?
Check the TOA site.
They have all the manuals for download
Rate my help if you could and get back to me
Thanks
Aug 29, 2009 | TOA Electronics M-900MK2 Amplifier
How do I change the input from the DVI-I input to the 15
I found the online manual and followed the instructions to set to "auto" input. Everything works fine.
It had been a discouraging ordeal trying to locate a new DVI cable (which came with the projector)
and as it turns out the 15 pin cable works fine. Thank you.
Rick
Jun 11, 2009 | Sanyo PLC XU50 Multimedia Projector
Connecting a sonos 90 to BO 8000 active speakers
Does your sonus system has pre-out? you can directly connect one single rca cable to each output into the speakers. make sure, each speakers is set to left and right each channel. these switches can be found above the rca input of the beolab 8000 next to the power link input. You have to understand that by using powerlink source cable is ideal only for other bang&olufsen equipments......however, there are other options, if u don't have a pre-amp output of your amplifier, you can also modify the speaker out of the amp, thru a conversion cable available from bang & olufsen, with an rca cable left and right channel, without interfering with the powerlink.
Apr 03, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Unlock code for DSE G2112 required
Hi, I recently bought this model too. I spoke to **** Smith themselves and they assured me that the G2112 is region free out of the box. Have you had a problem?
Feb 17, 2008 | Televison & Video
S7 226 Siemen's Plc programming
Hi there, you can check out this link Learn PLC programming.
This web site runplc.com is great resource for anything you like about PLC programming, free programs for programmable logic controllers, and much much more about PLC programming basic
Feb 04, 2008 | Computers & Internet
Connecting input & output on my TOA 900 series amp
http://www.toaelectronics.com/Manuals/P-906_12_24MK2.pdf.
Jan 07, 2008 | TOA Electronics P-924MK2 Amplifier
Electrical Supplies Logo
63 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
