Question about Home
I have 3 new t5 4 bulb ho high bay fixtures with an advance ICN-4S54-90C-2LS-G ballast. When I turn on the switch only the 2 outside bulbs light up on all 3 fixtures. How can I make the inside bulbs
Power is correct and wiring is correct
    Sergeant:
  • 324 Answers
If only two bulbs are lighting on ALL the fixtures, this usually indicates wiring.
Check wiring diagram as follows.
If unsure, contact local electrician to ensure proper wiring within your states electrical code.
http://www.stanion.com/pdf/advance4.pdf
Posted on Nov 24, 2014
3 Suggested Answers
  • 405 Answers
SOURCE: 2000 Chevy Blazer, 4x4, 4
HI. There is no possible short circuit on the fuse box.However it may be possible that fuse has been busted.Have you tried replacing the fuse with a new one?.What measurement you did to conclude that wiring is okey.Have you tried to tests the continuity of the wire using a MULTITESTER.Now if the fuse is defective current will not flow on it,that's why it has no power as well flowing along the circuit.Hope this helps.Thank you for choosing FIXYA.
Posted on Jul 21, 2011
kobusc53
SOURCE: i have an opel corsa
Mine did the same. After a while the other indicators started doing the same. The problem was the flasher unit. Cost was R830-00 for the unit and 10 minutes of labour to replace.
Kobus
Posted on Apr 12, 2014
I have a T12 fluorescent light fixture and replaced the bulbs and ballast. I have double checked all the wiring connections. I get the bulbs to light when I move the bulbs, but only for a second.
Your description sounds like the connectors for the tubes. Also RECHECK wiring. Different on newer ballasts. See below...
Turn off fixture, unplug, or deactivate fuse...
Pull out bulbs and the tin fixture cover/reflector.
Extract the bulb connector. Go to hardware and buy 4 more, and just replace them. The connections fail where the wire connects and the rigours of bulb replacements damage this piece. TONS easier to get new pieces.
ALSO!!!! many new (fancy schmancy) ballasts WIRE UP completely differently from the old ballast. Follow the wiring diagram on the NEW ballast. This detail trips up many.
Doc
Sep 13, 2016 | Photography
We have Lithonia 2 bulb fixtures in a recessed ceiling. We currently have 2 (25) watt bulbs in them. What wattage can I upgrade to ??
The ballast inside the fixture is rated to operate 2 25w bulbs. You can't put higher wattage bulbs in this fixture, unless you change the ballast. Sorry.
Sep 22, 2014 | Lithonia Lighting Fluorescent Flush Mount...
My fluorescent shop light fixtures sometimes does not go on and sometimes the bulbs just flicker without giving much light. What's wrong?
If your shop is in your garage, and it is cold outside, the two-pin fluorescent tubes don't work very well. Garage lighting (fluorescent) should be the HO (high output) type. It operates on the same voltage. The tubes are not interchangeable. You need a HO fixture. If your shop is inside your house, then flickering tubes (assuming that you tried changing them out with new ones) indicate a bad ballast inside the fixture. You can either change out the ballast, or for almost the same price, replace the fixture.
Sep 19, 2014 | Home
Fixture not working after bulb change
"CFLs" Compact Fluorescent Bulbs (with built in ballast) must be labeled as dimmable to be used on a dimmer circuit.
Traditional fluorescent fixtures must have a dimmable ballast installed inside and can be used with standard fluorescent lamps.
Fluorescent lamps must be sized to match the ballast. CFL's are matched at the factory, but others are not. Older fluorescent lamp fixtures have a ballast inside. A type rating is to operate (2) 48 inch / 40 watt lamps. Newer fluorescent lamps are rated for 32 watts, and these will not work - or will have a greatly reduced life.
If you installed CFL's, the first thing I would do is install regular incandescent lamps and see if it works as expected. If not, something else is wrong - otherwise - make sure you've got the right lamps in the fixture.
Mar 17, 2014 | Electrical Supplies
Need a replacement ballast for glo double 54 inch T5 HO aquarium light
Hagen has a massive website and they sell parts for virtually everything they make.
This is one page from their Canadian site listing ballasts for their lights.
http://ca-en.hagen.com/SearchProduct/ProductPageSearch?page=1&resultsPerPage=25&keyword=ballasts
Jan 10, 2014 | Hagen Glo T5 HO Electronic Ballast for T5...
My Sony undermount radio/cd combo has a lot of static noise when I turn on the fluorescent lights in our horse barn. As soon as I flip the light switch off the static disappears and the reception Is great...
Those lights are bad news for sending out interference especially if you are on the AM band with the radio. There is not a lot that you can do about it. IF the antenna is the cord and there is no other connections on the radio, you have to change light types ( and you can get LED ) that replace those you have, or you can switch to FM band or use disks. The ballast in those lights is a huge magnetic field
Nov 06, 2017 | Sony ICF-CDK50 Under Counter CD...
How do you take the light fixture apart to fix the balace?
You may find that a new fixture is the easier and cheaper way to go as some ballast can be expensive and hard to find the matching style. A similar style fixture at Home Depot or Lowes cost, in a 2 pack about $18.00. Add a CF bulb to it for another $4.00 and you have a decorative similar fixture. Some ballast cost anywhere from $9.00-$50.00. If you wish to replace the ballast: (turn off the power) remove the globe, remove the existing florescent bulb, take the fixture off the ceiling (usually two screws) remove the wire nuts, make a small diagram of the existing wires and the color codes, take the ballast to the Home Depot or Lowes first, match the ballast. Now reverse the process to replace the fixture. Hope this helps. Good Luck!
Douglas
Oct 31, 2010 | Universal Lighting and Decor White...
Home Logo
130 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
